[Liblas-commits] r1234 - in trunk: . m4
liblas-commits at liblas.org liblas-commits at liblas.org
Sat Apr 18 00:05:34 EDT 2009
Author: hobu
Date: Sat Apr 18 00:05:34 2009
New Revision: 1234
URL: http://liblas.org/changeset/1234
store macros instead of pointing externally
Added:
   trunk/m4/
   trunk/m4/ax_lib_oracle_oci.m4
   trunk/   (props changed)
   trunk/autogen.sh
Modified: trunk/autogen.sh
--- trunk/autogen.sh	(original)
+++ trunk/autogen.sh	Sat Apr 18 00:05:34 2009
@@ -26,8 +26,8 @@
    AMFLAGS=$AMFLAGS" --include-deps";
 fi
-echo "Running aclocal -I macros"
-aclocal -I macros || giveup
+echo "Running aclocal -I m4"
+aclocal -I m4 || giveup
 #echo "Running autoheader"
 #autoheader || giveup
 echo "Running libtoolize"
Added: trunk/m4/ax_lib_oracle_oci.m4
--- (empty file)
+++ trunk/m4/ax_lib_oracle_oci.m4	Sat Apr 18 00:05:34 2009
@@ -0,0 +1,298 @@
+dnl @synopsis AX_LIB_ORACLE_OCI([MINIMUM-VERSION])
+dnl
+dnl @summary Find Oracle OCI API.
+dnl
+dnl This macro provides tests of availability of Oracle OCI API of
+dnl particular version or newer. This macros checks for Oracle OCI
+dnl headers and libraries and defines compilation flags.
+dnl
+dnl Macro supports following options and their values:
+dnl
+dnl 1) Single-option usage:
+dnl
+dnl     --with-oci         -- path to ORACLE_HOME directory
+dnl
+dnl 2) Two-options usage (both options are required):
+dnl
+dnl     --with-oci-include -- path to directory with OCI headers
+dnl     --with-oci-lib     -- path to directory with OCI libraries
+dnl
+dnl NOTE: These options described above do not take yes|no values. If
+dnl 'yes' value is passed, then WARNING message will be displayed, 'no'
+dnl value, as well as the --without-oci-* variations will cause the
+dnl macro to not check enything.
+dnl
+dnl This macro calls:
+dnl
+dnl   AC_SUBST(ORACLE_OCI_CFLAGS)
+dnl   AC_SUBST(ORACLE_OCI_LDFLAGS)
+dnl   AC_SUBST(ORACLE_OCI_VERSION)
+dnl
+dnl And sets:
+dnl
+dnl   HAVE_ORACLE_OCI
+dnl
+dnl @category InstalledPackages
+dnl @category Cxx
+dnl @author Mateusz Loskot <mateusz at loskot.net>
+dnl @version 2007-11-30
+dnl @license AllPermissive
+AC_DEFUN([AX_LIB_ORACLE_OCI],
+    AC_ARG_WITH([oci],
+        AC_HELP_STRING([--with-oci=@<:@ARG@:>@],
+            [use Oracle OCI API from given Oracle home (ARG=path); use existing ORACLE_HOME (ARG=yes); disable Oracle OCI support (ARG=no)]
+        if test "$withval" = "yes"; then
+            if test -n "$ORACLE_HOME"; then
+                oracle_home_dir="$ORACLE_HOME"
+            else
+                oracle_home_dir=""
+            fi
+        elif test -d "$withval"; then
+            oracle_home_dir="$withval"
+        else
+        fi
+        else
+        fi
+    AC_ARG_WITH([oci-include],
+        AC_HELP_STRING([--with-oci-include=@<:@DIR@:>@],
+            [use Oracle OCI API headers from given path]
+        [oracle_home_include_dir="$withval"],
+        [oracle_home_include_dir=""]
+    AC_ARG_WITH([oci-lib],
+        AC_HELP_STRING([--with-oci-lib=@<:@DIR@:>@],
+            [use Oracle OCI API libraries from given path]
+        [oracle_home_lib_dir="$withval"],
+        [oracle_home_lib_dir=""]
+    ORACLE_OCI_CFLAGS=""
+    ORACLE_OCI_LDFLAGS=""
+    ORACLE_OCI_VERSION=""
+    dnl
+    dnl Collect include/lib paths
