[GRASS-windows] Compiling grass 6.4 on windows Xp using OSGeo4W
(ERROR: Could not determine External PROJ.4 version)
Glynn Clements
glynn at gclements.plus.com
Thu Jul 21 10:37:35 EDT 2011
ines_cherif wrote:
> I' m trying to compile grass 6.4 on my PC (Windows XP, 32bits)
> strictly following the instructions provided on:
> http://trac.osgeo.org/grass/wiki/CompileOnWindows. However I get the
> following error when running package.sh./
> checking how to run the C preprocessor... ./configure: line 1589: 4612 Segmentation fault (core dumped) ( eval $ac_try ) 2>&5
> checking for termio.h... ./configure: line 4163: 5640 Segmentation fault (core dumped) ( eval $ac_try ) 2>&5
> checking for time... ./configure: line 4524: 412 Segmentation fault (core dumped) ( eval $ac_link ) 2>&5
> checking whether setpgrp takes no argument... ./configure: line 4787: 7112 Segmentation fault (core dumped) ( eval $ac_link ) 2>&5
> checking for curses.h... ./configure: line 5924: 196 Segmentation fault (core dumped) ( eval $ac_try ) 2>&5
> checking for gtty in -lbsd-compat... ./configure: line 6040: 3828 Segmentation fault (core dumped) ( eval $ac_link ) 2>&5
> ./configure: line 6040: 4656 Segmentation fault (core dumped) ( eval $ac_link ) 2>&5
> checking External PROJ.4 version... ./configure: line 7173: 6352 Segmentation fault (core dumped) ( eval $ac_link ) 2>&5
The compiler seems somewhat prone to crashing. This could be caused by
a bad compiler installation, incompatible system libraries, or a
hardware problem (for some reason, compilers seem to be more likely
than other progams to show up defective RAM).
Either way, it's not directly related to GRASS.
More information about the grass-windows
