[Liblas-commits] r990 - trunk/include/liblas
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Feb 3 11:08:03 EST 2009
Author: mloskot
Date: Tue Feb  3 11:08:02 2009
New Revision: 990
URL: http://liblas.org/changeset/990
* Documented libLAS-specific elements of LASPoint class (no need to repeat LAS specification).
   trunk/include/liblas/laspoint.hpp
   trunk/include/liblas/lasreader.hpp
Modified: trunk/include/liblas/laspoint.hpp
--- trunk/include/liblas/laspoint.hpp	(original)
+++ trunk/include/liblas/laspoint.hpp	Tue Feb  3 11:08:02 2009
@@ -50,8 +50,7 @@
 namespace liblas {
-/// Definition of point data record.
+/// Point data record composed with X, Y, Z coordinates and attributes.
 class LASPoint
 public:
@@ -109,7 +108,16 @@
     uint16_t GetIntensity() const;
     void SetIntensity(uint16_t const& intensity);
+    /// Gets all scanning flags encoded as single byte.
+    /// The flags are (mandatory):
+    /// - Return Number (bits 0, 1, 2);
+    /// - Number of Returns - given pulse (bits 3, 4, 5);
+    /// - Scan Direction Flag (bit 6);
+    /// - Edge of Flight Line (bit 7).
     uint8_t GetScanFlags() const;
+    /// Sets all scanning flags passed as a single byte.
+    /// \sa Documentation of GetScanFlags method for flags details.
     void SetScanFlags(uint8_t const& flags);
     uint16_t GetReturnNumber() const;
@@ -145,7 +153,14 @@
     double GetTime() const;
     void SetTime(double const& time);
+    /// Index operator providing access to XYZ coordinates of point record.
+    /// Valid index values are 0, 1 or 2.
+    /// \exception std::out_of_range if requested index is out of range (> 2).
     double& operator[](std::size_t const& n);
+    /// Const version of index operator providing access to XYZ coordinates of point record.
     double const& operator[](std::size_t const& n) const;
     /// \todo TODO: Should we compare other data members, but not only coordinates?
@@ -172,13 +187,13 @@
-/// \todo To be documented.
+/// Equal-to operator implemented in terms of LASPoint::equal method.
 inline bool operator==(LASPoint const& lhs, LASPoint const& rhs)
     return lhs.equal(rhs);
+/// Not-equal-to operator implemented in terms of LASPoint::equal method.
 inline bool operator!=(LASPoint const& lhs, LASPoint const& rhs)
     return (!(lhs == rhs));
Modified: trunk/include/liblas/lasreader.hpp
--- trunk/include/liblas/lasreader.hpp	(original)
+++ trunk/include/liblas/lasreader.hpp	Tue Feb  3 11:08:02 2009
@@ -90,9 +90,9 @@
     void Init(); // throws on error
     void MakePIMPL(std::istream& ifs);
-    /// \todo TODO: Should we handle m_record.point_source_id ?
     void MakePoint(double const& time);
+    // TODO: Consider restoring const keyword and improving idea of re-assignment (see MakePIMPL).
     std::auto_ptr<detail::Reader> m_pimpl;
     LASHeader m_header;
     LASPoint m_point;
More information about the Liblas-commits mailing list