+    dnl
+    want_oracle_but_no_path="no"
+    if test -n "$oracle_home_dir"; then
+        if test "$oracle_home_dir" != "no" -a "$oracle_home_dir" != "yes"; then
+            dnl ORACLE_HOME path provided
+            dnl Primary path to OCI headers, available in Oracle>=10
+            oracle_include_dir="$oracle_home_dir/rdbms/public"
+            dnl Secondary path to OCI headers used by older versions
+            oracle_include_dir2="$oracle_home_dir/rdbms/demo"
+            dnl Library path
+            oracle_lib_dir="$oracle_home_dir/lib"
+        elif test "$oracle_home_dir" = "yes"; then
+            want_oracle_but_no_path="yes"
+        fi
+    elif test -n "$oracle_home_include_dir" -o -n "$oracle_home_lib_dir"; then
+        if test "$oracle_home_include_dir" != "no" -a "$oracle_home_include_dir" != "yes"; then
+            oracle_include_dir="$oracle_home_include_dir"
+        elif test "$oracle_home_include_dir" = "yes"; then
+        fi
+        if test "$oracle_home_lib_dir" != "no" -a "$oracle_home_lib_dir" != "yes"; then
+            oracle_lib_dir="$oracle_home_lib_dir"
+        elif test "$oracle_home_lib_dir" = "yes"; then
+        fi
+    fi
+    if test "$want_oracle_but_no_path" = "yes"; then
+        AC_MSG_WARN([Oracle support is requested but no Oracle paths have been provided. \
+Please, locate Oracle directories using --with-oci or \
+--with-oci-include and --with-oci-lib options.])
+    fi
+    dnl
+    dnl Check OCI files
+    dnl
+    if test -n "$oracle_include_dir" -a -n "$oracle_lib_dir"; then
+        saved_CPPFLAGS="$CPPFLAGS"
+        CPPFLAGS="$CPPFLAGS -I$oracle_include_dir"
+        dnl Additional path for older Oracle installations
+        if test -n "$oracle_include_dir2"; then
+            CPPFLAGS="$CPPFLAGS -I$oracle_include_dir2"
+        fi
+        dnl Depending on later Oracle version detection,
+        dnl -lnnz10 flag might be removed for older Oracle < 10.x
+        saved_LDFLAGS="$LDFLAGS"
+        oci_ldflags="-L$oracle_lib_dir -lclntsh"
+        LDFLAGS="$LDFLAGS $oci_ldflags"
+        dnl
+        dnl Check OCI headers
+        dnl
+        AC_MSG_CHECKING([for Oracle OCI headers in $oracle_include_dir])
+        AC_LANG_PUSH(C++)
+        AC_COMPILE_IFELSE([
+            AC_LANG_PROGRAM([[@%:@include <oci.h>]],
+#if defined(OCI_MAJOR_VERSION)
+#if OCI_MAJOR_VERSION == 10 && OCI_MINOR_VERSION == 2
+// Oracle 10.2 detected
+#endif
+#elif defined(OCI_V7_SYNTAX)
+// OK, older Oracle detected
+// TODO - mloskot: find better macro to check for older versions;
+#else
+#  error Oracle oci.h header not found
+#endif
+            ORACLE_OCI_CFLAGS="-I$oracle_include_dir"
+                ORACLE_OCI_CFLAGS="$ORACLE_OCI_CFLAGS -I$oracle_include_dir2"
+            fi
+            oci_header_found="yes"
+            AC_MSG_RESULT([yes])
+            oci_header_found="no"
+            AC_MSG_RESULT([not found])
+        AC_LANG_POP([C++])
+        dnl
+        dnl Check OCI libraries
+        dnl
+        if test "$oci_header_found" = "yes"; then
+            AC_MSG_CHECKING([for Oracle OCI libraries in $oracle_lib_dir])
+            AC_LANG_PUSH(C++)
+            AC_LINK_IFELSE([
+OCIEnv* envh = 0;
+OCIEnvCreate(&envh, OCI_DEFAULT, 0, 0, 0, 0, 0, 0);
