[Java-collab] Simple Text Exchange Format
Francisco José Peñarrubia fjp at scolab.es
Wed May 28 04:17:58 EDT 2008
Andreas Schmitz escribió:
>> 3.- If you include an index file (for example, longs with the position
>> in file where each record starts, it may allow you to spatially index
>> the file, random access and edit each record without rewriting the whole
>> file. Even to set a order (to put a feature below other, for example).
> I'm not sure about the random access (it's a text file, with various line
> lengths, which makes this hard to do).
> On another note: please make the used reference system mandatory as well (I like
> your use of QNames here) ;-)
> Best regards, Andreas
You are right, can't edit without rewriting the whole file, but random
access is possible. Same behaviour that shape files.
Cheers.
More information about the Java-collab mailing list
