[Liblas-commits] r1315 - branches/1.2/src
liblas-commits at liblas.org liblas-commits at liblas.org
Sat Jul 25 22:23:29 EDT 2009
Author: hobu
Date: Sat Jul 25 22:23:29 2009
New Revision: 1315
URL: http://liblas.org/changeset/1315
Fix #140 and #140 related to not having the gt_citation stuff
Added:
   branches/1.2/src/gt_citation.cpp
   branches/1.2/src/Makefile.am
Modified: branches/1.2/src/Makefile.am
--- branches/1.2/src/Makefile.am	(original)
+++ branches/1.2/src/Makefile.am	Sat Jul 25 22:23:29 2009
@@ -35,7 +35,7 @@
     detail/file.cpp
 if GDAL_IS_CONFIG
-liblas_la_SOURCES += gt_wkt_srs.cpp
+liblas_la_SOURCES += gt_wkt_srs.cpp gt_citation.cpp
 endif
 liblas_la_LDFLAGS = -version-info 1:0:0
Added: branches/1.2/src/gt_citation.cpp
--- (empty file)
+++ branches/1.2/src/gt_citation.cpp	Sat Jul 25 22:23:29 2009
@@ -0,0 +1,479 @@
+ * $Id$
+ * Project:  GeoTIFF Driver
+ * Purpose:  Implements special parsing of Imagine citation strings, and
+ *           to encode PE String info in citation fields as needed.
+ * Author:   Xiuguang Zhou (ESRI)
+ * Copyright (c) 2008, Xiuguang Zhou (ESRI)
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+ * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+#include "cpl_port.h"
+#include "cpl_string.h"
+#include "geo_normalize.h"
+#include "geovalues.h"
+#include "ogr_spatialref.h"
+#define nCitationNameTypes 9
+typedef enum
+  CitCsName = 0,
+  CitPcsName = 1,
+  CitProjectionName = 2,
+  CitLUnitsName = 3,
+  CitGcsName = 4,
+  CitDatumName = 5,
+  CitEllipsoidName = 6,
+  CitPrimemName = 7,
+  CitAUnitsName = 8
+} CitationNameType;
+char* ImagineCitationTranslation(const char* psCitation, geokey_t keyID);
+char** CitationStringParse(const char* psCitation);
+void SetLinearUnitCitation(GTIF* psGTIF, char* pszLinearUOMName);
+void SetGeogCSCitation(GTIF * psGTIF, OGRSpatialReference *poSRS, char* angUnitName, int nDatum, short nSpheroid);
+OGRBoolean SetCitationToSRS(GTIF* hGTIF, char* szCTString, int nCTStringLen,
+                            geokey_t geoKey,  OGRSpatialReference* poSRS, OGRBoolean* linearUnitIsSet);
+void GetGeogCSFromCitation(char* szGCSName, int nGCSName,
+                           geokey_t geoKey,
+                          char	**ppszGeogName,
+                          char	**ppszDatumName,
+                          char	**ppszPMName,
+                          char	**ppszSpheroidName,
+                          char	**ppszAngularUnits);
+/*                     ImagineCitationTranslation()                     */
+/*      Translate ERDAS Imagine GeoTif citation                         */
+    char* ret = NULL;
+    if(!psCitation)
+        return ret;
+    if(EQUALN(psCitation, "IMAGINE GeoTIFF Support", strlen("IMAGINE GeoTIFF Support")))
+        CPLString osName;
+        // this is a handle IMAGING style citation
+        const char* p = NULL;
+        p = strchr(psCitation, '$');
+        if(p)
+            p = strchr(p, '\n');
+        if(p)
+            p++;
+        const char* p1 = NULL;
+        if(p)
+            p1 = strchr(p, '\n');
+        if(p && p1)
+            switch (keyID)
+              case PCSCitationGeoKey:
+                osName = "PCS Name = ";
+                break;
+              case GTCitationGeoKey:
+                osName = "CS Name = ";
+                break;
+              case GeogCitationGeoKey:
+                if(!strstr(p, "Unable to"))
+                    osName = "GCS Name = ";
+                break;
+              default:
+                break;
+            if(strlen(osName)>0)
+                osName.append(p, p1-p);
+                osName += "|";
+        p = strstr(psCitation, "Projection Name = ");
+        if(p)
+            p += strlen("Projection Name = ");
+            if(!p1)
+                p1 = strchr(p, '\0');
+        if(p && p1)
+            osName += "|";
+        p = strstr(psCitation, "Datum = ");
+        if(p)
+            p += strlen("Datum = ");
+            if(!p1)
+        if(p && p1)
+            osName += "Datum = ";
