[GRASS-windows] Problem with compilation of GRASS 7.0 SVN on
	Windows 7
    Johannes Radinger
    JRadinger at gmx.at
    Mon Oct  3 09:10:15 EDT 2011
Hello,
I want to learn how to compile GRASS GIS 7.0 SVN on my Windows 7 platform.
Therefore I followed the instructions on
http://trac.osgeo.org/grass/wiki/CompileOnWindows
and did all the steps:
1) Installation of the OSGeo4W directory structure
2)Installation of the environment for compilation and unzipping and
copying MinGW packages to
mentioned destination folders
3) Downloaded, unzipped and copied the pre-build binaries (bison etc.)
to the destination folder
4) Downloaded and unzipped the GRASS 7.0 source code (weekly snapshot)
and copied to the usr/scr folder
5)Then I tried to compile. Therefore I typed as mentioned:
./mswindows/osgeo4w/package.sh
but got following problem!!:
sh: ./mswindows/osgeo4w/package.sh: No such file or directory
So what was wrong with my procedure? Is there anything missing?  How can
I check if
all the downloads were correct?
My osgeo4W directory looks now like:
Directory of C:\OSGeo4W
03.10.2011  14:09 <DIR>          .
03.10.2011  14:09 <DIR>          ..
19.09.2011  20:20 <DIR>          apps
03.10.2011  14:09 <DIR>          bc-1.06-2-bin
19.09.2011  20:23 <DIR>          bin
03.10.2011  14:03 <DIR>          binutils-2.19.1-mingw32-bin
03.10.2011  14:09 <DIR>          bison-2.1-bin
03.10.2011  14:09 <DIR>          bison-2.1-dep
19.09.2011  20:19 <DIR>          etc
03.10.2011  14:09 <DIR>          flex-2.5.4a-1-bin
03.10.2011  14:03 <DIR>          gcc-core-3.4.5-20060117-3
03.10.2011  14:03 <DIR>          gcc-g++-3.4.5-20060117-3
03.10.2011  14:09 <DIR>          gettext-0.14.4-bin
03.10.2011  14:09 <DIR>          gettext-0.14.4-lib
19.09.2011  20:21 <DIR>          include
19.09.2011  20:21 <DIR>          lib
03.10.2011  14:09 <DIR>          libiconv-1.9.2-1-lib
03.10.2011  14:09 <DIR>          libintl-0.14.4-bin
03.10.2011  14:09 <DIR>          libintl-0.14.4-lib
03.10.2011  14:03 <DIR>          mingw-utils-0.3
03.10.2011  14:03 <DIR>          mingw32-make-3.81-20080326-3
03.10.2011  14:03 <DIR>          mingwrt-3.15.2-mingw32-dev
07.02.2011  17:25             5.341 MRSID_EULA.txt
03.10.2011  14:03 <DIR>          msysCORE-1.0.11-bin
19.09.2011  20:23               151 OSGeo4W.bat
19.09.2011  20:23             4.286 OSGeo4W.ico
03.10.2011  14:09 <DIR>          readline-5.0-1-bin
03.10.2011  14:09 <DIR>          regex-2.7-bin(1)
19.09.2011  20:20 <DIR>          share
19.09.2011  20:18 <DIR>          tmp
19.09.2011  20:18 <DIR>          usr
19.09.2011  20:18 <DIR>          var
03.10.2011  14:03 <DIR>          w32api-3.13-mingw32-dev
                3 File(s)          9.778 bytes
               30 Dir(s)  60.059.414.528 bytes free
Hope somebody can help me, so that I can compile my own GRASS installations.
And maybe you can also help me how to install GRASS add ons in windows?
Probably they have to be compiled with the source...but how does that work?
Thank you very much
best regards
Johannes
More information about the grass-windows
