[Liblas-commits] hg: default srid to 0, and when it is 0, use 2d for indexs, bloc...
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Oct 22 11:17:20 EDT 2009
changeset 6825f3771a59 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=6825f3771a59
summary: default srid to 0, and when it is 0, use 2d for indexs, block entries, but 3d still for PC creation
diffstat:
 apps/las2oci.cpp |  149 ++++++++++++++++++++++++++++++++++---------------
 1 files changed, 104 insertions(+), 45 deletions(-)
diffs (273 lines):
diff -r 21a88d859fb2 -r 6825f3771a59 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Wed Oct 21 15:52:29 2009 -0500
+++ b/apps/las2oci.cpp	Thu Oct 22 10:14:13 2009 -0500
@@ -84,38 +84,18 @@
     oss << "DELETE FROM " << tableName;
     statement = Run(connection, oss);
-    if (statement != 0) delete statement; else return false;
+    if (statement != 0) delete statement;
     oss.str("");
     oss << "DROP TABLE " << tableName;
     cout << oss.str() << endl;
-    oss.str("");
-    oss << "DROP TABLE BLKTAB ";
-    statement = Run(connection, oss);
-    oss.str("");
-    oss << "DROP TABLE RES ";
-    oss.str("");
-    oss << "DROP TABLE INPTAB ";
-    oss.str("");
-    oss << "DROP TABLE LIDAR_DATA";
-    oss.str("");
+    oss.str("");
     oss << "DELETE FROM USER_SDO_GEOM_METADATA WHERE TABLE_NAME='"<< tableName << "'";
     oss.str("");
     return true;
@@ -141,7 +121,10 @@
-bool DeleteTable(OWConnection* connection, const char* tableName, const char* cloudTableName, const char* cloudColumnName)
+bool DeleteTable(   OWConnection* connection,
+                    const char* tableName,
+                    const char* cloudTableName,
+                    const char* cloudColumnName)
     ostringstream oss;
     OWStatement* statement = 0;
@@ -187,7 +170,9 @@
     return true;
-bool GetPointData(LASPoint const& p, bool bTime, std::vector<liblas::uint8_t>& point_data)
+bool GetPointData(  LASPoint const& p,
+                    bool bTime,
+                    std::vector<liblas::uint8_t>& point_data)
     // This function returns an array of bytes describing the
     // x,y,z and optionally time values for the point.
@@ -238,7 +223,10 @@
     return true;
-bool GetResultData(const LASQueryResult& result, LASReader* reader, std::vector<liblas::uint8_t>& data, int nDimension)
+bool GetResultData( const LASQueryResult& result,
+                    LASReader* reader,
+                    std::vector<liblas::uint8_t>& data,
+                    int nDimension)
     list<SpatialIndex::id_type> const& ids = result.GetIDs();
@@ -298,7 +286,12 @@
     return true;
-bool InsertBlock(OWConnection* connection, const LASQueryResult& result, int srid, LASReader* reader, const char* tableName, long precision)
+bool InsertBlock(OWConnection* connection,
+                const LASQueryResult& result,
+                int srid,
+                long precision)
     ostringstream oss;
@@ -306,17 +299,38 @@
     const SpatialIndex::Region* b = result.GetBounds();
     liblas::uint32_t num_points =ids.size();
     ostringstream oss_geom;
+    ostringstream s_srid;
+    ostringstream s_gtype;
+    ostringstream s_eleminfo;
+    bool bUse3d = true;
+    if (srid == 0) {
+        s_srid << "NULL";
+        s_gtype << "2003";
+        s_eleminfo  << "(1,1003,3)";
+        bUse3d = false;
+    } else {
+        s_srid << srid;
+        s_gtype << "3008";
+        s_eleminfo << "(1,1007,3)";
     oss_geom.setf(std::ios_base::fixed, std::ios_base::floatfield);
     oss_geom.precision(precision);
-    oss_geom << "mdsys.sdo_geometry(3008,"<<srid<<", null,"
-              "mdsys.sdo_elem_info_array(1,1007,3),"
-              "mdsys.sdo_ordinate_array("<< b->getLow(0) <<","<<
-                                            b->getLow(1) <<","<<
-                                            b->getLow(2) <<","<<
-                                            b->getHigh(0) <<","<<
-                                            b->getHigh(1) <<","<<
-                                            b->getHigh(2)<<"))";
+    oss_geom << "mdsys.sdo_geometry(" << s_gtype.str() << "," << s_srid.str() << ", null,";
+    oss_geom << "mdsys.sdo_elem_info_array" << s_eleminfo.str() << ",";
+    oss_geom << "mdsys.sdo_ordinate_array("<< b->getLow(0) <<","<<
