[GRASS-windows] Using an external hard drive as data source
Mon May 24 17:11:40 EDT 2010
Hanlie Pretorius wrote:
> I'm using GRASS on two machines in different locations (one Win XP,
> the other Ubuntu 10.04), so I would like to keep my grassdata folder
> on an external drive. However, when I try to run grass in Ubuntu using
> the external hard drive (NTFS file system), I get the following error
> as soon as I've selected the new data location and the GUI starts to
> load:
> Execution failed: 'g.region -u -g -p -c'
> Details:
> Error: MAPSET PERMANENT - permission denied
> To run GRASS, I use the command 'sudo grass -wx'.
> GRASS works fine when I run it from the internal hard drive.
> Is there a way to get GRASS to work from the external drive?
You must be the owner of the directory for the current mapset.
If you're mounting a FAT filesystem, you can use the uid= mount option
to set the ownership of the files. However, I don't know what the
situation is with NTFS, as it has its own permission model.
More information about the grass-windows mailing list
