[Liblas-commits] r1035 - in trunk: python/liblas src
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Feb 17 02:02:29 EST 2009
Author: hobu
Date: Tue Feb 17 02:02:29 2009
New Revision: 1035
URL: http://liblas.org/changeset/1035
default to using 1.2 for LASHeader and fix SetVersionMinor interaction with the data offset that likely prevented us from ever correctly writing 1.0 data
   trunk/python/liblas/color.py
   trunk/python/liblas/header.py
   trunk/src/lasheader.cpp
Modified: trunk/python/liblas/color.py
--- trunk/python/liblas/color.py	(original)
+++ trunk/python/liblas/color.py	Tue Feb 17 02:02:29 2009
@@ -44,7 +44,7 @@
 import ctypes
 class Color(object):
-    def __init__(self, owned=True, handle=None):
+    def __init__(self, red=0, green=0, blue=0, owned=True, handle=None):
         if handle:
             self.handle = handle
         else:
Modified: trunk/python/liblas/header.py
--- trunk/python/liblas/header.py	(original)
+++ trunk/python/liblas/header.py	Tue Feb 17 02:02:29 2009
@@ -97,7 +97,7 @@
     major_version = property(get_majorversion, set_majorversion)
     def get_minorversion(self):
-        """Returns the minor version of the file.  Expect this value to always be 0 or 1"""
+        """Returns the minor version of the file.  Expect this value to always be 0, 1, or 2"""
         return core.las.LASHeader_GetVersionMinor(self.handle)
     def set_minorversion(self, value):
         """Sets the minor version of the file.  The value should be 0 for 1.0 LAS files and 1 for 1.1 LAS files"""
@@ -195,19 +195,19 @@
     records_count = property(get_recordscount)
     def get_dataformatid(self):
-        """Returns the data format id.
+        """Gets the point format value
         A value of 1 means the format is 1.1 compatible and includes a time
         value on the points.  A value of 0 means the format is 1.0 compatible.
         return core.las.LASHeader_GetDataFormatId(self.handle)
     def set_dataformatid(self, value):
-        """Sets the data format id for the file.
+        """Sets the point format value
-        It can only be 1 (for 1.1 compatible) or 0 (for 1.0 compatible).
+        It can only be  1 (for 1.1 compatible) or 0 (for 1.0 compatible).
-        if value not in [1,0]:
-            raise core.LASException("Format ID must be 1 or 0")
+        if value not in [3, 2,1,0]:
+            raise core.LASException("Format ID must be 3, 2, 1, or 0")
         return core.las.LASHeader_SetDataFormatId(self.handle, value)
     dataformat_id = property(get_dataformatid, set_dataformatid)
Modified: trunk/src/lasheader.cpp
--- trunk/src/lasheader.cpp	(original)
+++ trunk/src/lasheader.cpp	Tue Feb 17 02:02:29 2009
@@ -263,8 +263,19 @@
     if (v > eVersionMinorMax)
         throw std::out_of_range("version minor out of range");
     m_versionMinor = v;
+    uint32_t size = 0;
+    uint32_t const dataSignatureSize = 2;
+    // Add the signature if we're a 1.0 file
+    if (eVersionMinorMin == m_versionMinor) {
+        size = dataSignatureSize;
+    SetDataOffset(GetHeaderSize()+size);
 std::string LASHeader::GetSystemId(bool pad /*= false*/) const
@@ -359,8 +370,9 @@
     uint16_t const hsize = GetHeaderSize();
-    if ((eVersionMinorMin == m_versionMinor && v < hsize + dataSignatureSize)
-        || (eVersionMinorMax == m_versionMinor && v < hsize))
+    if ( (m_versionMinor == 0 && v < hsize + dataSignatureSize) ||
+         (m_versionMinor == 1 && v < hsize) ||
+         (m_versionMinor == 2 && v < hsize) )
         throw std::out_of_range("data offset out of range");
@@ -608,10 +620,10 @@
 void LASHeader::Init()
     // Initialize public header block with default
-    // values according to LAS 1.1
+    // values according to LAS 1.2
     m_versionMajor = 1;
-    m_versionMinor = 1;
+    m_versionMinor = 2;
     m_dataFormatId = ePointFormat0;
     m_dataRecordLen = ePointSize0;
More information about the Liblas-commits mailing list
