[GRASS-windows] Re: WinGRASS installation and addtional python modules
Helmut Kudrnovsky hellik at web.de
Fri May 20 07:28:34 EDT 2011
hi,
have a look in
http://svn.osgeo.org/grass/grass/trunk/gui/wxpython/README
REQUIREMENTS
GRASS GIS >= 6.4
Python >= 2.4 (Python 3 not supported) Python ElementTree (only for Python 2.4)
wxPython >= 2.8.1.1
NumPy >= 1.0.4
best regards
Helmut
-----Ursprüngliche Nachricht-----
Von: "Johannes Radinger" <JRadinger at gmx.at>
Gesendet: 20.05.2011 09:41:33
An: "Helmut Kudrnovsky" <hellik at web.de>
Betreff: Re: WinGRASS installation and addtional python modules
Hej,
Am 19.05.2011 um 20:59 schrieb Helmut Kudrnovsky:
>>> call "%GISBASE%\etc\env.bat">
>> You should probably look at this.
>> just have a look in the source
>> http://trac.osgeo.org/grass/browser/grass/branches/
>> releasebranch_6_4/mswindows/env.bat#L32
>> rem Path to the python directory
>> set PYTHONHOME=%GISBASE%\Python25
>> if "x%GRASS_PYTHON%" == "x" set GRASS_PYTHON=python
So what I did now so far is:
1) Deleted the Grass\python25 folder
2) created the env. variables: PYTHONPATH (set to %GISBASE%\etc\python)
and GRASS_PYTHON (set to C:\Python27\python.exe)
3) In env.bat: I tried to delete the line "set PYTHONHOME=%GISBASE%
\Python25" and I tried to replace it with "set PYTHONHOME=C:
\Python27" ---Should I delete or replace or?
4) I didn't found anything about python25 in the init.bat
Still nothing happes after start...I tried to open the Wxgui and to
open the Command line. The command line asks me for my mapset etc and
after typing Esc+Enter it closes.
Can anyone tell me exactly what I've to delete or replace.
Do I need wxpython installed on my local python27 installation?
/johannes
> [sent to early]
>>> "%WINGISBASE%\etc\Init.bat" %*>
>> And this.
> releasebranch_6_4/lib/init/init.bat
> best regards
> Helmut
> ___________________________________________________________
> Schon gehört? WEB.DE hat einen genialen Phishing-Filter in die
> Toolbar eingebaut! http://produkte.web.de/go/toolbar
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-windows/attachments/20110520/daceae73/smime.bin
More information about the grass-windows mailing list
