[GRASS-windows] grass start bat in windows
Sun Jan 31 22:39:59 EST 2010
maven apache wrote:
> I want to write a bat to starat grass in command line .
> Thant's to say how to set the environment variables and grass vairables in
> the bat file.
> In fact I want to call garss in my java web application, so I think if I can
> write a bat to start grass, then I can do the same job(set envrionment
> variables) in my codes, then call garss.
> Is there anyone who has same experience?
Try something like the following:
	set WINGISBASE=C:\GRASS-64-SVN
	set GISBASE=C:/GRASS-64-SVN
	set PATH=%WINGISBASE%/bin;%WINGISBASE%/lib;%PATH%
	set GRASS_MESSAGE_FORMAT=silent
	set GIS_LOCK=0
	set GRASS_VERSION=6.5.svn
	WD=...
	UNIQUE=...
	set GISRC=%WD%/gisrc_%UNIQUE%
	copy %WD%\grassrc6 %GISRC%
	rem create a new mapset for this session
	g.mapset -c mapset_%UNIQUE%
You will need to set WD to a working directory, and set UNIQUE to a
unique value for each session (on Unix, $$ contains the PID of the
shell process; you'll need to figure out something for Windows).
More information about the grass-windows mailing list
