[GRASS-windows] Re: Compiling WINGrass 7.0SVN
Johannes Radinger JRadinger at gmx.at
Wed Oct 12 04:45:02 EDT 2011
Am 12.10.2011 18:00, schrieb grass-windows-request at lists.osgeo.org:
> seehttp://lists.osgeo.org/pipermail/grass-commit/2011-October/019671.html
> "fix package.sh (deleting old package logs)"
thank you for that fix and your post about it! The log-file seems to
work now
in the newest revision. Now I can see were I run in troubles. I get
following
error when configuring (package.log):
`/c/OSGeo4W/lib/sqlite3_i.lib' -> `mswindows/osgeo4w/lib/libsqlite3.a'
`/c/OSGeo4W/lib/proj.lib' -> `mswindows/osgeo4w/lib/libproj.a'
`/c/OSGeo4W/lib/libtiff_i.lib' -> `mswindows/osgeo4w/lib/libtiff.a'
`/c/OSGeo4W/lib/libpq.lib' -> `mswindows/osgeo4w/lib/libpq.a'
`/c/OSGeo4W/lib/jpeg_i.lib' -> `mswindows/osgeo4w/lib/libjpeg.a'
`/c/OSGeo4W/lib/zlib.lib' -> `mswindows/osgeo4w/lib/libz.a'
Wed Oct 12 10:29:55 CEDT 2011: STARTING remove old logs
Wed Oct 12 10:29:55 CEDT 2011: FINISHED remove old logs AFTER 0s
Wed Oct 12 10:29:55 CEDT 2011: STARTING configure
checking host system type... i686-pc-mingw32
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... rm: cannot lstat `conftest.exe':
Permission denied
yes
checking for Cygwin environment... no
checking for mingw32 environment... yes
checking for executable suffix... .exe
checking for full floating-point support... yes
checking for pwd... /bin/pwd
checking for source directory... /osgeo4w/usr/src/grass-7.0.svn
checking for build directory... /osgeo4w/usr/src/grass-7.0.svn
checking for svnversion... no
checking for MacOSX App... no
checking for MacOSX architectures... no
checking for MacOSX SDK... no
checking how to build libraries... shared
checking for additional include dirs... /c/OSGeo4W/include
checking for additional library dirs... /c/OSGeo4W/lib
/osgeo4w/usr/src/grass-7.0.svn/mswindows/osgeo4w/lib
checking for a BSD compatible install... /bin/install -c
checking for flex... lex
checking for yywrap in -ll... no
checking for lex... no
configure: error: *** Unable to locate lex.
There is a probelm with lex. Has that anything to do with flex? I never
explicitely installed any "lex". Just in case it has something to do
with flex...There is a flex-2.5.4a-1-bin folder in c://OSGeo4W
Are the other configure settings okay? What is with the conftest.exe note?
So one step further but still not at the end of the road...
best regards
Johannes
More information about the grass-windows mailing list
