[Java-collab] News on GeoServer supporting GDAL (Simplified steps).
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Tue Jun 3 06:14:00 EDT 2008
Hi lists,
we have slightly simplified the procedure for testing the unofficial
GeoServer release supporting GDAL through ImageIO-Ext. (A GeoServer version
supporting MrSID, JP2K (MrSID), JP2K (Kakadu), DTED, Erdas Imagine, NITF
Format).
The new release is available at
http://www.geo-solutions.it/libraries/geoserver-1.7.0-SNAPSHOT-war.zip.
We have set a simple guide with instructions and links to test the release.
This guide is available as:
HTML: http://www.geo-solutions.it/doc/geoservergdal.html
PDF: http://www.geo-solutions.it/doc/geoservergdal.pdf
OpenOffice Doc: http://www.geo-solutions.it/doc/geoservergdal.odt
Before testing GeoServer, be sure you have read the section "Some notes on
the GeoServer usage" on the ImageIO-EXT-GDAL WIKI page:
http://docs.codehaus.org/display/GEOTOOLS/ImageIO-EXT+GDAL#ImageIO-EXTGDAL-SomenotesontheGeoServerusage%26nbsp%3B
Finally, note that due to licensing issues, the available dynamic libraries
enable support for MrSID, JP2K (MrSID), DTED, Erdas Imagine, NITF formats.
If you need to add support to JP2K (Kakadu) and ECW, see instructions
available at http://www.geo-solutions.it/doc/ImageioExt-SetupGuide.odt(OpenOffice)
or
http://www.geo-solutions.it/doc/ImageioExt-SetupGuide.pdf (PDF), sections
"GDAL Requirements" and "GDAL Configurations" for further information on
enabling ECW and Kakadu support on GDAL. For further helps on this topic,
ask questions.
Regards,
Daniele
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
URL: http://lists.osgeo.org/pipermail/java-collab/attachments/20080603/7a2dcc73/attachment.html
More information about the Java-collab mailing list
