[Liblas-commits] r1280 - in trunk: apps include include/liblas include/liblas/index
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jun 8 21:52:13 EDT 2009
Author: hobu
Date: Wed May 20 15:56:34 2009
New Revision: 1280
URL: http://liblas.org/changeset/1280
reorganize indexing headers, source code reorg yet to come
Added:
   trunk/include/liblas/index/
   trunk/include/liblas/index/datastream.hpp
      - copied, changed from r1273, /trunk/include/liblas/lasindex.hpp
   trunk/include/liblas/index/index.hpp
   trunk/include/liblas/index/storage.hpp
   trunk/include/liblas/index/visitor.hpp
Removed:
   trunk/apps/lasindex.cpp
   trunk/include/Makefile.am
Modified: trunk/apps/lasindex.cpp
--- trunk/apps/lasindex.cpp	(original)
+++ trunk/apps/lasindex.cpp	Wed May 20 15:56:34 2009
@@ -6,7 +6,7 @@
 #include <liblas/lascolor.hpp>
 #include <liblas/lasreader.hpp>
 #include <liblas/lasheader.hpp>
-#include <liblas/lasindex.hpp>
+#include <liblas/index/index.hpp>
 #ifdef HAVE_SPATIALINDEX
 #include <spatialindex/SpatialIndex.h>
Modified: trunk/include/Makefile.am
--- trunk/include/Makefile.am	(original)
+++ trunk/include/Makefile.am	Wed May 20 15:56:34 2009
@@ -10,7 +10,6 @@
     liblas/laserror.hpp \
     liblas/lasfile.hpp \
     liblas/lasheader.hpp \
-	liblas/lasindex.hpp \
     liblas/laspoint.hpp \
     liblas/lasreader.hpp \
     liblas/lasvariablerecord.hpp \
@@ -34,4 +33,8 @@
     liblas/detail/writer.hpp \
     liblas/detail/writer10.hpp \
     liblas/detail/writer11.hpp \
-    liblas/detail/writer12.hpp
\ No newline at end of file
+    liblas/detail/writer12.hpp \
+    liblas/index/datastream.hpp \
+    liblas/index/index.hpp \
+    liblas/index/storage.hpp \
+    liblas/index/visitor.hpp
Copied: trunk/include/liblas/index/datastream.hpp (from r1273, /trunk/include/liblas/lasindex.hpp)
--- /trunk/include/liblas/lasindex.hpp	(original)
+++ trunk/include/liblas/index/datastream.hpp	Wed May 20 15:56:34 2009
@@ -2,7 +2,7 @@
  * $Id$
  * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
- * Purpose:  LAS indexing class
+ * Purpose:  LAS indexing data stream class
  * Author:   Howard Butler, hobu.inc at gmail.com
@@ -39,8 +39,8 @@
  * OF SUCH DAMAGE.
-#ifndef LIBLAS_LASINDEX_HPP_INCLUDED
-#define LIBLAS_LASINDEX_HPP_INCLUDED
+#ifndef LIBLAS_INDEX_DATASTREAM_HPP_INCLUDED
+#define LIBLAS_INDEX_DATASTREAM_HPP_INCLUDED
 #include <liblas/lasvariablerecord.hpp>
 #include <liblas/laspoint.hpp>
@@ -56,114 +56,7 @@
 namespace liblas {
-class LASIndexDataStream;
-class LASIndex
-public:
-    enum IndexType
-        eMemoryIndex = 1, ///< A transient memory index that will go away
-        eVLRIndex = 2, ///< An index that will store its data in VLR records
-        eExternalIndex = 3 ///< An index that will store its data in files alongside the .las file (.las.dat & .las.idx)
-    LASIndex();
-    LASIndex(std::string& filename);
-    /// Copy constructor.
-    LASIndex(LASIndex const& other);
-    ~LASIndex();
-    void Initialize(LASIndexDataStream& strm);
-    void Initialize();
-    /// Assignment operator.
-    LASIndex& operator=(LASIndex const& rhs);
-    /// Comparison operator.
