[Liblas-commits] hg: [cmake] Added experimental rules for MSVC to set custom PATH...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Sep 29 15:33:29 EDT 2009
changeset e7c73ce07e62 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=e7c73ce07e62
summary: [cmake] Added experimental rules for MSVC to set custom PATH for Debugging->Environment property in generated *.vcproj.*.user file so all run-time dependencies are found and libLAS programs can run inside IDE.
diffstat:
 CMakeLists.txt                          |    8 ++
 apps/CMakeLists.txt                     |   12 +++
 build/cmake/libLAS.vcproj.user.template |  121 ++++++++++++++++++++++++++++++
 3 files changed, 141 insertions(+), 0 deletions(-)
diffs (166 lines):
diff -r ea3f319afd55 -r e7c73ce07e62 CMakeLists.txt
--- a/CMakeLists.txt	Tue Sep 29 00:36:19 2009 +0100
+++ b/CMakeLists.txt	Tue Sep 29 20:33:20 2009 +0100
@@ -58,6 +58,14 @@
             ADD_DEFINITIONS(-D_CRT_SECURE_NO_WARNINGS)
             ADD_DEFINITIONS(-D_CRT_NONSTDC_NO_WARNING)
         ENDIF()
+        # Generate dot-user file with user-specific settings for Visual Studio project
+        SET(MSVC_ENVIRONMENT_PATH "" CACHE STRING
+            "Custom PATH for Environment property in Visual Studio project configuration")
+        MARK_AS_ADVANCED(MSVC_ENVIRONMENT_PATH)
+        SET(VCPROJ_USER_ENVIRONMENT_PATH_DEBUG "${ENVIRONMENT_PATH}")
+        MARK_AS_ADVANCED(VCPROJ_USER_ENVIRONMENT_PATH_DEBUG)
     ENDIF()
 ELSE()
     IF(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
diff -r ea3f319afd55 -r e7c73ce07e62 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Tue Sep 29 00:36:19 2009 +0100
+++ b/apps/CMakeLists.txt	Tue Sep 29 20:33:20 2009 +0100
@@ -37,6 +37,18 @@
     ${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT} ${TXT2LAS}
     ${LAS2OGR} ${LASINDEX} ${LAS2OCI})
+# TODO: Experimental and requires testing --mloskot
+# Generate user-specific settings for Visual Studio project
+SET(VCPROJ_USER_REMOTE_MACHINE_DEBUG ${MACHINE_NAME})
+SET(VCPROJ_USER_ENVIRONMENT_DEBUG "${ENVIRONMENT_PATH}")
+FOREACH(utility ${LIBLAS_UTILITIES})
+    SET(USER_FILE ${utility}.vcproj.$ENV{USERDOMAIN}.$ENV{USERNAME}.user)
+    SET(OUTPUT_PATH ${CMAKE_CURRENT_BINARY_DIR}/${USER_FILE})
+    MESSAGE(STATUS "Generating ${CMAKE_GENERATOR} user-specific settings in ${USER_FILE}")
+    CONFIGURE_FILE(${CMAKE_SOURCE_DIR}/build/cmake/libLAS.vcproj.user.template ${OUTPUT_PATH} @ONLY)
+ENDFOREACH()
 # Configure build targets
diff -r ea3f319afd55 -r e7c73ce07e62 build/cmake/libLAS.vcproj.user.template
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/build/cmake/libLAS.vcproj.user.template	Tue Sep 29 20:33:20 2009 +0100
@@ -0,0 +1,121 @@
+<?xml version="1.0" encoding="Windows-1252"?>
+<VisualStudioUserFile
+	ProjectType="Visual C++"
+	Version="9.00"
+	ShowAllFiles="false"
+  <Configurations>
+    <Configuration
+			Name="Debug|Win32"
+      <DebugSettings
+				Command="$(TargetPath)"
+				WorkingDirectory=""
+				CommandArguments=""
+				Attach="false"
+				DebuggerType="3"
+				Remote="1"
+				RemoteMachine="DEV410"
+				RemoteCommand=""
+				HttpUrl=""
+				PDBPath=""
+				SQLDebugging=""
+        Environment="PATH=@VCPROJ_USER_ENVIRONMENT_PATH_DEBUG@;%PATH%"
+				EnvironmentMerge="true"
+				DebuggerFlavor="0"
+				MPIRunCommand=""
+				MPIRunArguments=""
+				MPIRunWorkingDirectory=""
+				ApplicationCommand=""
+				ApplicationArguments=""
+				ShimCommand=""
+				MPIAcceptMode=""
+				MPIAcceptFilter=""
+    </Configuration>
+    <Configuration
+			Name="Release|Win32"
+      <DebugSettings
+				Attach="false"
+				DebuggerType="3"
+				Remote="1"
+				RemoteCommand=""
+				HttpUrl=""
+				PDBPath=""
+				SQLDebugging=""
+				MPIRunCommand=""
+				ShimCommand=""
+				MPIAcceptMode=""
+    </Configuration>
+    <Configuration
+			Name="MinSizeRel|Win32"
+      <DebugSettings
+				Attach="false"
+				DebuggerType="3"
+				Remote="1"
+				RemoteCommand=""
+				HttpUrl=""
+				PDBPath=""
+				SQLDebugging=""
+				MPIRunCommand=""
+				ShimCommand=""
+				MPIAcceptMode=""
+    </Configuration>
+    <Configuration
+			Name="RelWithDebInfo|Win32"
+      <DebugSettings
+				Attach="false"
+				DebuggerType="3"
+				Remote="1"
+				RemoteCommand=""
+				HttpUrl=""
+				PDBPath=""
+				SQLDebugging=""
+				MPIRunCommand=""
+				ShimCommand=""
+				MPIAcceptMode=""
+    </Configuration>
+  </Configurations>
+</VisualStudioUserFile>
\ No newline at end of file
More information about the Liblas-commits mailing list