+            osName += "|";
+        p = strstr(psCitation, "Ellipsoid = ");
+        if(p)
+            p += strlen("Ellipsoid = ");
+            if(!p1)
+        if(p && p1)
+            osName += "Ellipsoid = ";
+            osName += "|";
+        p = strstr(psCitation, "Units = ");
+        if(p)
+            p += strlen("Units = ");
+            if(!p1)
+        if(p && p1)
+            osName += "LUnits = ";
+            osName += "|";
+        if(strlen(osName) > 0)
+            ret = CPLStrdup(osName);
+    return ret;
+/*                        CitationStringParse()                         */
+/*      Parse a Citation string                                         */
+    char ** ret = NULL;
+    if(!psCitation)
+        return ret;
+    ret = (char **) CPLCalloc(sizeof(char*), nCitationNameTypes);
+    const char* pDelimit = NULL;
+    const char* pStr = psCitation;
+    CPLString osName;
+    int nCitationLen = strlen(psCitation);
+    OGRBoolean nameFound = FALSE;
+    while((pStr-psCitation+1)< nCitationLen)
+        if( (pDelimit = strstr(pStr, "|")) )
+            osName = "";
+            osName.append(pStr, pDelimit-pStr);
+            pStr = pDelimit+1;
+        else
+            osName = pStr;
+            pStr += strlen(pStr);
+        const char* name = osName.c_str();
+        if( strstr(name, "PCS Name = ") )
+            if (!ret[CitPcsName])
+                ret[CitPcsName] = CPLStrdup(name+strlen("PCS Name = "));
+            nameFound = TRUE;
+        if(strstr(name, "Projection Name = "))
+            if (!ret[CitProjectionName])
+                ret[CitProjectionName] = CPLStrdup(name+strlen("Projection Name = "));
+            nameFound = TRUE;
+        if(strstr(name, "LUnits = "))
+            if (!ret[CitLUnitsName])
+                ret[CitLUnitsName] = CPLStrdup(name+strlen("LUnits = "));
+            nameFound = TRUE;
+        if(strstr(name, "GCS Name = "))
+            if (!ret[CitGcsName])
+                ret[CitGcsName] = CPLStrdup(name+strlen("GCS Name = "));
+            nameFound = TRUE;
+        if(strstr(name, "Datum = "))
+            if (!ret[CitDatumName])
+                ret[CitDatumName] = CPLStrdup(name+strlen("Datum = "));
+            nameFound = TRUE;
+        if(strstr(name, "Ellipsoid = "))
+            if (!ret[CitEllipsoidName])
+                ret[CitEllipsoidName] = CPLStrdup(name+strlen("Ellipsoid = "));
+            nameFound = TRUE;
+        if(strstr(name, "Primem = "))
+            if (!ret[CitPrimemName])
+                ret[CitPrimemName] = CPLStrdup(name+strlen("Primem = "));
+            nameFound = TRUE;
+        if(strstr(name, "AUnits = "))
+            if (!ret[CitAUnitsName])
+                ret[CitAUnitsName] = CPLStrdup(name+strlen("AUnits = "));
+            nameFound = TRUE;
+    if(!nameFound)
+        CPLFree( ret );
+        ret = (char**)NULL;
+    return ret;
+/*                       SetLinearUnitCitation()                        */
+/*      Set linear unit Citation string                                 */
+    char szName[512];
+    CPLString osCitation;
+    int n = 0;
+    if( GTIFKeyGet( psGTIF, PCSCitationGeoKey, szName, 0, sizeof(szName) ) )
+        n = strlen(szName);
+    if(n>0)
+        osCitation = szName;
+        if(osCitation[n-1] != '|')
+            osCitation += "|";
+        osCitation += "LUnits = ";
+        osCitation += pszLinearUOMName;
+    else
+        osCitation = "LUnits = ";
+    GTIFKeySet( psGTIF, PCSCitationGeoKey, TYPE_ASCII, 0, osCitation.c_str() );
+    return;
+/*                         SetGeogCSCitation()                          */
+/*      Set geogcs Citation string                                      */
+    int bRewriteGeogCitation = FALSE;
+    char szName[256];
+    size_t n = 0;
+    if( GTIFKeyGet( psGTIF, GeogCitationGeoKey, szName, 0, sizeof(szName) ) )
+    if (n == 0)
+        return;
+    if(!EQUALN(szName, "GCS Name = ", strlen("GCS Name = ")))
+        osCitation = "GCS Name = ";
+        osCitation += szName;
