[GRASS-windows] Re: GRASS 6.4.0 in Windows XP
Maciej Sieczka msieczka at sieczka.org
Tue Sep 28 16:03:49 EDT 2010
W dniu 28.09.2010 21:49, Thierry_ pisze:
> I have the same problem. I installed GRASS 6.4.0-1 from the installer on the
> website. A full install in "d:/GRASS" on a Win XP machine with both demo
> datasets.
> GRASS starts up fine and give me the welcome screen. I can select one of the
> demo projects or create a new project. But when I click on Start GRASS then
> I get an error: "execution failed: g.proj - p"
Does g.proj work ok from the command line though? If not, check if this
is not the same issue as in
http://osgeo-org.1803224.n2.nabble.com/lots-of-The-application-failed-to-initialize-properly-in-6-4-0-on-Windows-td5521511.html#a5571695.
Maciek
Maciej Sieczka
http://www.sieczka.org
More information about the grass-windows mailing list
