[Liblas-commits] hg: 2 new changesets
    liblas-commits at liblas.org
    Tue Nov 24 13:06:41 EST 2009
changeset 662246d734c4 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=662246d734c4
summary: rework srid/solid/3d interactions
changeset c58362f937df in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=c58362f937df
summary: merge
diffstat:
 apps/las2oci.cpp                    |  464 +++++++++++++++++++++++++++++---------
 include/liblas/index/datastream.hpp |    2 +-
 src/index/datastream.cpp            |    2 +-
 3 files changed, 355 insertions(+), 113 deletions(-)
diffs (truncated from 668 to 300 lines):
diff -r 9380e733d922 -r c58362f937df apps/las2oci.cpp
--- a/apps/las2oci.cpp	Thu Nov 12 09:03:02 2009 -0600
+++ b/apps/las2oci.cpp	Tue Nov 24 12:03:11 2009 -0600
@@ -146,7 +146,22 @@
     oss << "DELETE from " <<cloudTableName;
     statement = Run(connection, oss);
-    if (statement != 0) delete statement; else return false;
+    if (statement != 0) delete statement; else
+        // if we failed, try dropping the index
+        std::cout << "Dropping index ..." << std::endl;
+        oss.str("");
+        oss << "DROP INDEX "<<tableName<<"_cloud_idx" ;
+        statement = Run(connection, oss);
+        if (statement != 0) delete statement; else return false;
+        oss.str("");
+        // redelete from the table
+        oss << "DELETE from " <<cloudTableName;
+        oss.str("");
     oss.str("");
     std::string cloudColumnName_l = std::string(cloudColumnName);
@@ -181,7 +196,9 @@
     oss << "DELETE FROM USER_SDO_GEOM_METADATA WHERE TABLE_NAME='"<<table<<"'" ;
-    oss.str("");
+    oss.str("");
     return true;
@@ -308,7 +325,8 @@
                 const char* tableName,
                 long precision,
                 long pc_id,
-                bool bUseSolidGeometry)
+                bool bUseSolidGeometry,
+                bool bUse3d)
     ostringstream oss;
@@ -320,38 +338,81 @@
     ostringstream s_srid;
     ostringstream s_gtype;
     ostringstream s_eleminfo;
-    bool bUse3d = true;
-    bool bGeographic = true;
+    bool bGeographic = false;
     if (srid == 0) {
         s_srid << "NULL";
-        bUse3d = true;
-        bUseSolidGeometry = true;
+        // bUse3d = true;
+        // bUseSolidGeometry = true;
     else if (srid == 4326) {
-        bUse3d = true;
+        // bUse3d = true;
         bGeographic = true;
-        s_srid << "NULL";
+        s_srid << srid;
+        // s_srid << "NULL";
     else {
         s_srid << srid;
-        bUse3d = false;
+        // bUse3d = false;
         // If the user set an srid and set it to solid, we're still 3d
-        if (bUseSolidGeometry == true)
-            bUse3d = true;
+        // if (bUseSolidGeometry == true)
+        //     bUse3d = true;
-    if (bUseSolidGeometry == true) {
-        s_gtype << "3008";
-        s_eleminfo << "(1,1007,3)";
+    if (bUse3d) {
+        if (bUseSolidGeometry == true) {
+            s_gtype << "3008";
+            s_eleminfo << "(1,1007,3)";
+        } else {
+            s_gtype << "3003";
+            s_eleminfo  << "(1,1003,3)";
     } else {
-        s_gtype << "3003";
-        s_eleminfo  << "(1,1003,3)";
+            s_gtype << "2008";
+        } else {
+            s_gtype << "2003";
+    double x0, x1, y0, y1, z0, z1;
+    double tolerance = 0.05;
+    x0 = b->getLow(0);
+    x1 = b->getHigh(0);
+    y0 = b->getLow(1);
+    y1 = b->getHigh(1);
+    if (bUse3d) {
+        try {
+            z0 = b->getLow(2);
+            z1 = b->getHigh(2);
+        } catch (Tools::IndexOutOfBoundsException& e) {
+            z0 = 0;
+            z1 = 20000;
+    } else if (bGeographic) {
+        x0 = -180.0;
+        x1 = 180.0;
+        y0 = -90.0;
+        y1 = 90.0;
+        z0 = 0.0;
+        z1 = 20000.0;
+        tolerance = 0.000000005;
+    } else {
+        z0 = 0.0;
+        z1 = 20000.0;
     // std::cout << "use 3d?: " << bUse3d << " srid: " << s_srid.str() << std::endl;
     oss_geom.setf(std::ios_base::fixed, std::ios_base::floatfield);
     oss_geom.precision(precision);
@@ -360,27 +421,20 @@
 "              mdsys.sdo_elem_info_array"<< s_eleminfo.str() <<",\n"
