[Liblas-commits] r1122 - in trunk: include/liblas include/liblas/detail src src/detail
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Mar 19 21:31:43 EDT 2009
Author: mloskot
Date: Thu Mar 19 21:31:42 2009
New Revision: 1122
URL: http://liblas.org/changeset/1122
Fixed weakness of MakePIMPL by reverting changes applied as r984 and bringing m_pimpl back to constness. There is no need to re-create internal reader object and reassign it to m_pimpl, because reader state can be correctly reset by simple call of LASReader::Init. This fix is also related to Ticket #85. All 87 test cases pass.
   trunk/include/liblas/detail/reader.hpp
   trunk/include/liblas/lasreader.hpp
   trunk/src/detail/reader.cpp
   trunk/src/detail/reader10.cpp
   trunk/src/detail/reader11.cpp
   trunk/src/detail/reader12.cpp
   trunk/src/lasreader.cpp
Modified: trunk/include/liblas/detail/reader.hpp
--- trunk/include/liblas/detail/reader.hpp	(original)
+++ trunk/include/liblas/detail/reader.hpp	Thu Mar 19 21:31:42 2009
@@ -72,6 +72,7 @@
     std::istream& GetStream() const;
     bool ReadVLR(LASHeader& header);
     bool ReadGeoreference(LASHeader& header);
+    void Reset(LASHeader const& header);
     void SetSRS(const LASSRS& srs);
 protected:
@@ -80,19 +81,15 @@
     std::streamoff m_offset;
     uint32_t m_size;
     uint32_t m_current;
-    uint32_t m_recordlength;
-    void FillPoint(PointRecord& record, LASPoint& point);
-    void Project(LASPoint& point);
+    uint32_t m_recordlength;
     LASSRS m_out_srs;
-    LASSRS m_in_srs;
+    LASSRS m_in_srs;
     OGRCoordinateTransformationH m_transform;
     OGRSpatialReferenceH m_in_ref;
     OGRSpatialReferenceH m_out_ref;
+    void FillPoint(PointRecord& record, LASPoint& point);
+    void Project(LASPoint& point);
 private:
Modified: trunk/include/liblas/lasreader.hpp
--- trunk/include/liblas/lasreader.hpp	(original)
+++ trunk/include/liblas/lasreader.hpp	Thu Mar 19 21:31:42 2009
@@ -1,44 +1,44 @@
- * $Id$
- * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
- * Purpose:  LAS reader class
- * Author:   Mateusz Loskot, mateusz at loskot.net
- * Copyright (c) 2008, Mateusz Loskot
- * Copyright (c) 2008, Phil Vachon
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following
- * conditions are met:
- *     * Redistributions of source code must retain the above copyright
- *       notice, this list of conditions and the following disclaimer.
- *     * Redistributions in binary form must reproduce the above copyright
- *       notice, this list of conditions and the following disclaimer in
- *       the documentation and/or other materials provided
- *       with the distribution.
- *     * Neither the name of the Martin Isenburg or Iowa Department
- *       of Natural Resources nor the names of its contributors may be
- *       used to endorse or promote products derived from this software
- *       without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
- * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
- * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
- * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
- * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
- * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
- * OF SUCH DAMAGE.
+* $Id$
+* Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+* Purpose:  LAS reader class
+* Author:   Mateusz Loskot, mateusz at loskot.net
+* Copyright (c) 2008, Mateusz Loskot
+* Copyright (c) 2008, Phil Vachon
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+*     * Redistributions of source code must retain the above copyright
+*       notice, this list of conditions and the following disclaimer.
+*     * Redistributions in binary form must reproduce the above copyright
+*       notice, this list of conditions and the following disclaimer in
+*       the documentation and/or other materials provided
+*       with the distribution.