-    bool operator==(const LASIndex& other) const;
-    /// Inserts a LASPoint into the index with a given id
-    /// \param p the LASPoint to insert
-    /// \param id the id to associate with the point
-    void insert(LASPoint& p, int64_t id);
-    /// Intersects the index with the given cube and returns a
-    /// std::vector of ids.  Caller has ownership of the vector.
-    /// \param minx minimum X value of the cube
-    /// \param maxx maximum X value of the cube
-    /// \param miny minimum Y value of the cube
-    /// \param maxy maximum Y value of the cube
-    /// \param minz minimum Z value of the cube
-    /// \param maxz maximum Z value of the cube
-    /// \return std::vector<uint32_t> that the caller owns containing the ids that intersect the query.
-    std::vector<uint32_t>* intersects(double minx, double miny, double maxx, double maxy, double minz, double maxz);
-    /// Sets the page size for the index when stored externally
-    /// \param v - page value.  Defaults to 4096.
-    void SetPageSize(uint32_t v) { m_Pagesize = v; }
-    /// Get index page size for indexes that are stored externally
-    /// \return index page size.
-    uint32_t GetPageSize() { return m_Pagesize; }
-    /// Sets the index type
-    /// \param v - index type.  Defaults to eExternalIndex.
-    void SetIndexType(IndexType v) { m_idxType = v; }
-    /// Gets the index type
-    /// \return index type.
-    IndexType GetIndexType() { return m_idxType; }
-private:
-    SpatialIndex::IStorageManager* m_storage;
-    SpatialIndex::StorageManager::IBuffer* m_buffer;
-    SpatialIndex::ISpatialIndex* m_rtree;
-    uint32_t m_Pagesize;
-    IndexType m_idxType;
-    SpatialIndex::id_type m_idxId;
-    uint32_t m_idxCapacity;
-    uint32_t m_idxLeafCap;
-    uint32_t m_idxDimension;
-    double m_idxFillFactor;
-    bool m_idxExists;
-    std::string m_idxFilename;
-    uint16_t m_bufferCapacity;
-    bool m_bufferWriteThrough;
-    bool m_Initialized;
-    void Setup();
-    SpatialIndex::IStorageManager* CreateStorage(std::string& filename);
-    SpatialIndex::StorageManager::IBuffer* CreateIndexBuffer(SpatialIndex::IStorageManager& storage);
-    SpatialIndex::ISpatialIndex* CreateIndex(LASIndexDataStream& strm);
-    SpatialIndex::ISpatialIndex* LoadIndex();
-    bool ExternalIndexExists(std::string& filename);
-class LASVisitor : public SpatialIndex::IVisitor
-private:
-    size_t m_indexIO;
-    size_t m_leafIO;
-    std::vector<uint32_t>* m_vector;
-public:
-    LASVisitor(std::vector<uint32_t>* vect);
-    void visitNode(const SpatialIndex::INode& n);
-    void visitData(const SpatialIndex::IData& d);
-    void visitData(std::vector<const SpatialIndex::IData*>& v);
 class LASIndexDataStream : public SpatialIndex::IDataStream
@@ -187,42 +80,6 @@
-extern SpatialIndex::IStorageManager* returnLASStorageManager(Tools::PropertySet& in);
-extern SpatialIndex::IStorageManager* createNewLASStorageManager();
-class LASStorageManager : public SpatialIndex::IStorageManager
-public:
-    LASStorageManager(Tools::PropertySet&);
-    virtual ~LASStorageManager();
-    virtual void loadByteArray(const SpatialIndex::id_type id, size_t& len, uint8_t** data);
-    virtual void storeByteArray(SpatialIndex::id_type& id, const size_t len, const uint8_t* const data);
-    virtual void deleteByteArray(const SpatialIndex::id_type id);
-private:
-    class Entry
-    public:
-        byte* m_pData;
-        size_t m_length;
-        Entry(size_t l, const uint8_t* const d) : m_pData(0), m_length(l)
-            m_pData = new uint8_t[m_length];
-            memcpy(m_pData, d, m_length);
-        ~Entry() { delete[] m_pData; }
-    }; // Entry
-    std::vector<Entry*> m_buffer;
-    std::stack<SpatialIndex::id_type> m_emptyPages;
-}; // MemoryStorageManager
-#endif // LIBLAS_LASINDEX_HPP_INCLUDED
+#endif // LIBLAS_INDEX_DATASTREAM_HPP_INCLUDED
Copied: trunk/include/liblas/index/index.hpp (from r1273, /trunk/include/liblas/lasindex.hpp)
+++ trunk/include/liblas/index/index.hpp	Wed May 20 15:56:34 2009
@@ -39,14 +39,18 @@
  * OF SUCH DAMAGE.
