[Liblas-commits] r1303 - in trunk: apps include/liblas/index src/index
liblas-commits at liblas.org liblas-commits at liblas.org
Sat Jul 4 01:21:17 EDT 2009
Author: hobu
Date: Sat Jul  4 01:21:16 2009
New Revision: 1303
URL: http://liblas.org/changeset/1303
blk_extent index creation
   trunk/apps/las2oci.cpp
   trunk/include/liblas/index/query.hpp
   trunk/src/index/query.cpp
Modified: trunk/apps/las2oci.cpp
--- trunk/apps/las2oci.cpp	(original)
+++ trunk/apps/las2oci.cpp	Sat Jul  4 01:21:16 2009
@@ -34,6 +34,8 @@
 #endif
 std::istream* OpenInput(std::string filename)
     std::ios::openmode const mode = std::ios::in | std::ios::binary;
@@ -331,6 +333,52 @@
     return true;
+bool CreateSDOEntry(OWConnection* connection, const char* tableName, LASQuery* query, int srid)
+    ostringstream oss;
+    OWStatement* statement = 0;
+    // SpatialIndex::Region* b = query->bounds;
+    ostringstream oss_geom;
+    oss.setf(std::ios_base::fixed, std::ios_base::floatfield);
+    oss.precision(2);
+//     code = """
+// INSERT INTO user_sdo_geom_metadata VALUES (
+//     'foo',
+//     'blk_extent',
+//     MDSYS.SDO_DIM_ARRAY(
+// MDSYS.SDO_DIM_ELEMENT('X', 630250.000000, 630500.000000, 0.05),
+// MDSYS.SDO_DIM_ELEMENT('Y', 4834500, 4834750, 0.05)),
+//     8307)
+    oss <<  "INSERT INTO user_sdo_geom_metadata VALUES ('" << tableName <<
+            "','blk_extent', MDSYS.SDO_DIM_ARRAY("
+            "MDSYS.SDO_DIM_ELEMENT('X', "<< query->bounds.getLow(0) <<","<< query->bounds.getHigh(0)<<",0.05),"
+            "MDSYS.SDO_DIM_ELEMENT('Y', "<< query->bounds.getLow(1) <<","<< query->bounds.getHigh(1)<<",0.05)),"
+            << srid << ")";
+    statement = Run(connection, oss);
+    if (statement != 0) delete statement; else return false;
+    oss.str("");
+    return true;
+bool CreateBlockIndex(OWConnection* connection, const char* tableName)
+    oss << "CREATE INDEX "<< tableName <<"_cloud_idx on "<<tableName<<"(blk_extent) INDEXTYPE IS MDSYS.SPATIAL_INDEX" ;
+    oss.str("");
+    return true;
 void usage() {}
 int main(int argc, char* argv[])
@@ -458,6 +506,9 @@
         bool inserted = InsertBlock(con, *i, srid, reader2, table_name.c_str());
+    CreateSDOEntry(con, table_name.c_str(), query, srid );
+    CreateBlockIndex(con, table_name.c_str());
 //    Cleanup(con, "base");
  // int   iCol = 0;
Modified: trunk/include/liblas/index/query.hpp
--- trunk/include/liblas/index/query.hpp	(original)
+++ trunk/include/liblas/index/query.hpp	Sat Jul  4 01:21:16 2009
@@ -89,6 +89,8 @@
     std::queue<SpatialIndex::id_type> m_ids;
     uint32_t m_count;
     std::list<LASQueryResult> m_results;
+    bool m_first;
 public:
     LASQuery();
@@ -98,6 +100,7 @@
     void getNextEntry(const SpatialIndex::IEntry& entry, SpatialIndex::id_type& nextEntry, bool& hasNext);
     std::list<LASQueryResult>& GetResults() {return m_results;}
+    SpatialIndex::Region bounds;
Modified: trunk/src/index/query.cpp
--- trunk/src/index/query.cpp	(original)
+++ trunk/src/index/query.cpp	Sat Jul  4 01:21:16 2009
@@ -53,10 +53,21 @@
 namespace liblas
-    LASQuery::LASQuery() :m_count(0){}
+    LASQuery::LASQuery() :m_count(0),m_first(true){}
 void LASQuery::getNextEntry(const SpatialIndex::IEntry& entry, SpatialIndex::id_type& nextEntry, bool& hasNext) {
     // the first time we are called, entry points to the root.
+    if (m_first) {
+        SpatialIndex::IShape* ps;
+        entry.getShape(&ps);
+        ps->getMBR(bounds);
+        delete ps;
+        // any other time through we're no longer at the root so
+        // we wouldn't get the entire index's bounding box
+        m_first = false;
     const SpatialIndex::INode* n = dynamic_cast<const SpatialIndex::INode*>(&entry);
     // if (n !=0 ) {
More information about the Liblas-commits mailing list