+    else
+    if(nDatum == KvUserDefined )
+        const char* datumName = poSRS->GetAttrValue( "DATUM" );
+        if(datumName && strlen(datumName) > 0)
+            osCitation += "|Datum = ";
+            osCitation += datumName;
+            bRewriteGeogCitation = TRUE;
+    if(nSpheroid == KvUserDefined )
+        const char* spheroidName = poSRS->GetAttrValue( "SPHEROID" );
+        if(spheroidName && strlen(spheroidName) > 0)
+            osCitation += "|Ellipsoid = ";
+            osCitation += spheroidName;
+    const char* primemName = poSRS->GetAttrValue( "PRIMEM" );
+    if(primemName && strlen(primemName) > 0)
+        osCitation += "|Primem = ";
+        osCitation += primemName;
+        double primemValue = poSRS->GetPrimeMeridian(NULL);
+        if(angUnitName && !EQUAL(angUnitName, "Degree"))
+            double aUnit = poSRS->GetAngularUnits(NULL);
+            primemValue *= aUnit;
+        GTIFKeySet( psGTIF, GeogPrimeMeridianLongGeoKey, TYPE_DOUBLE, 1,
+                    primemValue );
+    if(angUnitName && strlen(angUnitName) > 0 && !EQUAL(angUnitName, "Degree"))
+        osCitation += "|AUnits = ";
+        osCitation += angUnitName;
+    if (osCitation[strlen(osCitation) - 1] != '|')
+    if (bRewriteGeogCitation)
+        GTIFKeySet( psGTIF, GeogCitationGeoKey, TYPE_ASCII, 0, osCitation.c_str() );
+    return;
+/*                          SetCitationToSRS()                          */
+/*      Parse and set Citation string to SRS                            */
+    OGRBoolean ret = FALSE;
+    *linearUnitIsSet = FALSE;
+    char* imgCTName = ImagineCitationTranslation(szCTString, geoKey);
+    if(imgCTName)
+        strncpy(szCTString, imgCTName, nCTStringLen);
+        szCTString[nCTStringLen-1] = '\0';
+        CPLFree( imgCTName );
+    char** ctNames = CitationStringParse(szCTString);
+    if(ctNames)
+        if( poSRS->GetRoot() == NULL)
+            poSRS->SetNode( "PROJCS", "unnamed" );
+        if(ctNames[CitPcsName])
+            poSRS->SetNode( "PROJCS", ctNames[CitPcsName] );
+            ret = TRUE;
+        else if(geoKey != GTCitationGeoKey)
+            char    szPCSName[128];
+            if( GTIFKeyGet( hGTIF, GTCitationGeoKey, szPCSName, 0, sizeof(szPCSName) ) )
+                poSRS->SetNode( "PROJCS", szPCSName );
+                ret = TRUE;
+        if(ctNames[CitProjectionName])
+            poSRS->SetProjection( ctNames[CitProjectionName] );
+        if(ctNames[CitLUnitsName])
+            double unitSize;
+            if (GTIFKeyGet(hGTIF, ProjLinearUnitSizeGeoKey, &unitSize, 0,
+                           sizeof(unitSize) ))
+                poSRS->SetLinearUnits( ctNames[CitLUnitsName], unitSize);
+                *linearUnitIsSet = TRUE;
+        for(int i= 0; i<nCitationNameTypes; i++)
+            CPLFree( ctNames[i] );
+        CPLFree( ctNames );
+    return ret;
+/*                       GetGeogCSFromCitation()                        */
+/*      Parse and get geogcs names from a Citation string               */
+                           geokey_t geoKey,
+    *ppszGeogName = *ppszDatumName = *ppszPMName =
+        *ppszSpheroidName = *ppszAngularUnits = NULL;
+    char* imgCTName = ImagineCitationTranslation(szGCSName, geoKey);
+    if(imgCTName)
+        strncpy(szGCSName, imgCTName, nGCSName);
+        szGCSName[nGCSName-1] = '\0';
+    char** ctNames = CitationStringParse(szGCSName);
+    if(ctNames)
+        if(ctNames[CitGcsName])
+            *ppszGeogName = CPLStrdup( ctNames[CitGcsName] );
+        if(ctNames[CitDatumName])
+            *ppszDatumName = CPLStrdup( ctNames[CitDatumName] );
+        if(ctNames[CitEllipsoidName])
+            *ppszSpheroidName = CPLStrdup( ctNames[CitEllipsoidName] );
+        if(ctNames[CitPrimemName])
+            *ppszPMName = CPLStrdup( ctNames[CitPrimemName] );
+        if(ctNames[CitAUnitsName])
+            *ppszAngularUnits = CPLStrdup( ctNames[CitAUnitsName] );
+    return;
More information about the Liblas-commits mailing list
