[Java-collab] CRS axis issues (Was: Introduction and a few suggestions on recent topics)
Markus Schneider schneider at lat-lon.de
Fri Aug 21 05:53:15 EDT 2009
Hi Martin,
Martin Desruisseaux wrote:
> 3) We could imagine a new sub-interfaces, said DirectPositionXYZ, which
>    impose the new constraint that the CRS must have its first axis
>    orientated toward east, the second axis orientated toward north, and
>    the third axis (if any) orientated toward up. Attempts to assign an
>    other kind of CRS to a DirectPositionXYZ throws IllegalArgumentException
>    at construction time. This DirectPositionXYZ interface would have the
>    getX(), getY(), getZ() methods.
Interesting idea. On the other hand, this would introduce even more levels to the geometry type hierarchy...
> 4) The most efficient way to handle the axis order issue in a
>    GeoTools/Geotk-like implementation is to impose the desired order right
>    at the CRS creation time. Rather than having DirectPosition accepting
>    arbitrary axis order and have its getX()/getY() methods perform analysis
>    on the CRS axes, it is better to let the referencing module provides the
>    MathTransform from the arbitrary CRS to the "XYZ-ordered" CRS.
>    Advantages:
>      * This avoid duplication of code since the referencing module
>        already performs analysis of axes when infering MathTransform.
>      * A MathTransform performing axes swapping is an AffineTransform.
>        AffineTransforms can be efficiently concatenated with other kind
>        of conversions like unit conversions or "scaling", "false easting",
>        "false northing" after a map projection. Consequently in many cases
>        the cost of performing axis swapping is absolutly null, because
>        we just updated the coefficients of an affine transform that
>        would have been applied anyway.
> 5) The MathTransform interface defines the following method:
>    DirectPosition transform(DirectPosition source, DirectPosition target);
>    where target is an optionnaly pre-allocated object (this is exactly
>    the same approach than java.awt.geom.AffineTransform, but lets forget
>    that for now). For now lets assume that "target" is null, which means
>    than MathTransform will return a newly allocated object. In the
>    particular case where the target CRS is one having XYZ axis order,
>    MathTransform could return a DirectPositionXYZ object.
>    Advantage:
>    * User can know if he is allowed to use the getX(), getY() methods
>      by performing an "if (p instanceof DirectPositionXYZ)" check.
>    * The check proposed by Mathias (where getX() throw an exception
>      if the point doesn't have a legal CRS) is replaced by a cast to
>      DirectPositionXYZ, which throw a ClassCastException if we are
>      not allowed to. The advantage is that this check is performed
>      only once for the DirectPosition as a whole, instead than for
>      each individual ordinate.
> In summary this approach is:
> * Type safe, since the getX() / getY() methods are defined only
>   in an sub-interface where the meaning of those methods is
>   garanteed to be the expected one. This allow API who want
>   a XYZ position to enforce this restriction in their method
>   signature.
> * Highly performant, since 1) in a majority of cases the axis
>   swapping has been concatenated in an affine transform
>   which already existed anyway, and 2) the check for validity
>   of getX() / getY() method call is performed only once for
>   the DirectPosition as a whole (and is not performed any more
>   once we have casted to DirectPositionXYZ), instead than every
>   time a get[X|Y] method is invoked.
These are very interesting approaches for providing an efficient implementation and correct behaviour for CRS-aware
#getX() and #getY() methods.
I would like to come back to these issues after we achieved the interim goal of having working test cases based on GML
import/export. I guess we only need the getter methods based on the ordinate index up to this point, but not any
axis-awareness.
Best regards,
Markus
Markus Schneider
l a t / l o n  GmbH
Aennchenstrasse 19           53177 Bonn, Germany
phone ++49 +228 184960       fax ++49 +228 1849629
http://www.lat-lon.de        http://www.deegree.org
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/java-collab/attachments/20090821/b2ad2db8/signature.bin
More information about the Java-collab mailing list
