[Liblas-commits] r999 - trunk/include/liblas
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Feb 4 21:59:38 EST 2009
Author: hobu
Date: Wed Feb  4 21:59:38 2009
New Revision: 999
URL: http://liblas.org/changeset/999
add Red, Green, and Blue to LASPoint for 1.2 support #91
   trunk/include/liblas/laspoint.hpp
Modified: trunk/include/liblas/laspoint.hpp
--- trunk/include/liblas/laspoint.hpp	(original)
+++ trunk/include/liblas/laspoint.hpp	Wed Feb  4 21:59:38 2009
@@ -109,10 +109,10 @@
     void SetIntensity(uint16_t const& intensity);
     /// Gets all scanning flags encoded as single byte.
-    /// The flags are (mandatory):
-    /// - Return Number (bits 0, 1, 2);
-    /// - Number of Returns - given pulse (bits 3, 4, 5);
-    /// - Scan Direction Flag (bit 6);
+    /// The flags are (mandatory):
+    /// - Return Number (bits 0, 1, 2);
+    /// - Number of Returns - given pulse (bits 3, 4, 5);
+    /// - Scan Direction Flag (bit 6);
     /// - Edge of Flight Line (bit 7).
     uint8_t GetScanFlags() const;
@@ -149,7 +149,25 @@
     /// Set value of User Bit Field (LAS 1.0) or Point Source ID (LAS 1.1).
     void SetPointSourceID(uint16_t const& id);
+    /// Fetch value of the red image channel value associated with this point (LAS 1.2)
+    uint16_t GetRed() const;
+    /// Set value of the red image channel value associated with this point (LAS 1.2)
+    void SetRed(uint16_t const& value);
+    /// Fetch value of the blue image channel value associated with this point (LAS 1.2)
+    uint16_t GetBlue() const;
+    /// Set value of the blue image channel value associated with this point (LAS 1.2)
+    void SetBlue(uint16_t const& value);
+    /// Fetch value of the green image channel value associated with this point (LAS 1.2)
+    uint16_t GetGreen() const;
+    void SetGreen(uint16_t const& value);
     double GetTime() const;
     void SetTime(double const& time);
@@ -180,6 +198,9 @@
     uint8_t m_userData;
     uint16_t m_pointSourceId;
     double m_gpsTime;
+    uint16_t m_red;
+    uint16_t m_green;
+    uint16_t m_blue;
     void throw_out_of_range() const
@@ -320,6 +341,36 @@
     m_gpsTime = time;
+inline uint16_t LASPoint::GetRed() const
+    return m_red;
+inline void LASPoint::SetRed(uint16_t const& value)
+    m_red = value;
+inline uint16_t LASPoint::GetBlue() const
+    return m_blue;
+inline void LASPoint::SetBlue(uint16_t const& value)
+    m_blue = value;
+inline uint16_t LASPoint::GetGreen() const
+    return m_green;
+inline void LASPoint::SetGreen(uint16_t const& value)
+    m_green = value;
 inline double& LASPoint::operator[](std::size_t const& n)
     if (coords_size <= n)
More information about the Liblas-commits mailing list
