[Gvsig_italian] file .log Burbello
alberto.burbello a libero.it alberto.burbello a libero.it
Mar 3 Lug 2012 03:04:24 PDT
Salve lista ecco il file .log intero relativo al mio problema  poco fa descritto..Saluti e grazie
INFO main com.iver.andami.ui.fonts.FontUtils - Fonts configuration was not necessary
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Non si é incontrata la traduzione per 1.11.0 final
INFO main com.iver.andami.Launcher - Ignorando il registroC:\Programmi\gvSIG_1.11.0_final\bin\gvSIG\extensiones\raster_trasp_0.1. Documento 'config.xml' non trovato
INFO main com.iver.andami.Launcher - Ignorando il registroC:\Programmi\gvSIG_1.11.0_final\bin\gvSIG\extensiones\src. Documento 'config.xml' non trovato
INFO main com.iver.andami.Launcher - Ignorando il registroC:\Programmi\gvSIG_1.11.0_final\bin\gvSIG\extensiones\__MACOSX. Documento 'config.xml' non trovato
WARN main com.iver.andami.PluginServices - Non si é incontrata la traduzione per setting_up_event_queue
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.core
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.core.menus.ToolbarMenus...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.core.PreferencesExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.core.Consola...
INFO AWT-EventQueue-1 com.iver.andami.messages.NotificationManager - Se añade un listener al manager de notificaciones
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.core.StatusBar...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.About...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.IntializeApplicationExtension...
INFO AWT-EventQueue-1 com.iver.cit.gvsig.IntializeApplicationExtension - gvSIG version: 1.11.0 final (Build 1305)
INFO AWT-EventQueue-1 com.iver.cit.gvsig.IntializeApplicationExtension -     gvSIG app exec path: C:\Programmi\gvSIG_1.11.0_final\bin
INFO AWT-EventQueue-1 com.iver.cit.gvsig.IntializeApplicationExtension -     gvSIG user app home: C:\Users\Burbello\gvSIG\
INFO AWT-EventQueue-1 com.iver.cit.gvsig.IntializeApplicationExtension -     gvSIG extension path: C:\Programmi\gvSIG_1.11.0_final\bin\gvSIG\extensiones
INFO AWT-EventQueue-1 com.iver.cit.gvsig.IntializeApplicationExtension -     gvSIG locale language: it
INFO AWT-EventQueue-1 com.iver.cit.gvsig.IntializeApplicationExtension - OS name: Windows 7
INFO AWT-EventQueue-1 com.iver.cit.gvsig.IntializeApplicationExtension -     arch:x86
INFO AWT-EventQueue-1 com.iver.cit.gvsig.IntializeApplicationExtension -     version:6.1
INFO AWT-EventQueue-1 com.iver.cit.gvsig.IntializeApplicationExtension - JAVA vendor: Sun Microsystems Inc.
INFO AWT-EventQueue-1 com.iver.cit.gvsig.IntializeApplicationExtension -     version:1.6.0_33
INFO AWT-EventQueue-1 com.iver.cit.gvsig.IntializeApplicationExtension -     home: C:\Program Files (x86)\Java\jre6
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayerOrderExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ShalomExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.MeasureExtension...
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Non si é incontrata la traduzione per options.view.show_file_extensions
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ViewControls...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ViewSelectionControls...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InfoToolExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.CopyPasteExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.BasicSymbologyExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.AddLayer...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ProjectExtension...
WARN AWT-EventQueue-1 es.prodevelop.cit.gvsig.fmap.drivers.jdbc.oracle.OracleSpatialDriver - *-----------------------------------------------------------------------*
WARN AWT-EventQueue-1 es.prodevelop.cit.gvsig.fmap.drivers.jdbc.oracle.OracleSpatialDriver - * Oracle JDBC library (ojdbc*.jar) not found. You need to copy that
WARN AWT-EventQueue-1 es.prodevelop.cit.gvsig.fmap.drivers.jdbc.oracle.OracleSpatialDriver - * jar file to gvSIG's main lib folder if you intend to access
WARN AWT-EventQueue-1 es.prodevelop.cit.gvsig.fmap.drivers.jdbc.oracle.OracleSpatialDriver - * Oracle Spatial/Locator databases.
WARN AWT-EventQueue-1 es.prodevelop.cit.gvsig.fmap.drivers.jdbc.oracle.OracleSpatialDriver - * Read gvSIG manual (Oracle driver section) for details.