+#ifndef LIBLAS_INDEX_INDEX_HPP_INCLUDED
+#define LIBLAS_INDEX_INDEX_HPP_INCLUDED
+#include <liblas/index/datastream.hpp>
+#include <liblas/index/storage.hpp>
+#include <liblas/index/visitor.hpp>
 //std
 #include <string>
@@ -56,8 +60,6 @@
 namespace liblas {
 class LASIndex
 public:
@@ -148,81 +150,8 @@
-private:
-    size_t m_indexIO;
-    size_t m_leafIO;
-public:
-class LASIndexDataStream : public SpatialIndex::IDataStream
-public:
-    LASIndexDataStream(LASReader* reader);
-    ~LASIndexDataStream();
-    SpatialIndex::IData* getNext();
-    bool hasNext() throw (Tools::NotSupportedException);
-    size_t size() throw (Tools::NotSupportedException);
-    void rewind() throw (Tools::NotSupportedException);
-    bool readPoint();
-protected:
-    liblas::LASReader* m_reader;
-    SpatialIndex::RTree::Data* m_pNext;
-    SpatialIndex::id_type m_id;
-public:
-private:
-    class Entry
-    public:
-        byte* m_pData;
-        size_t m_length;
-    }; // Entry
+#endif // LIBLAS_INDEX_INDEX_HPP_INCLUDED
Copied: trunk/include/liblas/index/storage.hpp (from r1273, /trunk/include/liblas/lasindex.hpp)
+++ trunk/include/liblas/index/storage.hpp	Wed May 20 15:56:34 2009
@@ -2,7 +2,7 @@
  * $Id$
+ * Purpose:  LAS indexing storage class
@@ -39,11 +39,8 @@
  * OF SUCH DAMAGE.
-#include <liblas/lasvariablerecord.hpp>
-#include <liblas/laspoint.hpp>
+#ifndef LIBLAS_INDEX_STORAGE_HPP_INCLUDED
+#define LIBLAS_INDEX_STORAGE_HPP_INCLUDED
@@ -56,136 +53,6 @@
 namespace liblas {
-class LASIndex
-public:
-    enum IndexType
-    LASIndex();
-    ~LASIndex();
-private:
-    bool m_idxExists;
-    void Setup();
-private:
-    size_t m_indexIO;
-    size_t m_leafIO;
-public:
-public:
-    bool readPoint();
-protected:
@@ -225,4 +92,4 @@
+#endif // LIBLAS_INDEX_STORAGE_HPP_INCLUDED
Copied: trunk/include/liblas/index/visitor.hpp (from r1273, /trunk/include/liblas/lasindex.hpp)
+++ trunk/include/liblas/index/visitor.hpp	Wed May 20 15:56:34 2009
@@ -39,11 +39,8 @@
  * OF SUCH DAMAGE.
+#ifndef LIBLAS_INDEX_VISITOR_HPP_INCLUDED
+#define LIBLAS_INDEX_VISITOR_HPP_INCLUDED
@@ -56,97 +53,6 @@
 namespace liblas {
-class LASIndex
-public:
-    enum IndexType
-    LASIndex();
-    ~LASIndex();
-private:
-    bool m_idxExists;
-    void Setup();
@@ -165,64 +71,8 @@
-public:
-    bool readPoint();
-protected:
-public:
-private:
-    class Entry
-    public:
-        byte* m_pData;
-        size_t m_length;
-    }; // Entry
+#endif // LIBLAS_INDEX_VISITOR_HPP_INCLUDED
More information about the Liblas-commits mailing list
