[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Oct 19 17:00:47 EDT 2009
changeset 27b8d7c94396 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=27b8d7c94396
summary: Updated .hgignore patterns with Windows/Visual C++ specific files.
changeset 2f33d0723e98 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=2f33d0723e98
summary: Added support for OSGEO4W_ROOT to CMake macros.
diffstat:
 .hgignore                          |  11 +++++
 build/cmake/FindGDAL.cmake         |  28 +++++++++++--
 build/cmake/FindGeoTIFF.cmake      |  72 +++++++++++++----------------------
 build/cmake/FindSpatialIndex.cmake |  16 +++++--
 4 files changed, 72 insertions(+), 55 deletions(-)
diffs (236 lines):
diff -r a11bf44844f7 -r 2f33d0723e98 .hgignore
--- a/.hgignore	Mon Oct 19 21:02:24 2009 +0100
+++ b/.hgignore	Mon Oct 19 22:00:35 2009 +0100
@@ -1,20 +1,29 @@
 syntax: glob
 .deps
 .libs
 *.dll
+*.embed.manifest
 *.exe
 *.exp
+*.idb
+*.ilk
+*.intermediate.manifest
 *.la
 *.lib
 *.lo
+*.ncb
 *.o
 *.obj
+*.pdb
 *.pyc
 *.res
+*.suo
 *.swp
 *.bz2
 *.gz
 *.orig
+*.user
 aclocal.m4
 apps/las2las
 apps/las2txt
@@ -51,3 +60,5 @@
 CMakeCache.txt
 cmake_install.cmake
 src/liblas.a
+Debug
+Release
diff -r a11bf44844f7 -r 2f33d0723e98 build/cmake/FindGDAL.cmake
--- a/build/cmake/FindGDAL.cmake	Mon Oct 19 21:02:24 2009 +0100
+++ b/build/cmake/FindGDAL.cmake	Mon Oct 19 22:00:35 2009 +0100
@@ -14,11 +14,21 @@
 MESSAGE(STATUS "Searching for GDAL ${GDAL_FIND_VERSION}+ library")
+MESSAGE(STATUS "   NOTE: Required version is not checked - to be implemented")
 SET(GDAL_NAMES gdal)
 IF(WIN32)
+    SET(OSGEO4W_IMPORT_LIBRARY gdal_i)
+    IF($ENV{OSGEO4W_ROOT})
+        SET(OSGEO4W_ROOT_DIR $ENV{OSGEO4W_ROOT})
+        MESSAGE(STATUS "Trying OSGeo4W using environment variable OSGEO4W_ROOT=$ENV{OSGEO4W_ROOT}")
+    ELSE()
+        SET(OSGEO4W_ROOT_DIR c:/OSGeo4W)
+        MESSAGE(STATUS "Trying OSGeo4W using default location OSGEO4W_ROOT=${OSGEO4W_ROOT_DIR}")
+    ENDIF()
     IF(MINGW)
         FIND_PATH(GDAL_INCLUDE_DIR
             gdal.h
@@ -26,7 +36,8 @@
             PATHS
             /usr/local/include
             /usr/include
-            c:/msys/local/include)
+            c:/msys/local/include
+            ${OSGEO4W_ROOT_DIR}/include)
         FIND_LIBRARY(GDAL_LIBRARY
             NAMES ${GDAL_NAMES}
@@ -34,21 +45,28 @@
             PATHS
             /usr/local/lib
             /usr/lib
-            c:/msys/local/lib)
+            c:/msys/local/lib
+            ${OSGEO4W_ROOT_DIR}/lib)
     ENDIF(MINGW)
     IF(MSVC)
-        SET(GDAL_INCLUDE_DIR "$ENV{LIB_DIR}/include/gdal" CACHE STRING INTERNAL)
+        FIND_PATH(GDAL_INCLUDE_DIR
+            NAMES gdal.h
+            PATH_PREFIXES gdal gdal-1.6
+            PATHS
+            "$ENV{LIB_DIR}/include/gdal"
-        SET(GDAL_NAMES ${GDAL_NAMES} gdal_I)
+        SET(GDAL_NAMES ${OSGEO4W_IMPORT_LIBRARY} ${GDAL_NAMES})
             NAMES ${GDAL_NAMES}
             PATHS
             "$ENV{LIB_DIR}/lib"
             /usr/lib
+            c:/msys/local/lib
         IF(GDAL_LIBRARY)
             SET(GDAL_LIBRARY;odbc32;odbccp32 CACHE STRING INTERNAL)