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ExtDB_Spatial...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.SingleVectorialDBConnectionExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.AboutContributors...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.FFrameLegendExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.RestoreViewInfoExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.PaletteViewInfoExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.Export...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.PrintProperties...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.PrintTable...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.Print...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ShowTable...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ViewProjectWindow...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.RemoveTableLink...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.RemoveTableUnion...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.FiltroExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableRowsOperations...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableNumericFieldOperations...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableFieldOperations...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditPasteExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditCutExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditCopyExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableManageFields...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditRemoveRowExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditInsertExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditStartExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditStopExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.UndoTableExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.RedoTableExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableOperations...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutCommandStackExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutUndoExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutRedoExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutGraphicControls...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.FFrameViewExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutInsertToolsExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutEditVertexExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutEditableControls...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ExportLayoutExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ClearSelectionExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ZoomToSelectExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ViewPropertiesExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ZoomPrev...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.geoprocess
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.geoprocess.manager.GeoprocessManagerExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.oracle_spatial
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.prodevelop.cit.gvsig.jdbc_spatial.NewOracleSpatialTableExtension...
ERROR AWT-EventQueue-1 es.prodevelop.cit.gvsig.jdbc_spatial.NewOracleSpatialTableExtension - Unable to instantiate ROWID (oracle jar missing?) : Errore leggendo il file:oracle.sql.ROWID
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.prodevelop.cit.gvsig.jdbc_spatial.ExportOracleExtension...
ERROR AWT-EventQueue-1 es.prodevelop.cit.gvsig.jdbc_spatial.ExportOracleExtension - Unable to instantiate ROWID (oracle jar missing?) : Errore leggendo il file:oracle.sql.ROWID
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.crs
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.crs.JCrsExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.chartlegend
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.chartlegend.ChartExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.jdbc_spatial
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.jdbc_spatial.ExtJDBC_Spatial...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.gvsig.datalocator
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.gvsig.datalocator.DataLocatorExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.gvsig.addeventtheme
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.gvsig.addeventtheme.AddEventThemeExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.backup
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.backup.BackUpProjectExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.backup.AboutBackUpProjectExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.hyperlink
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.hyperlink.LinkControls...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.iconThemeBase
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.iconThemeBase.ExtensionIcon16Theme...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.selectduplicates
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.selectduplicates.DuplicateSelectionExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.help
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.help.HelpExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.layerLoadingOrder
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.layerLoadingOrder.SmartOrderExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from es.unex.sextante
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteToolbarConfigExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteAboutExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextantePointCollectorExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteDataExplorerExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteAdditionalResultsExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteCommandLineExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteHistoryExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteModelerExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteToolboxExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from es.gva.cit.gvsig.catalogClient
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.gva.cit.gvsig.gazetteer.GazetteerExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.gva.cit.gvsig.catalog.CatalogClientExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.gva.cit.gvsig.catalog.CatalogClientAboutExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.gva.cit.gvsig.gazetteer.DeleteSearchesExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.georeferencing
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.georeferencing.GeoreferencingModule...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.wcs
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.wcs.WCSClientExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.installer.app.extension
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.installer.app.extension.execution.InstallPackageExtension...
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - Initializing library 'org.gvsig.tools.ToolsLibrary'.
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - PostInitializing library 'org.gvsig.tools.ToolsLibrary'.
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - Initializing library 'org.gvsig.installer.lib.api.InstallerLibrary'.
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - PostInitializing library 'org.gvsig.installer.lib.api.InstallerLibrary'.
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - Initializing library 'org.gvsig.installer.lib.impl.DefaultInstallerLibrary'.
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - PostInitializing library 'org.gvsig.installer.lib.impl.DefaultInstallerLibrary'.
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - Initializing library 'org.gvsig.installer.swing.api.SwingInstallerLibrary'.
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - PostInitializing library 'org.gvsig.installer.swing.api.SwingInstallerLibrary'.
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - Initializing library 'org.gvsig.installer.swing.impl.DefaultSwingInstallerLibrary'.
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - PostInitializing library 'org.gvsig.installer.swing.impl.DefaultSwingInstallerLibrary'.
