[Liblas-commits] hg: add hgignore
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Oct 2 10:23:03 EDT 2009
changeset 88cbde565cd5 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=88cbde565cd5
summary: add hgignore
diffstat:
 .hgignore |  47 +++++++++++++++++++++++++++++++++++++++++++++++
 1 files changed, 47 insertions(+), 0 deletions(-)
diffs (52 lines):
diff -r be75b07d66d2 -r 88cbde565cd5 .hgignore
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/.hgignore	Fri Oct 02 09:20:25 2009 -0500
@@ -0,0 +1,47 @@
+syntax: glob
+*.la
+*.lo
+*.o
+*.obj
+.deps
+.libs
+*.exe
+*.exp
+*.lib
+aclocal.m4
+apps/las2las
+apps/las2txt
+apps/lasinfo
+apps/lasmerge
+apps/liblas-config
+apps/ts2las
+apps/txt2las
+apps/las2oci
+apps/las2ogr
+apps/lasindex
+autom4te.cache
+config.guess
+config.log
+config.status
+config.sub
+configure
+depcomp
+install-sh
+libtool
+liblas_test
+ltmain.sh
+missing
+Makefile
+Makefile.in
+build.hobu
+test/data/*.dat
+test/data/*.idx
+python/build/*
+python/dist/*
+python/libLAS.egg-info/*
+*.pyc
+src/CMakeFiles
+CMakeFiles
+CMakeCache.txt
+cmake_install.cmake
+src/liblas.a
\ No newline at end of file
More information about the Liblas-commits mailing list