+if (envh) OCIHandleFree(envh, OCI_HTYPE_ENV);
+                ORACLE_OCI_LDFLAGS="$oci_ldflags"
+                oci_lib_found="yes"
+                oci_lib_found="no"
+        fi
+        CPPFLAGS="$saved_CPPFLAGS"
+        LDFLAGS="$saved_LDFLAGS"
+    fi
+    dnl
+    dnl Check required version of Oracle is available
+    dnl
+    oracle_version_req=ifelse([$1], [], [], [$1])
+    if test "$oci_header_found" = "yes" -a "$oci_lib_found" = "yes" -a \
+        -n "$oracle_version_req"; then
+        oracle_version_major=`cat $oracle_include_dir/oci.h \
+                             | grep '#define.*OCI_MAJOR_VERSION.*' \
+                             | sed -e 's/#define OCI_MAJOR_VERSION  *//' \
+                             | sed -e 's/  *\/\*.*\*\///'`
+        oracle_version_minor=`cat $oracle_include_dir/oci.h \
+                             | grep '#define.*OCI_MINOR_VERSION.*' \
+                             | sed -e 's/#define OCI_MINOR_VERSION  *//' \
+        AC_MSG_CHECKING([if Oracle OCI version is >= $oracle_version_req])
+        if test -n "$oracle_version_major" -a -n $"oracle_version_minor"; then
+            ORACLE_OCI_VERSION="$oracle_version_major.$oracle_version_minor"
+            dnl Decompose required version string of Oracle
+            dnl and calculate its number representation
+            oracle_version_req_major=`expr $oracle_version_req : '\([[0-9]]*\)'`
+            oracle_version_req_minor=`expr $oracle_version_req : '[[0-9]]*\.\([[0-9]]*\)'`
+            oracle_version_req_number=`expr $oracle_version_req_major \* 1000000 \
+                                       \+ $oracle_version_req_minor \* 1000`
+            dnl Calculate its number representation
+            oracle_version_number=`expr $oracle_version_major \* 1000000 \
+                                  \+ $oracle_version_minor \* 1000`
+            oracle_version_check=`expr $oracle_version_number \>\= $oracle_version_req_number`
+            if test "$oracle_version_check" = "1"; then
+                oracle_version_checked="yes"
+                dnl Add -lnnz10 flag to Oracle >= 10.x
+                AC_MSG_CHECKING([for Oracle version >= 10.x to use -lnnz10 flag])
+                oracle_nnz10_check=`expr $oracle_version_number \>\= 10 \* 1000000`
+                if test "$oracle_nnz10_check" = "1"; then
+                    ORACLE_OCI_LDFLAGS="$ORACLE_OCI_LDFLAGS -lnnz$oracle_version_major"
+                else
+                    AC_MSG_RESULT([no])
+                fi
+            else
+                oracle_version_checked="no"
+                AC_MSG_ERROR([Oracle $ORACLE_OCI_VERSION found, but required version is $oracle_version_req])
+            fi
+        else
+            ORACLE_OCI_VERSION="UNKNOWN"
+            AC_MSG_WARN([Oracle version unknown, probably OCI older than 10.2 is available])
+        fi
+    fi
+    AC_MSG_CHECKING([if Oracle support is enabled])
+    if test "$oci_header_found" = "yes" -a "$oci_lib_found" = "yes"; then
+        AC_SUBST([ORACLE_OCI_VERSION])
+        AC_SUBST([ORACLE_OCI_CFLAGS])
+        AC_SUBST([ORACLE_OCI_LDFLAGS])
+        HAVE_ORACLE_OCI="yes"
+    else
+        HAVE_ORACLE_OCI="no"
+    fi
+    AC_MSG_RESULT([$HAVE_ORACLE_OCI])
More information about the Liblas-commits mailing list
