[GRASS-windows] winGrass 7 r.watershed bugs
    Hanan Karam
    HananKaram at esinternational.com
    Mon Mar 18 11:00:22 PDT 2013
Hi everyone,
I've been using GRASS for a couple months now on a Windows platform.  I use it for hydrological modelling.  I started with WinGrass 6.4.3RC2 and then decided to try out WinGrass7 (SVN nightly winGRASS 7 experimental build downloaded on February 23 2013)
r.watershed worked well in WinGrass 6.4.3RC2, but it seems to have the following bugs in WinGrass 7.  Any information on these bugs would be appreciated:
1) output flow accumulation map is actually a drainage direction map
2) no output of flow accumulation map
(streams and basins output maps are fine)
The command I used is:
r.watershed -m elevation=DEMmap threshold=4000 accumulation=ACCmap drainage=DRAINDIRmap basin=BASINmap stream=STREAMmap
And the output was:
SECTION 1 beginning: Initiating Variables. 5 sections total.
SECTION 1a: Mark masked and NULL cells
SECTION 1b: Determining Offmap Flow.
SECTION 2: A* Search.
SECTION 3a: Accumulating Surface Flow with MFD.
SECTION 3b: Adjusting drainage directions.
SECTION 4: Watershed determination.
SECTION 5: Closing Maps.
Closing stream segments map
Closing basins map
Closing accumulation map
Closing flow direction map
WARNING: category information for [DRAINDIRmap] in [HNK2] missing or invalid
Results:  Basin and Stream maps are good.  No drainage direction map was output. The output flow accumulation map turned out to be a drainage direction map.
Cheers,
Hanan
Hanan Karam
Consultant
ESI: The UK's leading independent scientific environmental consultancy specialising in water, land and sustainable development.
T: +44 (0) 1743 276100
E: mailto:hanankaram at esinternational.com| W: http://www.esinternational.com<http://www.esinternational.com/>
ESI Ltd, New Zealand House, 160 Abbey Foregate, Shrewsbury, SY2 6FD
SHREWSBURY | LONDON | READING | CARDIFF
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. They may also be legally privileged. If you have received this email in error please notify us immediately by reply and destroy any copies.  ESI Ltd. is registered in England & Wales under registration number 3212832.
This message has been scanned for malware by Websense. www.websense.com
URL: <http://lists.osgeo.org/pipermail/grass-windows/attachments/20130318/fa662fbc/attachment.html>
More information about the grass-windows
