[GRASS-windows] grass evnironment variables and grass session
maven apache apachemaven0 at gmail.com
Sun Feb 28 21:13:26 EST 2010
2010/2/27 Glynn Clements <glynn at gclements.plus.com>
> maven apache wrote:
> > BTW, is the 6.4.svn version in the download page of  grass is stable?
> Anything with ".svn" in the name is a snapshot of the SubVersion
> repository, which changes from day to day.
The same bat works just on the 6.3 , when I change to 6.4 ,it does not work.
why?
@echo off
rem *******Environment variables***********
rem Set GRASS Installation Directory Variable
set GRASSDIR=F:\anzhuang\GRASS  //when I change to 6.4, it does not work.
rem set GISBASE=D:\GrassDataBase
set GISRC=C:\Documents and Settings\Administrator\.grassrc6
rem Set Path to utilities (libraries and bynaries) used by GRASS
set PATH=%GRASSDIR%\msys\bin;%PATH%
set PATH=%GRASSDIR%\extrabin;%GRASSDIR%\extralib;%GRASSDIR%\extrabin;%PATH%
set
PATH=%GRASSDIR%\tcl-tk\bin;%GRASSDIR%\sqlite\bin;%GRASSDIR%\gpsbabel;%PATH%
set
PATH=%PATH%;%GRASSDIR%\bin;%GRASSDIR%\lib;%GRASSDIR%\scripts;%GRASSDIR%\etc;%GRASSDIR%\sqlite\lib;%GRASSDIR%\sqlite\bin;
rem Path to the proj files (notably the epsg projection list)
set GRASS_PROJSHARE=%GRASSDIR%\proj
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20100301/164ebbc9/attachment.html
More information about the grass-windows mailing list