diff -r a11bf44844f7 -r 2f33d0723e98 build/cmake/FindGeoTIFF.cmake
--- a/build/cmake/FindGeoTIFF.cmake	Mon Oct 19 21:02:24 2009 +0100
+++ b/build/cmake/FindGeoTIFF.cmake	Mon Oct 19 22:00:35 2009 +0100
@@ -17,61 +17,43 @@
 # For details see the accompanying COPYING-CMAKE-SCRIPTS file.
+MESSAGE(STATUS "Searching for GeoTIFF ${GeoTIFF_FIND_VERSION}+ library")
-SET(GEOTIFF_NAMES geotiff)
+IF(GEOTIFF_INCLUDE_DIR)
+    # Already in cache, be silent
+    SET(GEOTIFF_FIND_QUIETLY TRUE)
+ENDIF()
 IF(WIN32)
+    SET(OSGEO4W_IMPORT_LIBRARY geotiff_i)
+    ELSE()
+    ENDIF()
+ENDIF()
+FIND_PATH(GEOTIFF_INCLUDE_DIR
+    geotiff.h
+    PATH_PREFIXES geotiff
+    PATHS
-    IF(MINGW)
-        FIND_PATH(GEOTIFF_INCLUDE_DIR
-            geotiff.h
-            PATH_PREFIXES geotiff
-            PATHS
-            /usr/local/include
-            /usr/include
+SET(GEOTIFF_NAMES ${OSGEO4W_IMPORT_LIBRARY} geotiff)
-        FIND_LIBRARY(GEOTIFF_LIBRARY
-            NAMES ${GEOTIFF_NAMES}
-            PATHS
-            /usr/local/lib
-            /usr/lib
-    ENDIF(MINGW)
-    IF(MSVC)
-            geotiff.h
-            PATHS
-            "$ENV{LIB_DIR}/include"
-            c:/OSGeo4W/include
-        SET(GEOTIFF_NAMES ${GEOTIFF_NAMES} geotiff_i)
-        FIND_LIBRARY(GEOTIFF_LIBRARY NAMES
-            PATHS
-            "$ENV{LIB_DIR}/lib"
-            c:/OSGeo4W/lib
-    ENDIF(MSVC)
-ELSEIF(UNIX)
-    FIND_PATH(GEOTIFF_INCLUDE_DIR geotiff.h PATH_PREFIXES geotiff)
-    FIND_LIBRARY(GEOTIFF_LIBRARY NAMES ${GEOTIFF_NAMES})
-ELSE()
-    MESSAGE("FindGeoTIFF.cmake: unrecognized or unsupported operating system")
-ENDIF()
+FIND_LIBRARY(GEOTIFF_LIBRARY
+    NAMES ${GEOTIFF_NAMES}
+    PATHS
 IF(GEOTIFF_FOUND)
   SET(GEOTIFF_LIBRARIES ${GEOTIFF_LIBRARY})
 ENDIF()
-# Handle the QUIETLY and REQUIRED arguments and set SPATIALINDEX_FOUND to TRUE
+# Handle the QUIETLY and REQUIRED arguments and set GEOTIFF_FOUND to TRUE
 # if all listed variables are TRUE
 INCLUDE(FindPackageHandleStandardArgs)
 FIND_PACKAGE_HANDLE_STANDARD_ARGS(GEOTIFF DEFAULT_MSG GEOTIFF_LIBRARY GEOTIFF_INCLUDE_DIR)
diff -r a11bf44844f7 -r 2f33d0723e98 build/cmake/FindSpatialIndex.cmake
--- a/build/cmake/FindSpatialIndex.cmake	Mon Oct 19 21:02:24 2009 +0100
+++ b/build/cmake/FindSpatialIndex.cmake	Mon Oct 19 22:00:35 2009 +0100
@@ -20,22 +20,28 @@
     SET(SPATIALINDEX_FIND_QUIETLY TRUE)
 ENDIF()
-IF(MSVC)
+IF(WIN32)
     SET(OSGEO4W_IMPORT_LIBRARY spatialindex_i)
-    SET(DEFAULT_OSGEO4W_HOME_DIR c:/OSGeo4W)
+    ELSE()
+    ENDIF()
 ENDIF()
 FIND_PATH(SPATIALINDEX_INCLUDE_DIR
     NAMES RTree.h
     PATH_PREFIXES spatialindex
     PATHS
-    ${DEFAULT_OSGEO4W_HOME_DIR}/include)
-SET(SPATIALINDEX_NAMES spatialindex ${OSGEO4W_IMPORT_LIBRARY})
+SET(SPATIALINDEX_NAMES ${OSGEO4W_IMPORT_LIBRARY} spatialindex)
 FIND_LIBRARY(SPATIALINDEX_LIBRARY
     NAMES ${SPATIALINDEX_NAMES}
     PATHS
-    ${DEFAULT_OSGEO4W_HOME_DIR}/lib)
More information about the Liblas-commits mailing list