+                                            b->getLow(1) <<",";
+    if (bUse3d)
+        oss_geom <<                         b->getLow(2) <<",";
+    oss_geom <<                             b->getHigh(0) <<","<<
+                                            b->getHigh(1);
+    if (bUse3d)
+        oss_geom                            <<","<< b->getHigh(2);
+    oss_geom << "))";
     oss << "INSERT INTO "<< tableName << "(BLK_ID, NUM_POINTS, BLK_EXTENT, POINTS) VALUES ( "
                          << result.GetID() <<"," << num_points << ", " << oss_geom.str() <<", EMPTY_BLOB())";
@@ -375,7 +389,11 @@
-bool CreateSDOEntry(OWConnection* connection, const char* tableName, LASQuery* query, long srid, long precision)
+bool CreateSDOEntry(    OWConnection* connection,
+                        LASQuery* query,
+                        long srid,
+                        long precision)
     ostringstream oss;
@@ -384,6 +402,16 @@
     oss.setf(std::ios_base::fixed, std::ios_base::floatfield);
     oss.precision(precision);
+    if (srid == 0) {
+        s_srid << "NULL";
+        bUse3d = false;
+    } else {
+        s_srid << srid;
 //     code = """
 // INSERT INTO user_sdo_geom_metadata VALUES (
@@ -397,9 +425,14 @@
     oss <<  "INSERT INTO user_sdo_geom_metadata VALUES ('" << tableName <<
             "','blk_extent', MDSYS.SDO_DIM_ARRAY("
             "MDSYS.SDO_DIM_ELEMENT('X', "<< query->bounds.getLow(0) <<","<< query->bounds.getHigh(0)<<",0.05),"
-            "MDSYS.SDO_DIM_ELEMENT('Y', "<< query->bounds.getLow(1) <<","<< query->bounds.getHigh(1)<<",0.05),"
-            "MDSYS.SDO_DIM_ELEMENT('Z', "<< query->bounds.getLow(2) <<","<< query->bounds.getHigh(2)<<",0.05)),"
-            << srid << ")";
+            "MDSYS.SDO_DIM_ELEMENT('Y', "<< query->bounds.getLow(1) <<","<< query->bounds.getHigh(1)<<",0.05)";
+    if (bUse3d) {
+        oss << "," <<
+            "MDSYS.SDO_DIM_ELEMENT('Z', "<< query->bounds.getLow(2) <<","<< query->bounds.getHigh(2)<<",0.05)";
+    oss << ")," << s_srid.str() << ")";
     oss.str("");
@@ -408,12 +441,27 @@
-bool CreateBlockIndex(OWConnection* connection, const char* tableName)
+bool CreateBlockIndex(OWConnection* connection, const char* tableName, long srid)
     ostringstream oss;
-    oss << "CREATE INDEX "<< tableName <<"_cloud_idx on "<<tableName<<"(blk_extent) INDEXTYPE IS MDSYS.SPATIAL_INDEX PARAMETERS('sdo_indx_dims=3')" ;
+    if (srid == 0) {
+        s_srid << "NULL";
+        bUse3d = false;
+    } else {
+        s_srid << srid;
+    oss << "CREATE INDEX "<< tableName <<"_cloud_idx on "<<tableName<<"(blk_extent) INDEXTYPE IS MDSYS.SPATIAL_INDEX";
+    if (bUse3d) {
+        oss <<" PARAMETERS('sdo_indx_dims=3')" ;
     oss.str("");
@@ -465,6 +513,9 @@
                     long precision)
     ostringstream oss;
@@ -500,6 +551,13 @@
         columns << cloudColumnName_u;
         values << "pc";
+    if (srid == 0) {
+        s_srid << "NULL";
+        bUse3d = false;
+    } else {
+        s_srid << srid;
 oss << "declare\n"
 "  pc sdo_pc;\n"
@@ -510,7 +568,7 @@
 "          '"<< cloudColumnName_u<<"',   -- Column name of the SDO_POINT_CLOUD object\n"
 "          '"<<blkTableName_u<<"', -- Table to store blocks of the point cloud\n"
 "           'blk_capacity="<<blk_capacity<<"', -- max # of points per block\n"
-"           mdsys.sdo_geometry(3008, "<<srid<<", null,\n"
+"           mdsys.sdo_geometry(3008, "<<s_srid.str()<<", null,\n"
 "              mdsys.sdo_elem_info_array(1,1007,3),\n"
 "              mdsys.sdo_ordinate_array(\n"
 << query->bounds.getLow(0) << ","
@@ -600,7 +658,7 @@
     bool bDropTable = false;
     liblas::uint32_t nCapacity = 10000;
     double dFillFactor = 0.99;
-    int srid = 4327;
+    int srid = 0;
     long precision = 8;
     for (int i = 1; i < argc; i++)
@@ -838,8 +896,9 @@
     if (!bUseExistingBlockTable) {
+        std::cout << "Creating new block table user_sdo_geom_metadata entries and index ..." << std::endl;
         CreateSDOEntry(con, table_name.c_str(), query, srid , precision);
-        CreateBlockIndex(con, table_name.c_str());
+        CreateBlockIndex(con, table_name.c_str(), srid);
     bool output = CreatePCEntry(  con,
More information about the Liblas-commits mailing list
