[GRASS-windows] grass evnironment variables and grass session
maven apache apachemaven0 at gmail.com
Thu Feb 25 20:48:17 EST 2010
2010/2/26 Glynn Clements <glynn at gclements.plus.com>
> maven apache wrote:
> > set GISBASE=D:\GrassDataBase;
> > set GISRC=C:\Documents and Settings\Administrator\.grassrc6;
> > set LOCATION_NAME=spearfish60;
> None of those lines should have semicolons on the end, and the third
> one shouldn't exist (LOCATION_NAME is a %GISRC% setting, not an
> environment variable).
> Thanks, I delete the semicolons on the end , and it works(grass of version
6.3, and I am trying to test the grass 6.4)
BTW, is the 6.4.svn version in the download page of  grass is stable?
Another question, the grass session:
if the gisrc file (.grassrc6) is work for just one user? I mean if more than
one user use the grass , should I create a .grassrc6 which contain a new
location and mapset for each user?
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20100226/1cdce1fa/attachment.html
More information about the grass-windows mailing list
