[Liblas-commits] r1331 - in branches/1.2: include/liblas/detail src/detail
liblas-commits at liblas.org liblas-commits at liblas.org
Sun Aug 2 00:42:38 EDT 2009
Author: hobu
Date: Sun Aug  2 00:42:38 2009
New Revision: 1331
URL: http://liblas.org/changeset/1331
attempt a fix for #134
   branches/1.2/include/liblas/detail/writer.hpp
   branches/1.2/src/detail/writer.cpp
Modified: branches/1.2/include/liblas/detail/writer.hpp
--- branches/1.2/include/liblas/detail/writer.hpp	(original)
+++ branches/1.2/include/liblas/detail/writer.hpp	Sun Aug  2 00:42:38 2009
@@ -77,7 +77,7 @@
     void FillPointRecord(PointRecord& record, const LASPoint& point, const LASHeader& header);
-    void Project(PointRecord& point);
+    void Project(LASPoint& point);
     LASSpatialReference m_out_srs;
     LASSpatialReference m_in_srs;
Modified: branches/1.2/src/detail/writer.cpp
--- branches/1.2/src/detail/writer.cpp	(original)
+++ branches/1.2/src/detail/writer.cpp	Sun Aug  2 00:42:38 2009
@@ -87,11 +87,18 @@
 void Writer::FillPointRecord(PointRecord& record, const LASPoint& point, const LASHeader& header)
-    record.x = static_cast<int32_t>((point.GetX() - header.GetOffsetX()) / header.GetScaleX());
-    record.y = static_cast<int32_t>((point.GetY() - header.GetOffsetY()) / header.GetScaleY());
-    record.z = static_cast<int32_t>((point.GetZ() - header.GetOffsetZ()) / header.GetScaleZ());
-    if (m_transform) Project(record);
+    if (m_transform) {
+        // let's just copy the point for now.
+        LASPoint p = LASPoint(point);
+        Project(p);
+        record.x = static_cast<int32_t>((p.GetX() - header.GetOffsetX()) / header.GetScaleX());
+        record.y = static_cast<int32_t>((p.GetY() - header.GetOffsetY()) / header.GetScaleY());
+        record.z = static_cast<int32_t>((p.GetZ() - header.GetOffsetZ()) / header.GetScaleZ());
+    } else {
+        record.x = static_cast<int32_t>((point.GetX() - header.GetOffsetX()) / header.GetScaleX());
+        record.y = static_cast<int32_t>((point.GetY() - header.GetOffsetY()) / header.GetScaleY());
+        record.z = static_cast<int32_t>((point.GetZ() - header.GetOffsetZ()) / header.GetScaleZ());
     record.intensity = point.GetIntensity();
     record.flags = point.GetScanFlags();
@@ -120,7 +127,7 @@
     int32_t difference = header.GetDataOffset() - (vlr_total_size + header.GetHeaderSize());
     if (difference < 0)
         return difference;
@@ -150,7 +157,7 @@
-void Writer::SetSRS(const LASSpatialReference& srs)
+void Writer::SetSRS(const LASSpatialReference& srs )
     m_out_srs = srs;
 #ifdef HAVE_GDAL
@@ -161,7 +168,7 @@
     if (result != OGRERR_NONE)
         std::ostringstream msg;
-        msg << "Could not import input spatial reference for Reader::" << CPLGetLastErrorMsg() << result;
+        msg << "Could not import input spatial reference for Writer::" << CPLGetLastErrorMsg() << result;
         std::string message(msg.str());
         throw std::runtime_error(message);
@@ -170,7 +177,7 @@
-        msg << "Could not import output spatial reference for Reader::" << CPLGetLastErrorMsg() << result;
+        msg << "Could not import output spatial reference for Writer::" << CPLGetLastErrorMsg() << result;
@@ -180,14 +187,14 @@
 #endif
-void Writer::Project(PointRecord& point)
+void Writer::Project(LASPoint& p)
 #ifdef HAVE_GDAL
     int ret = 0;
-    double x = point.x;
-    double y = point.y;
-    double z = point.z;
+    double x = p.GetX();
+    double y = p.GetY();
+    double z = p.GetZ();
     ret = OCTTransform(m_transform, 1, &x, &y, &z);
@@ -198,10 +205,9 @@
-    // FIXME: PointRecords need to be descaled
-    point.x = x;
-    point.y = y;
-    point.z = z;
+    p.SetX(x);
+    p.SetY(y);
+    p.SetZ(z);
 #else
     UNREFERENCED_PARAMETER(point);
 #endif
More information about the Liblas-commits mailing list
