[Java-collab] Open Street Map XML library?
Jorge Gaspar Sanz Salinas jsanz at osgeo.org
Wed Apr 29 13:28:01 EDT 2009
2009/4/27 Sunburned Surveyor <sunburned.surveyor at gmail.com>:
> I’m trying to work with some Open Street Map data in OpenJUMP. I need
> to code a reader and writer for the OSM XML file format. Is anyone
> done any work with this file format that they would be willing to
> share?
> Thanks,
> Landon
> Java-collab mailing list
> Java-collab at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/java-collab
Sorry, I sent this message off-list accidentally (the old
reply-replyall behaviour). This is a collaboration list after all :-)
Landon,
At gvSIG, Luis Sevilla developed a prototype driver[1] to read OSM
files. Probably you can adapt it to your feature model easyly. No
writer was debeloped (and I think this could be a hard work by the way
OSM data works with tags and so on)
On the other hand, why not transform to GML and use any other reader?
Good luck!
[1] https://forge.osor.eu/projects/gvsig-poc/
Ingeniero en Geodesia y Cartografía
http://wiki.osgeo.org/wiki/Jorge_Sanz
More information about the Java-collab mailing list
