[Liblas-commits] r1049 - trunk/src
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Feb 19 14:02:45 EST 2009
Author: hobu
Date: Thu Feb 19 14:02:45 2009
New Revision: 1049
URL: http://liblas.org/changeset/1049
don't leak, better error checking
   trunk/src/lassrs.cpp
Modified: trunk/src/lassrs.cpp
--- trunk/src/lassrs.cpp	(original)
+++ trunk/src/lassrs.cpp	Thu Feb 19 14:02:45 2009
@@ -70,16 +70,16 @@
     // FIXME: this needs to be cleaned up
-    // if (m_gtiff)
-    //     GTIFFree(m_gtiff);
-    //     m_gtiff = NULL;
-    // if (m_tiff)
-    //     ST_Destroy(m_tiff);
-    //     m_tiff = NULL;
+    if (m_gtiff)
+        GTIFFree(m_gtiff);
+        m_gtiff = NULL;
+    if (m_tiff)
+        ST_Destroy(m_tiff);
+        m_tiff = NULL;
@@ -107,15 +107,24 @@
     std::string const uid("LASF_Projection");
+    // Wipe out any existing VLRs that might exist on the LASSRS
     m_vlrs.clear();
+    // We only copy VLR records from the list which are related to GeoTIFF keys.
+    // They must have an id of "LASF_Projection" and a record id that's related.
     for (i = vlrs.begin(); i != vlrs.end(); ++i)
+        //GTIFF_GEOKEYDIRECTORY == 34735
         if (uid == (*i).GetUserId(true).c_str() && 34735 == (*i).GetRecordId()) {
             m_vlrs.push_back(*i);
+        // GTIFF_DOUBLEPARAMS == 34736
         if (uid == (*i).GetUserId(true).c_str() && 34736 == (*i).GetRecordId()) {
+        // GTIFF_ASCIIPARAMS == 34737
         if (uid == (*i).GetUserId(true).c_str() && 34737 == (*i).GetRecordId()) {
@@ -150,8 +159,8 @@
     int acount = 0;
     int atype =0;
-    if (!m_tiff) throw std::invalid_argument("m_tiff was null");
-    if (!m_gtiff) throw std::invalid_argument("m_gtiff was null");
+    if (!m_tiff) throw std::invalid_argument("m_tiff was null, cannot reset VLRs without m_tiff");
+    if (!m_gtiff) throw std::invalid_argument("m_gtiff was null, cannot reset VLRs without m_gtiff");
     ret = ST_GetKey(m_tiff, 34735, &kcount, &ktype, (void**)&kdata);
@@ -183,40 +192,6 @@
         m_vlrs.push_back(record);
-    // GTIFF_ASCIIPARAMS == 34737
-    ret = ST_GetKey(m_tiff, 34737, &acount, &atype, (void**)&adata);
-    if (ret)
-         LASVLR record;
-         int i = 0;
-         record.SetRecordId(34737);
-         record.SetUserId("LASF_Projection");
-         std::vector<uint8_t> data;
-         uint32_t length = acount;
-         record.SetRecordLength(length);
-         // Copy the data into the data vector
-         for (i=0; i<acount;i++) {
-             avalue = adata[i];
-             uint8_t* v =  reinterpret_cast<uint8_t*>(&avalue);
-             data.push_back(v[0]);
-             data.push_back(v[1]);
-             data.push_back(v[2]);
-             data.push_back(v[3]);
-             data.push_back(v[4]);
-             data.push_back(v[5]);
-             data.push_back(v[6]);
-             data.push_back(v[7]);
-         record.SetData(data);
-         m_vlrs.push_back(record);
     ret = ST_GetKey(m_tiff, 34736, &dcount, &dtype, (void**)&ddata);
     if (ret)
@@ -251,6 +226,50 @@
+    ret = ST_GetKey(m_tiff, 34737, &acount, &atype, (void**)&adata);
+    if (ret)
+         LASVLR record;
+         int i = 0;
+         record.SetRecordId(34737);
+         record.SetUserId("LASF_Projection");
+         std::vector<uint8_t> data;
+         // whoa.  If the returned count was 0, it is because there
+         // was a bug in libgeotiff that existed before r1531 where it
+         // didn't calculate the string length for an ASCII geotiff tag.
+         // We need to throw an exception in this case because we're
+         // screwed, and if we don't we'll end up writing bad GeoTIFF keys.
+         if (!acount) {
+             throw std::runtime_error("GeoTIFF ASCII key with no returned size. "
+                                      "Upgrade your libgeotiff to a version greater "
+                                      "than r1531 (libgeotiff 1.2.6)");
+         uint32_t length = acount;
+         record.SetRecordLength(length);
+         // Copy the data into the data vector
+         for (i=0; i<acount;i++) {
+             avalue = adata[i];
+             uint8_t* v =  reinterpret_cast<uint8_t*>(&avalue);
+             data.push_back(v[0]);
+             data.push_back(v[1]);
+             data.push_back(v[2]);
+             data.push_back(v[3]);
+             data.push_back(v[4]);
+             data.push_back(v[5]);
+             data.push_back(v[6]);
+             data.push_back(v[7]);
+         record.SetData(data);
+         m_vlrs.push_back(record);
 #endif // ndef HAVE_LIBGEOTIFF
@@ -258,13 +277,17 @@
 const GTIF* LASSRS::GetGTIF(){
 #ifdef HAVE_LIBGEOTIFF
-    // if we're already set, don't overwrite
-    // FIXME this is a bug.
-    // if (m_gtiff) return m_gtiff;
+    // If we already have m_gtiff and m_tiff, that is because we have
+    // already called GetGTIF once before.  VLRs ultimately drive how the
+    // LASSRS is defined, not the GeoTIFF keys.
+    if (m_tiff) {ST_Destroy(m_tiff); m_tiff = NULL;}
+    if (m_gtiff) {GTIFFree(m_gtiff); m_gtiff = NULL; }
     m_tiff = ST_Create();
+    // Nothing is going to happen here if we don't have any VLRs describing
+    // SRS information on the LASSRS.
     for (uint16_t i = 0; i < m_vlrs.size(); ++i)
         LASVLR record = m_vlrs[i];
@@ -298,7 +321,6 @@
     return NULL;
 /// Fetch the SRS as WKT
 std::string LASSRS::GetWKT() const
@@ -335,7 +357,8 @@
         throw std::runtime_error("The geotiff keys could not be written");
 #else
+    throw std::runtime_error("GDAL is not available, LASSRS could not be set from WKT");
 #endif
@@ -361,7 +384,9 @@
     poSRS->exportToProj4(&proj4);
     std::string tmp(proj4);
     std::free(proj4);
+    delete poSRS;
     return tmp;
 #endif
@@ -402,6 +427,8 @@
     poSRS->exportToWkt(&poWKT);
+    delete poSRS;
     std::string tmp(poWKT);
     std::free(poWKT);
More information about the Liblas-commits mailing list
