[Java-collab] Some Thoughts
Stefan Steiniger sstein at geo.uzh.ch
Mon Apr 27 13:46:16 EDT 2009
- what is a "route addressing" library?
do you mean routing or geocoding (postcode versus real coordinates) or a
combined thing
- on the dxf thing: you know that there are at least 2 dxf drivers out
there for OpenJUMP. One, I think, is build on proprietarry library.
stefan
Sunburned Surveyor wrote:
> This list has been pretty quiet since its inception. I wanted to send
> a brief update:
> - I cleaned up the OSGeo wiki page found here:
> http://wiki.osgeo.org/wiki/Java_GIS_Collaboration
> - JTIN (a Java library for working with TIN data) is currently found
> at the JUMP Pilot Project SVN. We got funded for another summer of
> work on the library (via Google’s Summer of Code) and hope to
> integrate it as part of degree 2.
> - I’ve got a library for parsing GPX data that is available under the
> LGPL and is currently an unsupported module in Geotools. This code
> supports the basics of reading GPX files, but there is a lot of room
> for improvement.
> - My Google Summer of Code student recently pointed out the Kabeja
> library that can be used for reading DXF files. I’ve been in contact
> with the developer, who seems to be a friendly guy. This seems like a
> good library to support the DXF format in Java GIS applications. Right
> now it appears to read the whole document into RAM, like DOM, but this
> could be fixed. I thought I would share the information about the
> library with other programmers on this list:
> http://kabeja.sourceforge.net/
> - I will need to do write some code this summer on a route addressing
> library for a project at my day job. I would like to make this an
> unsupported module in Geotools as well. Let me know if you are
> interested in working together on this.
> Landon
> Java-collab mailing list
> Java-collab at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/java-collab
More information about the Java-collab mailing list
