[Liblas-commits] hg: support doing 2d indexing
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Oct 23 13:19:35 EDT 2009
changeset 6ead09c2f4b9 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=6ead09c2f4b9
summary: support doing 2d indexing
diffstat:
 apps/las2oci.cpp                    |  12 +++++++++++-
 apps/lasindex.cpp                   |  27 +++++++++++----------------
 include/liblas/index/datastream.hpp |  13 +++++++++++--
 include/liblas/index/index.hpp      |   8 ++++++++
 src/index/datastream.cpp            |   4 ++--
 src/index/index.cpp                 |   4 ++--
 6 files changed, 45 insertions(+), 23 deletions(-)
diffs (194 lines):
diff -r bef66b66faee -r 6ead09c2f4b9 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Fri Oct 23 09:24:13 2009 -0500
+++ b/apps/las2oci.cpp	Fri Oct 23 12:16:35 2009 -0500
@@ -719,6 +719,7 @@
     double dFillFactor = 0.99;
     int srid = 0;
     long precision = 8;
+    long idx_dimension = 3;
     for (int i = 1; i < argc; i++)
@@ -769,6 +770,15 @@
             i++;
             srid=atoi(argv[i]);
+        else if (   strcmp(argv[i],"--idx-dimension") == 0  ||
+                    strcmp(argv[i],"-dim") == 0
+            i++;
+            idx_dimension=atoi(argv[i]);
         else if (   strcmp(argv[i],"--cloud-column-name") == 0  ||
                     strcmp(argv[i],"-cn") == 0
@@ -931,7 +941,7 @@
     LASReader* reader = new LASReader(*istrm);
-    LASIndexDataStream* idxstrm = new LASIndexDataStream(reader);
+    LASIndexDataStream* idxstrm = new LASIndexDataStream(reader, idx_dimension);
     LASIndex* idx = new LASIndex(input);
     idx->SetType(LASIndex::eExternalIndex);
diff -r bef66b66faee -r 6ead09c2f4b9 apps/lasindex.cpp
--- a/apps/lasindex.cpp	Fri Oct 23 09:24:13 2009 -0500
+++ b/apps/lasindex.cpp	Fri Oct 23 12:16:35 2009 -0500
@@ -52,7 +52,8 @@
 int main(int argc, char* argv[])
     std::string input;
-    std::string output;
+    long dimension = 3;
@@ -72,27 +73,19 @@
             i++;
             input = std::string(argv[i]);
-        else if (   std::strcmp(argv[i],"--output") == 0  ||
-                    std::strcmp(argv[i],"--out") == 0     ||
-                    std::strcmp(argv[i],"-out") == 0     ||
-                    std::strcmp(argv[i],"-o") == 0
+        else if (   std::strcmp(argv[i],"--dimension") == 0  ||
+                    std::strcmp(argv[i],"-dim") == 0     ||
+                    std::strcmp(argv[i],"-d") == 0
             i++;
-            output = std::string(argv[i]);
+            dimension = atoi(argv[i]);
-        else if (i == argc - 2 && output.empty() && input.empty())
+        else if (input.empty())
-        else if (i == argc - 1 && output.empty() && input.empty())
-            input = std::string(argv[i]);
         else
             usage();
@@ -110,12 +103,14 @@
     std::cout << "Indexing " << input<< " "<<std::endl;
+    LASIndexDataStream* idxstrm = new LASIndexDataStream(reader, dimension);
     idx->SetLeafCapacity(10000);
     idx->SetFillFactor(0.8);
+    idx->SetDimension(dimension);
     idx->Initialize(*idxstrm);
     delete idx;
diff -r bef66b66faee -r 6ead09c2f4b9 include/liblas/index/datastream.hpp
--- a/include/liblas/index/datastream.hpp	Fri Oct 23 09:24:13 2009 -0500
+++ b/include/liblas/index/datastream.hpp	Fri Oct 23 12:16:35 2009 -0500
@@ -65,7 +65,7 @@
 class LASIndexDataStream : public SpatialIndex::IDataStream
 public:
-    LASIndexDataStream(LASReader* reader);
+    LASIndexDataStream(LASReader* reader, long dimension);
     ~LASIndexDataStream();
     SpatialIndex::IData* getNext();
@@ -74,12 +74,21 @@
     ::uint32_t size() throw (Tools::NotSupportedException);
     void rewind() throw (Tools::NotSupportedException);
+    /// Sets the index dimension
+    /// \param v - dimension value.  Defaults to 3.
+    void SetDimension(uint32_t v) { m_idxDimension = v; }
+    /// Get index dimension
+    /// \return index dimension value.
+    uint32_t GetDimension() { return m_idxDimension; }
 protected:
     liblas::LASReader* m_reader;
     SpatialIndex::RTree::Data* m_pNext;
     SpatialIndex::id_type m_id;
+    uint32_t m_idxDimension;
     bool readPoint();
diff -r bef66b66faee -r 6ead09c2f4b9 include/liblas/index/index.hpp
--- a/include/liblas/index/index.hpp	Fri Oct 23 09:24:13 2009 -0500
+++ b/include/liblas/index/index.hpp	Fri Oct 23 12:16:35 2009 -0500
@@ -146,6 +146,14 @@
     /// Gets the index type
     /// \return index type.
     IndexType GetType() { return m_idxType; }
     LASVariableRecord* GetVLR();
diff -r bef66b66faee -r 6ead09c2f4b9 src/index/datastream.cpp
--- a/src/index/datastream.cpp	Fri Oct 23 09:24:13 2009 -0500
+++ b/src/index/datastream.cpp	Fri Oct 23 12:16:35 2009 -0500
@@ -57,7 +57,7 @@
-LASIndexDataStream::LASIndexDataStream(LASReader *reader) : m_reader(reader), m_pNext(0), m_id(0)
+LASIndexDataStream::LASIndexDataStream(LASReader *reader, long dimension) : m_reader(reader), m_pNext(0), m_id(0), m_idxDimension(dimension)
     bool read = readPoint();
     if (read) m_id = 0;
@@ -87,7 +87,7 @@
     max[0] = x; max[1] = y; max[2] = z;
-    SpatialIndex::Region r = SpatialIndex::Region(min, max, 3);
+    SpatialIndex::Region r = SpatialIndex::Region(min, max, m_idxDimension);
     m_pNext = new SpatialIndex::RTree::Data(0, 0, r, m_id);
      // std::cout << "Read point " << r <<  "Id: " << m_id << std::endl;
diff -r bef66b66faee -r 6ead09c2f4b9 src/index/index.cpp
--- a/src/index/index.cpp	Fri Oct 23 09:24:13 2009 -0500
+++ b/src/index/index.cpp	Fri Oct 23 12:16:35 2009 -0500
@@ -331,7 +331,7 @@
         throw std::runtime_error("Spatial index has not been initialized");
     try {
-        m_rtree->insertData(0, 0, SpatialIndex::Region(min, max, 3), id);
+        m_rtree->insertData(0, 0, SpatialIndex::Region(min, max, m_idxDimension), id);
     } catch (Tools::Exception& e) {
         std::ostringstream os;
         os << "Spatial Index Error: " << e.what();
@@ -361,7 +361,7 @@
     std::vector<uint32_t>* vect = new std::vector<uint32_t>;
     LASVisitor* visitor = new LASVisitor(vect);
-    SpatialIndex::Region* region = new SpatialIndex::Region(min, max, 3);
+    SpatialIndex::Region* region = new SpatialIndex::Region(min, max, m_idxDimension);
     try {
         m_rtree->intersectsWithQuery(*region, *visitor);
More information about the Liblas-commits mailing list
