[Liblas-commits] hg: 3 new changesets
    liblas-commits at liblas.org
    Fri Oct  2 19:27:51 EDT 2009
changeset ccdc1ec53425 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=ccdc1ec53425
summary: Updated dot-hgignore file
changeset bda24d7e6383 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=bda24d7e6383
summary: [cmake] Added unit test suite to CMake configuration (Ticket #52)
changeset 9110441400b4 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=9110441400b4
summary: Fixed bug of GDAL calls not guarded with HAVE_GDAL (Ticket #150)
diffstat:
 .hgignore                |  17 +++++++++--------
 CMakeLists.txt           |   5 +++++
 src/detail/writer.cpp    |   8 ++++----
 test/CMakeLists.txt      |   9 ++++++---
 test/unit/CMakeLists.txt |  26 +++++++++++++-------------
 5 files changed, 37 insertions(+), 28 deletions(-)
diffs (169 lines):
diff -r f3bde1e79871 -r 9110441400b4 .hgignore
--- a/.hgignore	Fri Oct 02 09:26:16 2009 -0500
+++ b/.hgignore	Sat Oct 03 00:27:40 2009 +0100
@@ -1,15 +1,17 @@
 syntax: glob
+.deps
+.libs
+*.dll
+*.exe
+*.exp
 *.la
+*.lib
 *.lo
 *.o
 *.obj
-.deps
-.libs
-*.exe
-*.exp
-*.lib
+*.pyc
 *.res
-*.dll
+*.swp
 aclocal.m4
 apps/las2las
 apps/las2txt
@@ -41,9 +43,8 @@
 python/build/*
 python/dist/*
 python/libLAS.egg-info/*
-*.pyc
 src/CMakeFiles
 CMakeFiles
 CMakeCache.txt
 cmake_install.cmake
-src/liblas.a
\ No newline at end of file
+src/liblas.a
diff -r f3bde1e79871 -r 9110441400b4 CMakeLists.txt
--- a/CMakeLists.txt	Fri Oct 02 09:26:16 2009 -0500
+++ b/CMakeLists.txt	Sat Oct 03 00:27:40 2009 +0100
@@ -18,6 +18,9 @@
 # Name of C library
 SET(LIBLAS_C_LIB_NAME las_c)
+# Name of test suite runner
+SET(LIBLAS_UNIT_TEST liblas_test)
 # Choose package components
 SET(WITH_UTILITIES TRUE CACHE BOOL "Choose if libLAS utilities should be built")
 SET(WITH_TESTS FALSE CACHE BOOL "Choose if libLAS unit tests should be built")
@@ -228,9 +231,11 @@
 ADD_SUBDIRECTORY(src)
 IF(WITH_UTILITIES)
+    MESSAGE(STATUS "Adding libLAS utilities to build - done")
     ADD_SUBDIRECTORY(apps)
 ENDIF()
 IF(WITH_TESTS)
+    MESSAGE(STATUS "Adding libLAS unit test suite to build - done")
     ADD_SUBDIRECTORY(test)
 ENDIF()
diff -r f3bde1e79871 -r 9110441400b4 src/detail/writer.cpp
--- a/src/detail/writer.cpp	Fri Oct 02 09:26:16 2009 -0500
+++ b/src/detail/writer.cpp	Sat Oct 03 00:27:40 2009 +0100
@@ -180,8 +180,9 @@
     m_in_srs = srs;
-void Writer::CreateTransform(){
+void Writer::CreateTransform()
+#ifdef HAVE_GDAL
     if (m_transform)
         OCTDestroyCoordinateTransformation(m_transform);
@@ -195,7 +196,6 @@
         OSRDestroySpatialReference(m_out_ref);
-#ifdef HAVE_GDAL
     m_in_ref = OSRNewSpatialReference(0);
     m_out_ref = OSRNewSpatialReference(0);
@@ -218,7 +218,6 @@
     m_transform = OCTNewCoordinateTransformation( m_in_ref, m_out_ref);
 #endif
@@ -247,6 +246,7 @@
     detail::ignore_unused_variable_warning(p);
 #endif
 Writer* WriterFactory::Create(std::ostream& ofs, LASHeader const& header)
     if (!ofs)
diff -r f3bde1e79871 -r 9110441400b4 test/CMakeLists.txt
--- a/test/CMakeLists.txt	Fri Oct 02 09:26:16 2009 -0500
+++ b/test/CMakeLists.txt	Sat Oct 03 00:27:40 2009 +0100
@@ -1,5 +1,8 @@
-# $Id$
-# List of test and sample programs subprojects
+# test/CMakeLists.txt controls building of libLAS tests
-SUBDIRS( unit )
+# Copyright (c) 2009 Mateusz Loskot <mateusz at loskot.net>
+SUBDIRS(unit)
diff -r f3bde1e79871 -r 9110441400b4 test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt	Fri Oct 02 09:26:16 2009 -0500
+++ b/test/unit/CMakeLists.txt	Sat Oct 03 00:27:40 2009 +0100
@@ -1,10 +1,13 @@
-# $Id$
-# Build libLAS unit test suite
+# test/unit/CMakeLists.txt controls building of libLAS unit tests suite
-SET( LIBLAS_TEST liblas_test )
-SET( LIBLAS_TEST_SRC
+SET(LIBLAS_UNIT_TEST_SRC
     common.cpp
     guid_test.cpp
     laserror_test.cpp
@@ -16,23 +19,20 @@
     lasspatialreference_test.cpp
     lasvariablerecord_test.cpp
     laswriter_test.cpp
-    liblas_test_suite.cpp
+    liblas_test_suite.cpp)
 INCLUDE_DIRECTORIES(
     ../../include
     ${GDAL_INCLUDE_DIR}
-    ${GEOTIFF_INCLUDE_DIR}
+    ${GEOTIFF_INCLUDE_DIR})
-ADD_EXECUTABLE( ${LIBLAS_TEST} ${LIBLAS_TEST_SRC} )
+ADD_EXECUTABLE(${LIBLAS_UNIT_TEST} ${LIBLAS_UNIT_TEST_SRC})
-TARGET_LINK_LIBRARIES( ${LIBLAS_TEST}
+TARGET_LINK_LIBRARIES(${LIBLAS_UNIT_TEST}
     ${LIBLAS_LIB_NAME}
 	${GDAL_LIBRARY}
-	${GEOTIFF_LIBRARY}
+	${GEOTIFF_LIBRARY})
 # TODO: Needs to tweak the executable path
-ADD_TEST(liblas_test ${EXECUTABLE_OUTPUT_PATH}/liblas_test)
+ADD_TEST(liblas_test ${EXECUTABLE_OUTPUT_PATH}/liblas_test ${CMAKE_SOURCE_DIR}/test/data)
More information about the Liblas-commits
