[Geotools-devel] [Java-collab] Multidimensional coverage and vertical extent
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Fri May 30 07:27:01 EDT 2008
Hi Martin,
On Fri, May 30, 2008 at 1:14 PM, Martin Desruisseaux <
martin.desruisseaux at geomatys.fr> wrote:
> Daniele Romagnoli a écrit :
> > How can I handle this special vertical level? (Since, I need to define
> > a Vertical CRS... which vertical datum?)
> For stuff like "depth in meters below sea level" and "isobaric level",
> there is
> existing VerticalDatumType that can be used for creating VerticalDatum
> instances:
> http://geoapi.sourceforge.net/snapshot/javadoc/org/opengis/referencing/datum/VerticalDatumType.html#DEPTH
Yes, I noticed that. But in these specials GRIB records there is no
knowledge about an "offset" from a reference level.
> <http://geoapi.sourceforge.net/snapshot/javadoc/org/opengis/referencing/datum/VerticalDatumType.html#DEPTH>
> For heights relative to cloud level, an application needs to defines new
> VerticalDatumType using the static valueOf(String) method.
> > In the case of a level such as "Cloud Top Level" or "Cloud Base Level"
> > is there a special way to define "its position with respect to the
> > Earth"?
> Not at this time. ISO 19111 do not suggests any programmatic way, only
> textual
> way, probably because the relationship is often quite complex. For example
> defining the position of VerticalDatumType.GEOIDAL with respect to
> VerticalDatumType.ELLIPSOIDAL is the subject of a whole GeoTools module on
> its
> own: modules/unsupported/referencing3D.
Yeah, I looked at this on the nice VerticalTransform class + its subclass :)
> GeoTools referencing module lacks a way to plugin vertical transformations
> at
> this time.
>        Martin
Daniele
> This SF.net email is sponsored by: Microsoft
> Defy all challenges. Microsoft(R) Visual Studio 2008.
> http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> Geotools-devel mailing list
> Geotools-devel at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geotools-devel
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/java-collab/attachments/20080530/41e93a9e/attachment.html
More information about the Java-collab mailing list
