[GRASS-windows] Re: Re: Problem with compilation of GRASS 7.0 SVN on Windows 7
Helmut Kudrnovsky hellik at web.de
Wed Oct 5 16:05:42 EDT 2011
>Thank you for your help. Of course I've to switch into the directory where
I want to compile.
>In the wiki (http://trac.osgeo.org/grass/wiki/CompileOnWindows) I was just
jumping over
>the coments on 6.4.1 to the compilation of GRASS 7.0 where it isn't
mentioned anymore.
it's a wiki ;o) , please feel free to improve!
>Anyway this problem seems to be solved...
good to hear.
>...but probabaly a new one popped up. After typing
./mswindows/osgeo4w/package.sh
>nothing really happens, no error but also no GRASS installation.
right, also here on my side, see http://trac.osgeo.org/grass/ticket/1460
>4. Check error.log for any messages and mswindows/osgeo4w/package.log if
you're having problems.
>But where can I find the error log on my computer (directory) or how can
access them to check what
>is wrong?
my source-tree of grass_trunk is i.e. here in
C:\OSGeo4W\usr\src\grass_trunk
so error.log is C:\OSGeo4W\usr\src\grass_trunk\error.log
but error.log is only there, if all compile-configuration is done, but in
this case it doesn't get so far, so see mswindows/osgeo4w/package.log
>To the add-on installation:
>1) Your way of putting the add-on into the trunk and then compile
GRASS+Add-on at
>once sounds promissing to me
it's the way to go...
>2) Does the wingrass-installer work also on other windows systems beside my
own?
the self built wingrass-installer should be working everywhere ...
>There is probably a difference between 32 and 64 bit but any other things I
have to consider?
wingrass is at the moment always 32-bit (because of lacking a
64-bit-build-system, but in principle a wingrass-64bit should be possible)
>3) This way of your installation of an add-on should actually work on any
system where
>I want to compile GRASS?
yes
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-with-compilation-of-GRASS-7-0-SVN-on-Windows-7-tp6854923p6863606.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
