[GRASS-windows] Python collections module
Frank Broniewski brfr at metrico.lu
Mon Feb 8 09:47:53 EST 2010
Ok, replacing the shipped version with the latest 2.5 version from the
python hp fixes this. Nevertheless I think this is a bug, but I hesitate to
report it until someone can confirm this.
Meanwhile I noticed that the grass python scripts mix spaces and tabs which
is not good. I am willing to remove the tabs from the file (PEP8 anyone?)
and upload the "fixed" scripts somewhere. Is there a procedure which I could
follow so that it is easy for the devs to integrate the changes?
Frank
Sent: Monday, February 08, 2010 2:27 PM
To: "grass-windows" <grass-windows at lists.osgeo.org>
Subject: [GRASS-windows] Python collections module
> Hello list,
> I am using the osgeo4w installation and I want to use the python scripting
> possibilities.
> When I try to import the grass module I get an ImportError "No module
> named collections" from "C:\OSGeo4W\apps\Python25\lib\threading.py".
> And indeed there is no collections.py. When I look into my Python26
> installation dir, there is a collections.py in Python26\Lib. Is the
> osgeo4w python package broken? Reinstalling does not fix the missing
> collections module.
> I appreciate any help with this problem
> Frank
> Frank Broniewski
> Metrico s.àr.l. ( http://www.metrico.lu )
> 36, rue des Romains
> L-5433 Niederdonven
> Luxembourg
> Fon: +352 26 74 94 28
> Fax: +352 26 74 94 99
> grass-windows mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-windows
More information about the grass-windows mailing list
