[Liblas-commits] hg: tweaks again
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Oct 19 15:40:19 EDT 2009
changeset c69ff73c7a79 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=c69ff73c7a79
summary: tweaks again
diffstat:
 python/scripts/oci2las.py |  16 ++++++++++------
 1 files changed, 10 insertions(+), 6 deletions(-)
diffs (39 lines):
diff -r 7f1aaecce916 -r c69ff73c7a79 python/scripts/oci2las.py
--- a/python/scripts/oci2las.py	Mon Oct 19 14:20:23 2009 -0500
+++ b/python/scripts/oci2las.py	Mon Oct 19 15:38:07 2009 -0400
@@ -129,6 +129,7 @@
         for i in xrange(num_points):
             rng = ptsize*i,ptsize*(i+1)
+            print num_points, len(blob)
             d = struct.unpack(format,blob[ptsize*i:ptsize*(i+1)])
             x, y, z, blk_id, pt_id = d
             p = point.Point()
@@ -214,12 +215,15 @@
         # write an actual cloud column
         for cloud in clouds:
-            self.cur.execute('SELECT NUM_POINTS, POINTS FROM %s'% cloud.BLK_TABLE)
-            blocks = self.cur.fetchall()
+            cur2 = self.con.cursor()
+            cur2.execute('SELECT NUM_POINTS, POINTS FROM %s'% cloud.BLK_TABLE)
-            for block in blocks:
-                num_points, blob = block[0], block[1].read()
-                points.append(self.get_points(num_points,blob))
+            for num_points, blob in cur2:
+#                num_points, blob = block[0], block[1].read()
+#                print num_points, blob
+                b = blob.read()
+                points.append(self.get_points(num_points,b))
         num_pts_index, blob_index = self.get_block_indexes(self.cur)
@@ -267,4 +271,4 @@
     d.process()
 if __name__=='__main__':
-    main()
\ No newline at end of file
+    main()
More information about the Liblas-commits mailing list
