[Liblas-commits] hg: Added <boost/cstdint.hpp> header and using namespace boost; ...
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Aug 2 12:46:36 EDT 2010
changeset 8c3cc1a87d67 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=8c3cc1a87d67
summary: Added <boost/cstdint.hpp> header and using namespace boost; directive missing for Visual C++.
diffstat:
 include/liblas/detail/pointrecord.hpp   |  18 ++++----
 include/liblas/detail/reader/point.hpp  |   6 +-
 include/liblas/detail/reader/reader.hpp |   2 +-
 include/liblas/detail/utility.hpp       |  10 ++--
 include/liblas/lasclassification.hpp    |   4 +-
 include/liblas/lasheader.hpp            |  68 ++++++++++++++++----------------
 include/liblas/lasvariablerecord.hpp    |  35 ++++++++--------
 src/detail/reader/reader.cpp            |  20 +++++----
 src/lasheader.cpp                       |   2 +
 src/laspoint.cpp                        |   2 +
 src/lasschema.cpp                       |   4 +
 src/lasvariablerecord.cpp               |  45 +++++++++++----------
 12 files changed, 115 insertions(+), 101 deletions(-)
diffs (truncated from 559 to 300 lines):
diff -r d0cfd54c9995 -r 8c3cc1a87d67 include/liblas/detail/pointrecord.hpp
--- a/include/liblas/detail/pointrecord.hpp	Mon Aug 02 11:39:02 2010 -0500
+++ b/include/liblas/detail/pointrecord.hpp	Mon Aug 02 17:50:18 2010 +0100
@@ -61,15 +61,15 @@
         , point_source_id(0)
-    int32_t x;
-    int32_t y;
-    int32_t z;
-    uint16_t intensity;
-    uint8_t flags; // TODO: Replace with portable std::bitset<8>
-    uint8_t classification;
-    int8_t scan_angle_rank;
-    uint8_t user_data; // 1.0: File Marker / 1.1: User Data
-    uint16_t point_source_id; // 1.0: User Bit field / 1.1: Point Source ID
+    boost::int32_t x;
+    boost::int32_t y;
+    boost::int32_t z;
+    boost::uint16_t intensity;
+    boost::uint8_t flags; // TODO: Replace with portable std::bitset<8>
+    boost::uint8_t classification;
+    boost::int8_t scan_angle_rank;
+    boost::uint8_t user_data; // 1.0: File Marker / 1.1: User Data
+    boost::uint16_t point_source_id; // 1.0: User Bit field / 1.1: Point Source ID
 }} // namespace liblas::detail
diff -r d0cfd54c9995 -r 8c3cc1a87d67 include/liblas/detail/reader/point.hpp
--- a/include/liblas/detail/reader/point.hpp	Mon Aug 02 11:39:02 2010 -0500
+++ b/include/liblas/detail/reader/point.hpp	Mon Aug 02 17:50:18 2010 +0100
@@ -48,8 +48,8 @@
 #include <liblas/lasheader.hpp>
 #include <liblas/laspoint.hpp>
 #include <liblas/lasschema.hpp>
+// boost
+#include <boost/cstdint.hpp>
 // std
 #include <iosfwd>
@@ -80,7 +80,7 @@
     std::istream& m_ifs;
     HeaderPtr m_header;
     PointPtr m_point;
-    std::vector<uint8_t> m_raw_data;
+    std::vector<boost::uint8_t> m_raw_data;
     void setup();
     void fill(PointRecord& record);
diff -r d0cfd54c9995 -r 8c3cc1a87d67 include/liblas/detail/reader/reader.hpp
--- a/include/liblas/detail/reader/reader.hpp	Mon Aug 02 11:39:02 2010 -0500
+++ b/include/liblas/detail/reader/reader.hpp	Mon Aug 02 17:50:18 2010 +0100
@@ -119,7 +119,7 @@
     void CacheData(boost::uint32_t position, HeaderPtr header);
-    typedef std::vector<uint8_t> cache_mask_type;
+    typedef std::vector<boost::uint8_t> cache_mask_type;
     cache_mask_type m_mask;
     cache_mask_type::size_type m_cache_size;
     cache_mask_type::size_type m_cache_start_position;
diff -r d0cfd54c9995 -r 8c3cc1a87d67 include/liblas/detail/utility.hpp
--- a/include/liblas/detail/utility.hpp	Mon Aug 02 11:39:02 2010 -0500
+++ b/include/liblas/detail/utility.hpp	Mon Aug 02 17:50:18 2010 +0100
@@ -147,11 +147,11 @@
 /// Definition of variable-length record header.
 struct VLRHeader
-  uint16_t reserved;
-  char userId[16];
-  uint16_t recordId;
-  uint16_t recordLengthAfterHeader;
-  char description[32];
+  boost::uint16_t reserved;
+  char userId[16]; // TODO: replace wtih boost::array --mloskot
+  boost::uint16_t recordId;
+  boost::uint16_t recordLengthAfterHeader;
+  char description[32]; // TODO: replace wtih boost::array --mloskot
 template <typename T>
diff -r d0cfd54c9995 -r 8c3cc1a87d67 include/liblas/lasclassification.hpp
--- a/include/liblas/lasclassification.hpp	Mon Aug 02 11:39:02 2010 -0500
+++ b/include/liblas/lasclassification.hpp	Mon Aug 02 17:50:18 2010 +0100
@@ -144,7 +144,7 @@
     std::string GetClassName() const;
     /// Returns index of ASPRS classification as defined in the lookup table.