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - Initializing library 'org.gvsig.installer.prov.plugin.PluginInstallerProviderLibrary'.
INFO AWT-EventQueue-1 org.gvsig.tools.library.AbstractLibrary - PostInitializing library 'org.gvsig.installer.prov.plugin.PluginInstallerProviderLibrary'.
DEBUG AWT-EventQueue-1 org.gvsig.tools.dynobject.impl.DefaultDynObjectManager - Add DynClass definition plugin.
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from es.prodevelop.cit.gvsig.arcims
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.prodevelop.cit.gvsig.arcims.extension.ArcimsClientModule...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.extended-symbology
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.symbology.SLDExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.symbology.ExtendedSymbologyExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.geoprocessextensions
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.geoprocess.impl.RegisterGeoprocessExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.rastertools
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.rastertools.GenericToolBarModule...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.rastertools.RasterModule...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.sde
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.sde.ExtSDE...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.tableExport
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.tableExport.xls.ExportTableToExcelExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.tableExport.ExportTableToFileExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.scripting
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.scripting.ScriptingExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.tableSummarize
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.app.documents.table.summarize.TableSummarizeExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.gvsig.centerviewpoint
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.gvsig.centerviewpoint.CenterViewToPointExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.quickPrint
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.iver.quickPrint.TemplateExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from it.gisforplanning.tools
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing it.raster.multitrasparency.MultiRasterTrasparency...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.i18n
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.i18n.extension.I18nExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.wms
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.wmc.ImportWebMapContextExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.wmc.ExportWebMapContextExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.wms.WMSClientExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.cad
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.SplitGeometryCADToolExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.AutoCompletePolygonExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.PreviousSelectionExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.MatrixExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.SelectionGeometryExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ComplexSelectionGeometryExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.StretchExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InternalPolygonExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.JoinExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InsertPolygonExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InsertPolyLineExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InsertLineExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InsertMultiPointExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InsertPointExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.MoveGeometryExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ExploitExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.CADExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableCommandStackExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ViewCommandStackExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.RedoViewExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.UndoViewExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ExportTo...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.StopEditing...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.StartEditing...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.CreateNewLayer...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.annotation
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.tools.annotations.labeling.SingleLabelingExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.Annotation_ToolExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.Annotation_Extension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.gvsig.expressionfield
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ExpressionFieldExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.copypastegeom
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.copypastegeom.PasteFeaturesExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.copypastegeom.CopyFeaturesExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.tableImport
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.tableImport.importfields.ImportFieldsExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.tableImport.addgeominfo.AddGeometricInfoExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.newgeoprocess
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.geoprocess.RegisterGeoprocessExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.quickInfo
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.quickInfo.QuickInfoToolExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.quickInfo.AboutQuickInfoExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.consecutivenumber
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.consecutivenumber.ConsecutiveFieldExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.selectionTools
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.selectionTools.SelectAllExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.selectionTools.SelectByCircleExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.selectionTools.SelectByPolylineExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.selectionTools.SelectByBufferExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.selectionTools.AboutSelectionToolsExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from es.udc.cartolab.gvsig.tocextra
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.udc.cartolab.gvsig.tocextra.TocExtraExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from es.udc.cartolab.gvsig.navtable
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.udc.cartolab.gvsig.navtable.AlphanumericNavTableExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.udc.cartolab.gvsig.navtable.NavTableExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from org.gvsig.gpe
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.gpe.GPEReaderExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.gpe.AboutGPEExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing org.gvsig.gpe.GPEWriterExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.wfs2
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.wfs.WFSClientExtension...
DEBUG AWT-EventQueue-1 com.iver.andami.Launcher - Initializing extensions from es.iver.derivedGeom
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.iver.derivedGeom.AddDerivedGeometrySHPExtension...
INFO AWT-EventQueue-1 com.iver.andami.Launcher - Initializing es.iver.derivedGeom.AboutDerivedGeomExtension...
