[Java-collab] OSGeom code initiation
Vincent Heurteaux vincent.heurteaux at geomatys.fr
Wed Jul 29 06:34:45 EDT 2009
Salut Ben,
Thank's for your answer.
On our side we'll be involved on GeoAPI, ISO10107 and it's evolutions.
GML and ISO19107 are really close, so Im sure we could have some
exchange around API in the future.
As you pointed, there are underlying tensions, then I gess it will be
difficult for us to collaborate on OSGeom, and we'll continue our
implementation on Geotoolkit as we planed first.
On your side (the community not only you), feel free to come to us if
you have whatever questions, we're open minded, and all for
collaboration.
Cheers,
Vincent
Le 29 juil. 09 à 05:24, Ben Caradoc-Davies a écrit :
> Axel FRANCOIS wrote:
>> >I think we are focusing on GML this time around; you are welcome to
>> >wrap the result in GeoAPI wrappers if you like.
>> >Jody
>> Do you mean that the project scope is restricted to GML parsing
>> and  formatting without geometry operations,
> No.
>> or do you mean that the model  for geometric objects is the GML
>> model?
> Yes. We need the geometry operations. The GML spec has more support
> here because it is open.
>> In the later case GML and ISO  19107 are the same thing, so my
>> question still applies ?
> I think Jody's answer still applies: it should be straightforward to
> wrap/adapt to make the new geometry code work with GeoAPI.
> You are opening a can of worms (bag of crabs, I believe, en
> francais). GeoAPI has not been as widely adopted as was once hoped,
> and I do not think there is support for basing the new geometry
> module on it. There are other off-topic issues, and the more
> diplomatic members are (in my view) avoiding discussing them on this
> list.
> Axel, your thesis project sounds very closely aligned with the
> general direction of the new geometry module. I welcome your
> involvement.
> Kind regards,
> Ben Caradoc-Davies <Ben.Caradoc-Davies at csiro.au>
> Software Engineer, CSIRO Exploration and Mining
> Australian Resources Research Centre
> 26 Dick Perry Ave, Kensington WA 6151, Australia
> Java-collab mailing list
> Java-collab at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/java-collab
More information about the Java-collab mailing list