 "              mdsys.sdo_ordinate_array(\n";
-    oss_geom << b->getLow(0) <<","<<
-                                            b->getLow(1) <<",";
+    oss_geom << x0 << ",\n" << y0 << ",\n";
     if (bUse3d) {
-        if (!bGeographic) {
-            oss_geom <<                         b->getLow(2) <<",";
-        } else {
-            oss_geom <<"0,";
+        oss_geom << z0 << ",\n";
-    oss_geom <<                             b->getHigh(0) <<","<<
-                                            b->getHigh(1);
+    oss_geom << x1 << ",\n" << y1 << "\n";
     if (bUse3d) {
-            oss_geom                            <<","<< b->getHigh(2);
-        } else {
-            oss_geom <<",20000";
+        oss_geom << ",\n";
+        oss_geom << z1;
     oss_geom << "))";
     oss << "INSERT INTO "<< tableName <<
             "(OBJ_ID, BLK_ID, NUM_POINTS, BLK_EXTENT, POINTS, PCBLK_MIN_RES, PCBLK_MAX_RES, NUM_UNSORTED_POINTS, PT_SORT_DIM) VALUES ( "
@@ -447,7 +501,15 @@
                         LASQuery* query,
                         long srid,
                         long precision,
+                        bool bUse3d,
+                        bool bSetExtents,
+                        double xmin,
+                        double xmax,
+                        double ymin,
+                        double ymax,
+                        double zmin,
+                        double zmax)
     ostringstream oss;
     OWStatement* statement = 0;
@@ -456,48 +518,73 @@
     oss.setf(std::ios_base::fixed, std::ios_base::floatfield);
     oss.precision(precision);
-    bool bUse3d = false;
-        bUse3d = true;
+    // if (bUseSolidGeometry == true) {
+    //     bUse3d = true;
     if (srid == 0) {
         s_srid << "NULL";
-        bUse3d = true;
+        // bUse3d = true;
-    else if (srid == 4326) {
-        s_srid << "NULL";
-        bUse3d = true;
-        bGeographic = true;
-    } else {
+    // else if (srid == 4326) {
+    //     // bUse3d = true;
+    //     bGeographic = true;
+    else {
         s_srid << srid;
+    if (bSetExtents){
+        x0 = xmin; x1 = xmax;
+        y0 = ymin; y1 = ymax;
+        z0 = zmin; z1 = zmax;
+    } else {
+        x0 = query->bounds.getLow(0);
+        x1 = query->bounds.getHigh(0);
+        y0 = query->bounds.getLow(1);
+        y1 = query->bounds.getHigh(1);
+        if (bUse3d) {
+            try {
+                z0 = query->bounds.getLow(2);
+                z1 = query->bounds.getHigh(2);
+                z0 = 0;
+                z1 = 20000;
+            x0 = -180.0;
+            x1 = 180.0;
+            y0 = -90.0;
+            y1 = 90.0;
+            z0 = 0.0;
+            z1 = 20000.0;
+        } else {
+            z0 = 0.0;
+            z1 = 20000.0;
     oss <<  "INSERT INTO user_sdo_geom_metadata VALUES ('" << tableName <<
         "','blk_extent', MDSYS.SDO_DIM_ARRAY(";
-    if (bGeographic == true) {
-        oss << "MDSYS.SDO_DIM_ELEMENT('X', -180, 180, .000000005),"
-               "MDSYS.SDO_DIM_ELEMENT('Y', -180, 180, .000000005)";
-    } else {
-        oss << "MDSYS.SDO_DIM_ELEMENT('X', "<< query->bounds.getLow(0) <<","<< query->bounds.getHigh(0)<<",0.05),"
-            "MDSYS.SDO_DIM_ELEMENT('Y', "<< query->bounds.getLow(1) <<","<< query->bounds.getHigh(1)<<",0.05)";
-            // "MDSYS.SDO_DIM_ELEMENT('X', "<< query->bounds.getLow(0) <<","<< query->bounds.getHigh(0)<<",0.05),"
-            // "MDSYS.SDO_DIM_ELEMENT('Y', "<< query->bounds.getLow(1) <<","<< query->bounds.getHigh(1)<<",0.05)";
+    oss << "MDSYS.SDO_DIM_ELEMENT('X', " << x0 << "," << x1 <<"," << tolerance << "),"
+           "MDSYS.SDO_DIM_ELEMENT('Y', " << y0 << "," << y1 <<"," << tolerance << ")";
     if (bUse3d) {
         oss << ",";
-        if (bGeographic)
-            oss <<"MDSYS.SDO_DIM_ELEMENT('Z', "<< 0 <<","<< 200000<<",0.000000005)";
-        else
-            oss << "MDSYS.SDO_DIM_ELEMENT('Z', "<< query->bounds.getLow(2) <<","<< query->bounds.getHigh(2)<<",0.00000005)";
+        oss <<"MDSYS.SDO_DIM_ELEMENT('Z', "<< z0 << "," << z1 << "," << tolerance << ")";
     oss << ")," << s_srid.str() << ")";
@@ -512,24 +599,24 @@
More information about the Liblas-commits
