[GRASS-windows] Re: [GRASS-dev] Instructions for devel versions added to CompileOnWindows
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Sun Mar 29 22:39:57 EDT 2009
Hi Colin & Markus,
I changed the line 299 of .../etc/Init.sh on three ways:
  a)  GRASS_WISH=wish.exe
  b)  GRASS_WISH=/c/OSGeo4W/bin/wish.exe
  c)  GRASS_WISH=/c/OSGeo4W/bin/wish85.exe
After I started MSYS and GRASS65: choices (b) and (c) worked fine,
but (a) still get error. May be we need to include "/c/OSGeo4W/bin"
on the PATH?
In fact, when I am writing, I tested options (b) and (c) and GRASS bypass
the WISH problem. But I get SEVERAL errors under MSYS, because
the system say that CAN'T find several lib** files, and CRASH. It happens
only
under MSYS!
BUT, if I add the path as shown below (etc/Init.sh) the things are solved.
if [ -n "$GRASS_ADDON_PATH" ] ; then
PATH="$GISBASE/bin:$GISBASE/scripts:$GRASS_ADDON_PATH:/c/OSGeo4W/bin:$PATH"
else
   PATH="$GISBASE/bin:$GISBASE/scripts:/c/OSGeo4W/bin:$PATH"
fi
So, I think we need to include the OSGeo4W/bin on the PATH almost for
VISTA 64bits.
I Continue testing... Remembering that I compiled GRASS 6.5 yesterday
(MSYS).
Curiously, I get the same problems (GRASS Crashing AFTER RUN ONLY ONE
TIME AFTER INSTALATION UNDER MSYS) on the grass64 binaries compiled and
available on OSGeo4 site. I don't know the reason of the GRASS run once time
and
not run fine again...
Well, I am here to test... almost under Vista (sorry!) 64.
milton
2009/3/29 Markus Neteler <neteler at osgeo.org>
> On Sun, Mar 29, 2009 at 6:45 PM, Colin Nielsen <colin.nielsen at gmail.com>
> wrote:
> > The grass64 (non-bat) startup from within msys uses Init.sh rather
> > than Init.bat. I think the equivalent in init.sh is line 299:
> > GRASS_WISH=wish
> Ah, ok. So I guess that a condition is needed: if Windows, then wish.exe,
> not wish. Maybe Milton can try that?
> > Perhaps this is a PATH problem, since wish.exe is in /osgeo4w/bin
> > which should be in PATH. I can't be sure, since grass starts fine for
> > me without the wish error.
> Still just guessing :)
> Markus
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090329/b5ba6c0a/attachment.html
More information about the grass-windows mailing list
