[Liblas-commits] hg: add pre- and post-sql methods
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Oct 14 13:49:19 EDT 2009
changeset 5a13b5fc940a in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=5a13b5fc940a
summary: add pre- and post-sql methods
diffstat:
 apps/las2oci.cpp |  53 ++++++++++++++++++++++++++++++++++++++++++++++++++---
 1 files changed, 50 insertions(+), 3 deletions(-)
diffs (100 lines):
diff -r 487723ab179f -r 5a13b5fc940a apps/las2oci.cpp
--- a/apps/las2oci.cpp	Tue Oct 13 21:25:48 2009 -0500
+++ b/apps/las2oci.cpp	Wed Oct 14 12:46:35 2009 -0500
@@ -523,7 +523,8 @@
     fprintf(stderr,"--cloud-table-name: (-cn) \n");
     fprintf(stderr,"--overwrite: (-d) \n");
     fprintf(stderr,"--srid: (-s) \n");
+    fprintf(stderr,"--pre-sql: (-prs) \"CREATE TABLE BASE (id number, cloud mdsys.sdo_pc)\" \n");
+    fprintf(stderr,"--post-sql: (-prs) \"UPDATE TABLE BASE SET ID=1\" \n");
     fprintf(stderr,"las2oci -i output.las lidar/lidar at oraclemachine/instance \n"
                    "--block-table-name  hobu_blocks --base-table-name hobu_base\n"
@@ -566,6 +567,9 @@
     std::string base_table_name("HOBU");
     std::string block_table_name("");
+    std::string pre_sql("");
+    std::string post_sql("");
     bool bUseExistingBlockTable = false;
     bool bDropTable = false;
     liblas::uint32_t nCapacity = 10000;
@@ -595,7 +599,6 @@
                     strcmp(argv[i],"-d") == 0
-            i++;
             bDropTable=true;
         else if (   strcmp(argv[i],"--blk_capacity") == 0  ||
@@ -641,9 +644,22 @@
             i++;
-            printf("have bk");
             block_table_name = std::string(argv[i]);
+        else if (   strcmp(argv[i],"--pre-sql") == 0  ||
+                    strcmp(argv[i],"-prs") == 0
+            i++;
+            pre_sql = std::string(argv[i]);
+        else if (   strcmp(argv[i],"--post-sql") == 0  ||
+                    strcmp(argv[i],"-pos") == 0
+            i++;
+            post_sql = std::string(argv[i]);
         else if (input.empty())
             input = std::string(argv[i]);
@@ -721,6 +737,21 @@
         DeleteTable(con, table_name.c_str(), base_table_name.c_str(), point_cloud_name.c_str());
+    if (!pre_sql.empty()) {
+        std::cout << "running pre-sql ..." << std::endl;
+        ostringstream oss;
+        oss << pre_sql;
+        OWStatement* statement = 0;
+        statement = Run(con, oss);
+        if (statement != 0) {
+            delete statement;
+        else {
+            std::cout << "pre-sql execution failed.." << std::endl;
+            return false;
+        oss.str("");
     if (!BlockTableExists(con, table_name.c_str()))
         CreateBlockTable(con, table_name.c_str());
     else {
@@ -773,6 +804,22 @@
                     nCapacity);
+    if (!post_sql.empty()) {
+        std::cout << "running post-sql ..." << std::endl;
+        oss << pre_sql;
+            delete statement;
+        else {
+            std::cout << "post-sql execution failed.." << std::endl;
+            return false;
+        oss.str("");
More information about the Liblas-commits mailing list
