[Liblas-commits] r1026 - in trunk: . include/liblas/capi python
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Feb 16 21:32:56 EST 2009
Author: hobu
Date: Mon Feb 16 21:32:55 2009
New Revision: 1026
URL: http://liblas.org/changeset/1026
increment versions to 1.2 which is where we will be at the next release
   trunk/configure.ac
   trunk/include/liblas/capi/las_version.h
   trunk/nmake.opt
   trunk/python/setup.py
Modified: trunk/configure.ac
--- trunk/configure.ac	(original)
+++ trunk/configure.ac	Mon Feb 16 21:32:55 2009
@@ -3,7 +3,7 @@
 dnl This is main autoconf bootstrap script of libLAS project.
 dnl
 m4_define([liblas_version_major], [1])
-m4_define([liblas_version_minor], [1])
+m4_define([liblas_version_minor], [2])
 m4_define([liblas_version_micro], [0])
 m4_define([liblas_version],
           [liblas_version_major.liblas_version_minor.liblas_version_micro])
@@ -123,8 +123,8 @@
 fi
 if test "$GDAL_CONFIG" != "no" ; then
-    VERSION=`$GDAL_CONFIG --version`
-    AC_MSG_RESULT([$GDAL_CONFIG reports version $VERSION])
+    GDAL_VERSION=`$GDAL_CONFIG --version`
+    AC_MSG_RESULT([$GDAL_CONFIG reports version $GDAL_VERSION])
     LIBS="`$GDAL_CONFIG --libs` $LIBS"
     GDAL_INC=`$GDAL_CONFIG --cflags`
     GDAL_PREFIX=`$GDAL_CONFIG --prefix`
Modified: trunk/include/liblas/capi/las_version.h
--- trunk/include/liblas/capi/las_version.h	(original)
+++ trunk/include/liblas/capi/las_version.h	Mon Feb 16 21:32:55 2009
@@ -44,7 +44,7 @@
 #ifndef LIBLAS_VERSION_MAJOR
 #define LIBLAS_VERSION_MAJOR    1
-#define LIBLAS_VERSION_MINOR    1
+#define LIBLAS_VERSION_MINOR    2
 #define LIBLAS_VERSION_REV      0
 #define LIBLAS_VERSION_BUILD    0
 #endif
@@ -58,7 +58,7 @@
 #endif
 #ifndef LIBLAS_RELEASE_NAME
-#define LIBLAS_RELEASE_NAME     "1.1.0"
+#define LIBLAS_RELEASE_NAME     "1.2.0"
 #endif
 #endif /* LAS_VERSION_H_INCLUDED */
Modified: trunk/nmake.opt
--- trunk/nmake.opt	(original)
+++ trunk/nmake.opt	Mon Feb 16 21:32:55 2009
@@ -13,7 +13,7 @@
 LAS_LIB_DLL = liblas_i.lib
 # only used for filenames of packages
-PACKAGE_VERSION = 1.1.0
+PACKAGE_VERSION = 1.2.0
 INCLUDES = -I$(LAS_ROOT)/include -I$(LAS_ROOT)/include/liblas/capi
Modified: trunk/python/setup.py
--- trunk/python/setup.py	(original)
+++ trunk/python/setup.py	Mon Feb 16 21:32:55 2009
@@ -17,7 +17,7 @@
 import os
-version = '1.1.0'
+version = '1.2.0'
 if os.name == 'nt':
     # Windows NT library
More information about the Liblas-commits mailing list