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/sextante.gif'
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin es.unex.sextante -- Non si é incontrata la traduzione per SEXTANTE Toolbox
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/documenter.png'
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin es.unex.sextante -- Non si é incontrata la traduzione per Data
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/sextante2.gif'
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin es.unex.sextante -- Non si é incontrata la traduzione per SEXTANTE Toolbar
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/model.png'
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin es.unex.sextante -- Non si é incontrata la traduzione per SEXTANTE Modeler
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/terminal.png'
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin es.unex.sextante -- Non si é incontrata la traduzione per SEXTANTE command line
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/history.gif'
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin es.unex.sextante -- Non si é incontrata la traduzione per SEXTANTE History
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/chart.gif'
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin es.unex.sextante -- Non si é incontrata la traduzione per Results
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/bullseye.gif'
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin es.unex.sextante -- Non si é incontrata la traduzione per Catch coordinates
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/view-quick-info-icon.png'
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/contrast.png'
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin it.gisforplanning.tools -- Non si é incontrata la traduzione per Multi Raster Trasparency
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.cit.gvsig.geoprocess -- Non si é incontrata la traduzione per debería de estar activada
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.gvsig.centerviewpoint -- Non si é incontrata la traduzione per debería de estar activada
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/table_refresh.png'
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/test.png'
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin es.udc.cartolab.gvsig.navtable -- Non si é incontrata la traduzione per Test NavTable tablas sueltas
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.gvsig.addeventtheme -- Non si é incontrata la traduzione per debería de estar activada
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/oracle.png'
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/binary.gif'
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/Link.png'
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/select-all-icon.png'
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/create-derivative-geometry-shape-icon.png'
WARN main com.iver.andami.PluginServices - Non si é incontrata la traduzione per creating_main_window
WARN AWT-EventQueue-1 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/enabled.png'
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.core -- Non si é incontrata la traduzione per core
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.core -- Non si é incontrata la traduzione per copy-paste-features
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.core -- Non si é incontrata la traduzione per SEXTANTE
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.core -- Non si é incontrata la traduzione per TRASPARENCY
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.core -- Non si é incontrata la traduzione per NavTable
INFO AWT-EventQueue-1 com.iver.andami.help.Help$DisplayHelpFromFocus - DisplayHelpFromFocus(id) id=Manual-usuario-gvSIG-1.10-Proyectos-de-gvSIG-Introdución
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.core -- Non si é incontrata la traduzione per Gestore di progetto
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.core -- Non si é incontrata la traduzione per Attiva la finestra
DEBUG AWT-EventQueue-1 com.iver.core.mdiManager.NewSkin - Activando Gestore di progetto
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 51085 KB
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Non si é incontrata la traduzione per ArcSDE
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Non si é incontrata la traduzione per GPE
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 69932 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Esegui comando:ABRIR
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 60211 KB
DEBUG AWT-EventQueue-1 com.iver.andami.messages.NotificationManager - Apertura progetto: CATASTO FREGI GRAPPA.gvp
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: ctr10000.shp loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: commont.shp loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: comuni2000.shp loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: Kart.3634 Stellungskarte_particolare.jpg loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083080.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083120.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083160.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 084130.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083030.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083100.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083110.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083040.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083070.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083150.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083060.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083130.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083140.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: NFA 2036,15.Korps.Beabsichtigte Gruppierung in der Königszone Raum der 48 JD.jpg loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: NFA Kt.2037,15.Korps.Verteidigungsplan XIII Blge. 3.jpg loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083090.ecw loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: BL_10000_sud.TIF loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: TV_10000_nord-ovest.TIF loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: VI_10000_nord-est.TIF loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083030.tif loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083040.tif loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083120.tif loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083130.tif loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083100.tif loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083110.tif loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083060.tif loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083070.tif loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083140.tif loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: 083080.tif loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: PERDUTI.shp loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: AUSTRIACI .shp loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: ITALIANI.shp loaded
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.fmap.layers.FLayers - layer: FRANCESI.shp loaded
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 75518 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 76198 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 76370 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 76974 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 77149 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 77734 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 77833 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 77941 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 78587 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 78721 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 79343 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 79514 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 68401 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 70310 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 70465 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 71155 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 73290 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 73581 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 74343 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 74406 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 74557 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 74720 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 75470 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 75576 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 75727 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 76481 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 76569 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 76776 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 77470 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 77553 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 78320 KB
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.core -- Non si é incontrata la traduzione per Mappa : prova
DEBUG AWT-EventQueue-1 com.iver.core.mdiManager.NewSkin - Activando Mappa : prova
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 79557 KB
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Non si é incontrata la traduzione per Centimetri
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.core -- Non si é incontrata la traduzione per Mappa : prova tavola.gvt
DEBUG AWT-EventQueue-1 com.iver.core.mdiManager.NewSkin - Activando Mappa : prova tavola.gvt
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 80175 KB
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.core -- Non si é incontrata la traduzione per Vista : CATASTO FREGI GRAPPA
DEBUG AWT-EventQueue-1 com.iver.core.mdiManager.NewSkin - Activando Vista : CATASTO FREGI GRAPPA
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 85514 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 86132 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 86750 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 92421 KB
WARN AWT-EventQueue-1 es.prodevelop.cit.gvsig.arcims.gui.panels.ServiceNamesPanel - Property 'arcims-servers' not found in XML file.