+*     * Neither the name of the Martin Isenburg or Iowa Department
+*       of Natural Resources nor the names of its contributors may be
+*       used to endorse or promote products derived from this software
+*       without specific prior written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
 #ifndef LIBLAS_LASREADER_HPP_INCLUDED
 #define LIBLAS_LASREADER_HPP_INCLUDED
@@ -63,29 +63,27 @@
     LASReader(std::istream& ifs);
     ~LASReader();
     std::size_t GetVersion() const;
     LASHeader const& GetHeader() const;
     LASPoint const& GetPoint() const;
     std::vector<LASVLR> const& GetVLRs() const;
+    /// Allow fetching of the stream
+    std::istream& GetStream() const;
+    bool IsEOF() const;
     bool ReadNextPoint();
     bool ReadPointAt(std::size_t n);
     bool ReadVLR();
+    void Reset();
-    // Reproject data as they are written if the LASWriter's reference is
-    // different than the LASHeader's
+    /// Reproject data as they are written if the LASWriter's reference is
+    /// different than the LASHeader's
     bool SetSRS(const LASSRS& ref);
-    // The operator is not const because it updates file stream position.
+    /// The operator is not const because it updates file stream position.
     LASPoint const& operator[](std::size_t n);
-    // Allow fetching of the stream
-    std::istream& GetStream() const;
-    bool Reset();
-    bool IsEOF() const;
 private:
     // Blocked copying operations, declared but not defined.
@@ -93,14 +91,11 @@
     LASReader& operator=(LASReader const& rhs);
     void Init(); // throws on error
-    void MakePIMPL(std::istream& ifs);
-    // TODO: Consider restoring const keyword and improving idea of re-assignment (see MakePIMPL).
-    std::auto_ptr<detail::Reader> m_pimpl;
+    const std::auto_ptr<detail::Reader> m_pimpl;
     LASHeader m_header;
     LASPoint m_point;
     std::vector<LASVLR> m_vlrs;
 } // namespace liblas
Modified: trunk/src/detail/reader.cpp
--- trunk/src/detail/reader.cpp	(original)
+++ trunk/src/detail/reader.cpp	Thu Mar 19 21:31:42 2009
@@ -67,20 +67,26 @@
 namespace liblas { namespace detail {
-Reader::Reader(std::istream& ifs) : m_ifs(ifs), m_offset(0), m_current(0), m_transform(0), m_in_ref(0), m_out_ref(0)
+Reader::Reader(std::istream& ifs) :
+    m_ifs(ifs), m_offset(0), m_size(0), m_current(0),
+    m_recordlength(0), m_transform(0),
+    m_in_ref(0), m_out_ref(0)
 Reader::~Reader()
 #ifdef HAVE_GDAL
-    if (m_transform) {
+    if (m_transform)
         OCTDestroyCoordinateTransformation(m_transform);
-    if (m_in_ref) {
+    if (m_in_ref)
         OSRDestroySpatialReference(m_in_ref);
-    if (m_out_ref) {
+    if (m_out_ref)
         OSRDestroySpatialReference(m_out_ref);
@@ -91,6 +97,7 @@
     return m_ifs;
 void Reader::FillPoint(PointRecord& record, LASPoint& point)
@@ -98,7 +105,10 @@
     point.SetY(record.y);
     point.SetZ(record.z);
-    if (m_transform) Project(point);
+    if (m_transform)
+        Project(point);
     point.SetIntensity(record.intensity);
     point.SetScanFlags(record.flags);
@@ -108,7 +118,6 @@
     point.SetPointSourceID(record.point_source_id);
 bool Reader::ReadVLR(LASHeader& header)
     VLRHeader vlrh = { 0 };
@@ -121,10 +130,10 @@
         read_n(vlrh, m_ifs, sizeof(VLRHeader));
         uint16_t length = vlrh.recordLengthAfterHeader;
-        if (length < 1) {
+        if (length < 1)
             throw std::domain_error("VLR record length must be at least 1 byte long");
         std::vector<uint8_t> data;
         data.resize(length);
@@ -140,13 +149,11 @@
         header.AddVLR(vlr);
     return true;
 bool Reader::ReadGeoreference(LASHeader& header)
     std::vector<LASVLR> vlrs;
     for (uint16_t i = 0; i < header.GetRecordsCount(); ++i)
@@ -154,16 +161,26 @@
         vlrs.push_back(record);
-    LASSRS srs(vlrs);
+    LASSRS srs(vlrs);
     header.SetSRS(srs);
     // keep a copy on the reader in case we're going to reproject data
     // on the way out.
     m_in_srs = srs;
     return true;
+void Reader::Reset(LASHeader const& header)
+    m_ifs.clear();
+    m_ifs.seekg(0);
+    // Reset sizes and set internal cursor to the beginning of file.
