[Java-collab] SLD
Stefan Steiniger sstein at geo.uzh.ch
Thu May 22 16:12:49 EDT 2008
On the SLD,
I like to refer to this thread on OpenJUMP devel list and my forward to
this list (was unfortunately the first email here):
first mail thread:
http://www.mail-archive.com/jump-pilot-devel@lists.sourceforge.net/msg04706.html
2nd mail: (unfortunately this one got lost in the archives.. so I attach
it completely: I don't attach the additional zip file due to the mail
filters but I can send it on request)
stefan
-------- Original Message --------
Subject: [JPP-Devel]  2nd test on SLD import/export OpenJUMP, Kosmo, uDig
Date: Sun, 18 May 2008 12:26:12 +0200 (CEST)
Reply-To: OpenJump develop and use <jump-pilot-devel at lists.sourceforge.net>
I did a test on Andreas' job about import/export SLD.
Hi all
I tested OpenJUMP, Kosmo and uDig on saving/opening
SLD files between each other (Kosmo only save to SLD).
This is the second test to verify Andreas's work
I used the same file (Italian_region.shp) for the 3
softwares. For each I defined the following features
on the style:
-Fill by range
-Fill by attribute
-Fill type
-Line color
-Line type
-Line width
-Text font
-Text color
-Text Dimension
-Halo
-Text position
And save different SLD files
These are the resaults:
a) OpenJUMP can easly open Kosmo SLD. It imports
everything except fill type and halo.
Sometimes it cannot import the correct position of the
Text
b) OpenJUMP opens uDig SLD but it doesn't import the
correct fill colour (depends to syntax of SLD, see
later). OK for text, text color, font and  and font
dimension.
c) uDig import correctly everything from Kosmo SLD,
included features that uDig still doesn't have, like
fill and line type and halo.
d) uDig doesn't import OpenJUMP SLD.
When I load in uDig a SLD file from OpenJUMP, the
screen turns to white
(I think this depends to different syntax of SLD
files (open SLD with a text edirtor to see it)
e) Kosmo has no SLD import, right now
You can see a better deatil on a EXCEL file attached
to this mail. I also attached the shapefile I used for
the test and the SLD files. (in TEST_ON_SLD.ZI(P))
Regards
Peppe
Jody Garnett wrote:
> erwan bocher wrote:
>> Currently we are working with Suisse guys (Olivier Ertz team) about
>> styling and symbology model for thematic maping, OGC compliant (SLD-
>> Thematic). Olivier will subscribe to this list.
> Sounds good; Olivier may be better served by either of:
> - the osgeo standards list (where kick around standards and try and make
> them work)
> - the geoapi project (where they are currently looking at moving to the
> Symbology Encoding standard; previously known as SLD 1.1).
> But others on this list will know more about this work...
> Jody
> Java-collab mailing list
> Java-collab at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/java-collab
More information about the Java-collab mailing list
