[GRASS-windows] problem from python & grass64 on Win XP
Liu, Huili HLiu at ap.org
Mon Oct 3 11:41:10 EDT 2011
Hi Glynn,
Thank you for your quick response.
You are right. I used Textpad to edit the script and I removed the last
empty line but it was still there. I tried notepad and it works.
Thanks,
Willie
-----Original Message-----
From: Glynn Clements [mailto:glynn at gclements.plus.com]
Sent: Friday, September 30, 2011 1:55 PM
To: Liu, Huili
Cc: grass-windows at lists.osgeo.org
Subject: Re: [GRASS-windows] problem from python & grass64 on Win XP
Liu, Willie wrote:
> I am trying to run a simple python script as below on Win XP but I got
> "Line too long or missing newline at line 56". I believe the problem
> comes from "grass.parser()".
The last line of the script must be entirely blank, i.e. the last
character of the script must be a newline.
The information contained in this communication is intended for the use
of the designated recipients named above. If the reader of this
communication is not the intended recipient, you are hereby notified
that you have received this communication in error, and that any review,
dissemination, distribution or copying of this communication is strictly
prohibited. If you have received this communication in error, please
notify The Associated Press immediately by telephone at +1-212-621-1898
and delete this e-mail. Thank you.
[IP_US_DISC]
msk dccc60c6d2c3a6438f0cf467d9a4938
More information about the grass-windows mailing list
