[Java-collab] Open Street Map XML library?
Stefan Steiniger sstein at geo.uzh.ch
Fri May 1 17:19:44 EDT 2009
Hei Jorge,
thanks for the hint... I'll have a look into it.
As I was thinking about going to the OSM conference and maybe tell them
something about free GIS that could be used for OSM purposes.
So.. as far as I see it would be gvSIG, QGIS and OpenJUMP.
However - I need to decide by tomorrow if I can get the necessary
material (deadline for talk proposals) and find time to go from OGRS
2009 in Nantes to Amsterdam in only day.
stefan
Jorge Gaspar Sanz Salinas wrote:
> 2009/4/27 Sunburned Surveyor <sunburned.surveyor at gmail.com>:
>> I’m trying to work with some Open Street Map data in OpenJUMP. I need
>> to code a reader and writer for the OSM XML file format. Is anyone
>> done any work with this file format that they would be willing to
>> share?
>> Thanks,
>> Landon
>> Java-collab mailing list
>> Java-collab at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/java-collab
> Sorry, I sent this message off-list accidentally (the old
> reply-replyall behaviour). This is a collaboration list after all :-)
> Landon,
> At gvSIG, Luis Sevilla developed a prototype driver[1] to read OSM
> files. Probably you can adapt it to your feature model easyly. No
> writer was debeloped (and I think this could be a hard work by the way
> OSM data works with tags and so on)
> On the other hand, why not transform to GML and use any other reader?
> Good luck!
> [1] https://forge.osor.eu/projects/gvsig-poc/
More information about the Java-collab mailing list
