[GRASS-windows] Fwd: winGrass, ODBC and Oracle
    Sharon M
    morrisxs09 at gmail.com
    Tue May  3 02:46:13 EDT 2011
Received no feedback on the Grass list, so checking if the winGrass list has
any ideas.
Thanks in advance for any ideas.
Sharon
---------- Forwarded message ----------
Date: Fri, Apr 29, 2011 at 4:07 PM
To: grass-user at lists.osgeo.org
I'm running winGrass 6.4.1 on winXP and trying to use the wingrass ODBC
driver to connect to an Oracle database.
I've used db.login and db.connect to define the database and user. When I
run db.tables -p a windows pops up with an error message:
Error odbc.exe has encounted a problem and needs to close
Do any winGrass versions - 6.4.1 or 6.5 or 7 - work with the Grass ODBC
driver and Oracle?
Also, are any of the Windows precompiled winGrass binaries compiled with the
ODBC driver?
Any help on this would be appreciated because I'd like to move my attribute
tables from the dbf driver to Oracle (which is where the attribute data came
from originally).
Thanks in advance,
Sharon
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20110503/b180153d/attachment.html
More information about the grass-windows
