[GRASS-windows] Location Wizard Problem
Luigi Ponti lponti at infinito.it
Tue Jan 26 07:17:31 EST 2010
On 26/01/2010 01:46, Markus Neteler wrote:
> On Sun, Jan 10, 2010 at 6:23 PM, MJ <mlc652 at gmail.com> wrote:
>> I am running the Windows version of Grass 6.4.0 (installed from native
>> version wingrass-6.4.osvn-r40049-1-setup.exe).  When I try to execute
>> the following, I have problems.
>> * Launch GRASS
>> * On the right-hand side select Location Wizard under Define new location
>> * Leave the GIS Data Directory field as is but choose a descriptive
>> name for the Project Location
>> * Continue to the next page
>> * Choose Select Coordinate System parameters from a list and continue
>> * Type in ll for the Projection Code or scroll down the page to find Lat/Lon
>> * Choose Dataum with associated ellipsoid
>> When I try to enter a Central Parallel or Central Meridian, nothing
>> changes occur in the entry boxes.  I can highlight the default zero
>> values, but I am unable to change them.
>> If I now click Next, I get the error "Something is Missing.  You must
>> enter a value for Central Meridian"
>> The same thing happens if I Choose the Ellipsoid Only option.
>> How dows one move past this page? Am I doing something wrong, or is this a bug?
>> Thanks.
> He/she uses Vista. While it now works for me on XP, any other user
> here experimenting problems with above in Vista using a fresh package
> from
> http://josef.fsv.cvut.cz/wingrass/grass64/
Same problem with today's WinGRASS-6.4.SVN-r40650-1-Setup.exe
(26-Jan-2010 03:47) on Windows 7, if it helps.
Text input boxes are grayed and showing 0.0 preset answer with no way to
modify it (you can put cursor in and highlight 0.0 but no way to enter
text).
Regards,
Luigi
> Markus
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20100126/403fa995/attachment.html
More information about the grass-windows mailing list