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 92548 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 75324 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 77545 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 78564 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 80574 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 82093 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Esegui comando:ZOOM_OUT
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.ViewControls - Comand : ZOOM_OUT
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 82780 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 83575 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 81707 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 77624 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Esegui comando:ZOOM_IN
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.ViewControls - Comand : ZOOM_IN
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 78306 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 79374 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 80527 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 80492 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 80596 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 81444 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 73175 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 80232 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 79880 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 83215 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 87190 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 80031 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 81543 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Esegui comando:PAN
DEBUG AWT-EventQueue-1 com.iver.cit.gvsig.ViewControls - Comand : PAN
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 86687 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 86787 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 88510 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 85572 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 90312 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 85318 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 78164 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 78248 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 79185 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 80234 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 84401 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 84456 KB
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 85893 KB
DEBUG Thread-42 com.iver.andami.messages.NotificationManager - Can´t read the driver:
    at org.gvsig.fmap.raster.layers.FLyrRasterSE.draw(FLyrRasterSE.java:656)
    at com.iver.cit.gvsig.fmap.DefaultMapContextDrawer.draw(DefaultMapContextDrawer.java:209)
    at com.iver.cit.gvsig.fmap.DefaultMapContextDrawer.draw(DefaultMapContextDrawer.java:175)
    at com.iver.cit.gvsig.fmap.MapContext.draw(MapContext.java:1097)
    at com.iver.cit.gvsig.fmap.MapControl$PaintingRequest.paint(MapControl.java:1043)
    at com.iver.cit.gvsig.fmap.MapControl$Drawer2$Worker.run(MapControl.java:1234)
    at java.lang.Thread.run(Unknown Source)
Caused by: org.gvsig.raster.dataset.io.RasterDriverException: Error reading data
    at org.gvsig.raster.dataset.io.GdalDriver.getWindowRaster(GdalDriver.java:316)
    at org.gvsig.raster.dataset.MultiRasterDataset.getWindowRaster(MultiRasterDataset.java:446)
    at org.gvsig.raster.buffer.BufferFactory.setAreaOfInterest(BufferFactory.java:294)
    at org.gvsig.raster.grid.render.Rendering.draw(Rendering.java:274)
    at org.gvsig.fmap.raster.layers.FLyrRasterSE.draw(FLyrRasterSE.java:688)
    at org.gvsig.fmap.raster.layers.FLyrRasterSE.draw(FLyrRasterSE.java:654)
    ... 6 more
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Plugin com.iver.core -- Non si é incontrata la traduzione per Console di informazione
DEBUG AWT-EventQueue-1 com.iver.core.mdiManager.NewSkin - Activando Console di informazione
DEBUG AWT-EventQueue-1 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 108459 KB
WARN AWT-EventQueue-1 com.iver.andami.PluginServices - Non si é incontrata la traduzione per writinng_project
DEBUG AWT-EventQueue-1 com.iver.andami.messages.NotificationManager - writinng_project: CATASTO FREGI GRAPPA.gvp
DEBUG AWT-EventQueue-1 com.iver.andami.messages.NotificationManager - Progetto salvato: CATASTO FREGI GRAPPA.gvp
INFO AWT-EventQueue-1 com.iver.cit.gvsig.ProjectExtension - Project saved. 204 miliseconds
INFO AWT-EventQueue-1 com.iver.cit.gvsig.fmap.drivers.db.utils.SingleVectorialDBConnectionManager - Successfully closed all connections.
Un allegato HTML è stato rimosso...
URL: <http://lists.osgeo.org/pipermail/gvsig-italian/attachments/20120703/6337eb3e/attachment.html>
More information about the Gvsig_italian mailing list