+    m_current = 0;
+    m_offset = header.GetDataOffset();
+    m_size = header.GetPointRecordsCount();
+    m_recordlength = header.GetDataRecordLength();
 void Reader::SetSRS(const LASSRS& srs)
@@ -205,15 +222,14 @@
     double y = point.GetY();
     double z = point.GetZ();
-    ret = OCTTransform(m_transform, 1, &x, &y, &z);
-    if (!ret) {
+    ret = OCTTransform(m_transform, 1, &x, &y, &z);
+    if (!ret)
         std::ostringstream msg;
         msg << "Could not project point for Reader::" << CPLGetLastErrorMsg() << ret;
         std::string message(msg.str());
         throw std::runtime_error(message);
     point.SetX(x);
     point.SetY(y);
@@ -223,7 +239,6 @@
 #endif
 Reader* ReaderFactory::Create(std::istream& ifs)
     if (!ifs)
Modified: trunk/src/detail/reader10.cpp
--- trunk/src/detail/reader10.cpp	(original)
+++ trunk/src/detail/reader10.cpp	Thu Mar 19 21:31:42 2009
@@ -207,9 +207,7 @@
     header.SetMax(x1, y1, z1);
     header.SetMin(x2, y2, z2);
-    m_offset = header.GetDataOffset();
-    m_size = header.GetPointRecordsCount();
-    m_recordlength = header.GetDataRecordLength();
+    Reset(header);
     return true;
Modified: trunk/src/detail/reader11.cpp
--- trunk/src/detail/reader11.cpp	(original)
+++ trunk/src/detail/reader11.cpp	Thu Mar 19 21:31:42 2009
@@ -211,9 +211,7 @@
+    Reset(header);
     return true;
Modified: trunk/src/detail/reader12.cpp
--- trunk/src/detail/reader12.cpp	(original)
+++ trunk/src/detail/reader12.cpp	Thu Mar 19 21:31:42 2009
@@ -217,9 +217,7 @@
+    Reset(header);
     return true;
Modified: trunk/src/lasreader.cpp
--- trunk/src/lasreader.cpp	(original)
+++ trunk/src/lasreader.cpp	Thu Mar 19 21:31:42 2009
@@ -53,9 +53,10 @@
 namespace liblas
-LASReader::LASReader(std::istream& ifs)
+LASReader::LASReader(std::istream& ifs) :
+    m_pimpl(detail::ReaderFactory::Create(ifs))
-    MakePIMPL(ifs);
+    //MakePIMPL(ifs);
     Init();
@@ -82,19 +83,13 @@
 bool LASReader::ReadNextPoint()
-    bool ret = false;
-    ret = m_pimpl->ReadNextPoint(m_point, m_header);
+    bool ret = m_pimpl->ReadNextPoint(m_point, m_header);
     return ret;
 bool LASReader::ReadPointAt(std::size_t n)
-    bool ret = false;
-    ret = m_pimpl->ReadPointAt(n, m_point, m_header);
+    bool ret = m_pimpl->ReadPointAt(n, m_point, m_header);
     return ret;
@@ -105,37 +100,27 @@
         throw std::out_of_range("point subscript out of range");
-    bool ret = false;
     if (!ret)
         throw std::out_of_range("no point record at given position");
     return m_point;
-void LASReader::MakePIMPL(std::istream& ifs)
-    m_pimpl = std::auto_ptr<detail::Reader>( detail::ReaderFactory::Create(ifs) );
 void LASReader::Init()
     bool ret = m_pimpl->ReadHeader(m_header);
     if (!ret)
         throw std::runtime_error("public header block reading failure");
     ret = m_pimpl->ReadVLR(m_header);
     if (!ret)
         throw std::runtime_error("public vlr header block reading failure");
     m_pimpl->ReadGeoreference(m_header);
+    m_pimpl->Reset(m_header);
 std::istream& LASReader::GetStream() const
@@ -143,14 +128,9 @@
     return m_pimpl->GetStream();
-bool LASReader::Reset()
+void LASReader::Reset()
-    std::istream& ifs = GetStream();
-    ifs.clear();
-    ifs.seekg(0);
-    MakePIMPL(ifs);
-	Init();
-    return true;
+    Init();
 bool LASReader::IsEOF() const
More information about the Liblas-commits mailing list
