[GRASS-windows] Problem in downloading and installing GRASS64 package
Angelo Paone angelo.paone1 at gmail.com
Fri Mar 1 01:38:31 PST 2013
Dear windows mailing list,
I have already send you a msg, I hope that this time someone will explain
me what I miss here,
To download the grass64 and gdal, I follow the istraction on your web
pages, and I make a short-cut of set.up.exe, then through proprieties I
edit the setup.exe adding -X as follow:
Target : C:\Users\USER\Desktop\setup.exe -X
then I run the set.up.exe -X, and I go to the list of mirror, than I add
the following URL:
  *http://grass.osgeo.org/grass64/binary/mswindows/cygwin/*  as you suggest.
I click on next and a msg comes out saying that
"http://grass.osgeo.org/grass64/binary/mswindows/cygwin/ //setup.ini line 1
: syntax error, unexpected LT, expecting $end"
I am sorry but I do not undenstand why it does not work, can someone
explain me?
Best wishes
Angelo
Angelo Paone
Research Professor
Post-Doctoral Research Fellow
Marie Curie Fellow
PhD, MSc, BSc
Pusan Natioanl University
Department of Earth Science
30, Jangjeon-dong, Geumjeong-gu
Busan, Republic of Korea
Tel. +82-51-510-2987
URL: <http://lists.osgeo.org/pipermail/grass-windows/attachments/20130301/f7d64da0/attachment.html>
More information about the grass-windows mailing list
