[GRASS-windows] r.in.ascii
Enrico R. Crema enryu_crema at yahoo.it
Mon Nov 2 15:03:43 EST 2009
I've changed my OS to MacOSX...but still using GRASS!!
E.
> Thanks Enrico,
> I'll try... :) I'll let you know... I hope it's not a WinGrass
> problem.
> By the way, can you tell me what software are you using instead of
> WinGRASS?
> Consuelo
> Enrico R. Crema wrote:
>> Hi Consuelo,
>> If you are importing an ESRI created ASCII file use r.in.arc instead
>> of r.in.ascii. The headers of ESRI's ASCII file are in fact slightly
>> different from the ones created by r.out.ascii, so this might be the
>> reason. I'm not using WinGRASS anymore though, so there are remote
>> chances that this is a wingrass problem, but worth have a try with
>> r.in.arc!!!!
>> Enrico
>>> Date: Fri, 30 Oct 2009 02:58:42 -0700 (PDT)
>>> From: cheluna <cheluna at gmail.com>
>>> Subject: [GRASS-windows] r.in.ascii
>>> To: grass-windows at lists.osgeo.org
>>> Message-ID: <1256896722991-3917960.post at n2.nabble.com>
>>> Content-Type: text/plain; charset=us-ascii
>>> Hello to everyone!
>>> I have a question. I'm not sure if I'm doing something wrong or
>>> what. I'm
>>> trying to import an ASCII file into WinGrass (using Phyton
>>> interface). The
>>> file was created with ArcInfo. The file is a 5.3 MB *asc file. But
>>> it is
>>> taking ages in importing it and after 21 hours, I gave in. Is that
>>> possible?
>>> Can it take that long? Or did I do something wrong?
>>> I'm using Windows Xp Sp3 on a Dell XPS M1210. I have installed Grass
>>> using
>>> OsGeo4W. Anyone has a clue?
>>> Thanks!
>>> Consuelo
>>> View this message in context:
>>> http://n2.nabble.com/r-in-ascii-tp3917960p3917960.html
>>> Sent from the Grass - Win mailing list archive at Nabble.com.
>>> grass-windows mailing list
>>> http://lists.osgeo.org/mailman/listinfo/grass-windows
>>> End of grass-windows Digest, Vol 38, Issue 8
> View this message in context: http://n2.nabble.com/r-in-ascii-tp3919908p3930959.html
> End of grass-windows Digest, Vol 39, Issue 1
More information about the grass-windows mailing list
