[iTowns-user] Showing a point cloud on top of wms imagery [iTownsV2]
Chris Lucas chris.lucas at geodan.nl
Wed Aug 23 03:14:01 PDT 2017
Hello,
I am trying to view a point cloud on top of wms imagery in iTowns2. Both
data is loaded, but the imagery is blocking the point cloud (see
screenshots at:
https://drive.google.com/file/d/0B_iWdvcnZj81UE9vaVI3NnUxZGs/view?usp=sharing
and
https://drive.google.com/file/d/0B_iWdvcnZj81OEhDUU1HeDNOa1U/view?usp=sharing).
Is there a way to put the imagery properly under the point cloud?
I tried loading the point cloud and imagery in different order and
enabling/disabling skirt of tilelayer, but no luck.
I am using windows 10 with Chrome version 60.0.3112.101 (Official Build)
(64-bit) and this is the code I'm using:
var viewerDiv = document.getElementById('viewerDiv');
viewerDiv.style.display = 'block';
itowns.THREE.Object3D.DefaultUp.set(0, 0, 1);
itowns.proj4.defs('EPSG:28992', '+proj=sterea +lat_0=52.15616055555555
+lon_0=5.38763888888889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel
+units=m +no_defs');
var extent = new itowns.Extent(
    'EPSG:28992',
    149260.453, 149555.000,
    410619.451, 410908.357
var view = new itowns.View('EPSG:28992', viewerDiv, {
logarithmicDepthBuffer: true });
view.mainLoop.gfxEngine.renderer.setClearColor(0xcccccc);
var debugGui = new dat.GUI();
var tileLayer = itowns.createPlanarLayer("Ortho", extent, {object3d:
view.scene})
tileLayer.disableSkirt = true;
view.addLayer(tileLayer);
view.addLayer({
    update: itowns.updateLayeredMaterialNodeImagery,
    url: 'https://geodata.nationaalgeoregister.nl/luchtfoto/rgb/wms',
    networkOptions: { crossOrigin: 'anonymous' },
    type: 'color',
    protocol: 'wms',
    version: '1.3.0',
    projection: 'EPSG:28992',
    transparent: false,
    extent: extent,
    axisOrder: 'wsen',
    options: {
        mimetype: 'image/jpeg',
}, tileLayer);
function showPointcloud(serverUrl, fileName, table) {
    var pointcloud;
    var oldPostUpdate;
    var controls;
    // Configure Point Cloud layer
    pointcloud = new itowns.GeometryLayer('pointcloud', view.scene);
    pointcloud.file = fileName || 'infos/sources';
    pointcloud.protocol = 'potreeconverter';
    pointcloud.url = serverUrl;
    pointcloud.table = table;
    function placeCamera(position, lookAt) {
        view.camera.camera3D.position.set(position.x, position.y,
position.z);
        view.camera.camera3D.lookAt(lookAt);
        // create controls
        controls = new itowns.FirstPersonControls(view, { focusOnClick:
true });
        debugGui.add(controls, 'moveSpeed', 1, 100).name('Movement speed');
        view.notifyChange(true);
    // add pointcloud to scene
    function onLayerReady() {
        var ratio;
        var position;
        var lookAt;
        debug.PointCloudDebug.initTools(view, pointcloud, debugGui);
        view.camera.camera3D.far = 2.0 *
pointcloud.root.bbox.getSize().length();
        ratio = pointcloud.root.bbox.getSize().x /
pointcloud.root.bbox.getSize().z;
        position = pointcloud.root.bbox.min.clone().add(
            pointcloud.root.bbox.getSize().multiply({ x: 0, y: 0, z: ratio
* 0.5 }));
        lookAt = pointcloud.root.bbox.getCenter();
        lookAt.z = pointcloud.root.bbox.min.z;
        placeCamera(position, lookAt);
        controls.moveSpeed = pointcloud.root.bbox.getSize().length() / 3;
        // update stats window
        oldPostUpdate = pointcloud.postUpdate;
        pointcloud.postUpdate = function postUpdate() {
            var info = document.getElementById('info');
            oldPostUpdate.apply(pointcloud, arguments);
            info.textContent = 'Nb points: ' +
                pointcloud.counters.displayedCount.toLocaleString() + ' (' +
                Math.floor(100 * pointcloud.counters.displayedCount /
pointcloud.counters.pointCount) + '%) (' +
                view.mainLoop.gfxEngine.renderer.info.memory.geometries +
    view.addLayer(pointcloud).then(onLayerReady);
showPointcloud("http://localhost:8000/iTownsViewer/data", "cloud.js",
undefined, true);
Any help would be welcome.
Regards,
Chris Lucas
URL: <http://lists.osgeo.org/pipermail/itowns-user/attachments/20170823/4c3aa124/attachment.html>
More information about the ITowns-user mailing list