-    uint8_t GetClass() const;
+    boost::uint8_t GetClass() const;
     /// Updates index of ASPRS classification as defined in the lookup table.
     /// Valid index is in range from 0 to class_table_size - 1.
@@ -155,7 +155,7 @@
     /// table is supported.
     /// @exception Theoretically, may throw std::out_of_range in case index
     /// value is not in range between 0 and class_table_size - 1.
-    void SetClass(uint8_t index);
+    void SetClass(boost::uint8_t index);
     /// Sets if this point was created by a technique other than LIDAR
     /// collection such as digitized from a photogrammetric stereo model.
diff -r d0cfd54c9995 -r 8c3cc1a87d67 include/liblas/lasheader.hpp
--- a/include/liblas/lasheader.hpp	Mon Aug 02 11:39:02 2010 -0500
+++ b/include/liblas/lasheader.hpp	Mon Aug 02 17:50:18 2010 +0100
@@ -190,38 +190,38 @@
     /// Set day of year of file creation date.
     /// \exception std::out_of_range - given value is higher than number 366.
     /// \todo TODO: Use full date structure instead of Julian date number.
-    void SetCreationDOY(uint16_t v);
+    void SetCreationDOY(boost::uint16_t v);
     /// Set year of file creation date.
     /// \todo TODO: Remove if full date structure is used.
-    uint16_t GetCreationYear() const;
+    boost::uint16_t GetCreationYear() const;
     /// Get year of file creation date.
     /// \exception std::out_of_range - given value is higher than number 9999.
-    void SetCreationYear(uint16_t v);
+    void SetCreationYear(boost::uint16_t v);
     /// Get number of bytes of generic verion of public header block storage.
     /// Standard version of the public header block is 227 bytes long.
-    uint16_t GetHeaderSize() const;
+    boost::uint16_t GetHeaderSize() const;
     /// Sets the header size.  Note that this is not the same as the offset to
     /// point data.
-    void SetHeaderSize(uint16_t v);
+    void SetHeaderSize(boost::uint16_t v);
     /// Get number of bytes from the beginning to the first point record.
-    uint32_t GetDataOffset() const;
+    boost::uint32_t GetDataOffset() const;
     /// Set number of bytes from the beginning to the first point record.
     /// \exception std::out_of_range - if given offset is bigger than 227+2 bytes
     /// for the LAS 1.0 format and 227 bytes for the LAS 1.1 format.
-    void SetDataOffset(uint32_t v);
+    void SetDataOffset(boost::uint32_t v);
     /// Get number of variable-length records.
-    uint32_t GetRecordsCount() const;
+    boost::uint32_t GetRecordsCount() const;
     /// Set number of variable-length records.
-    void SetRecordsCount(uint32_t v);
+    void SetRecordsCount(boost::uint32_t v);
     /// Get identifier of point data (record) format.
     PointFormatName GetDataFormatId() const;
@@ -230,18 +230,18 @@
     void SetDataFormatId(PointFormatName v);
     /// \todo To be documented
-    uint16_t GetDataRecordLength() const;
+    boost::uint16_t GetDataRecordLength() const;
     /// Set the length of the point format.  Evidently, there are
     /// LAS files in the wild that contain point formats of sizes that
     /// are different than the prescribed set specified in the specification.
-    void SetDataRecordLength(uint16_t v);
+    void SetDataRecordLength(boost::uint16_t v);
     /// Get total number of point records stored in the LAS file.
-    uint32_t GetPointRecordsCount() const;
+    boost::uint32_t GetPointRecordsCount() const;
     /// Set number of point records that will be stored in a new LAS file.
-    void SetPointRecordsCount(uint32_t v);
+    void SetPointRecordsCount(boost::uint32_t v);
     /// Get array of the total point records per return.
     RecordsByReturnArray const& GetPointRecordsByReturnCount() const;
@@ -250,7 +250,7 @@
     /// \exception std::out_of_range - if index is bigger than 4.
     /// \param index - subscript (0-4) of array element being updated.
     /// \param v - new value to assign to array element identified by index.
-    void SetPointRecordsByReturnCount(std::size_t index, uint32_t v);
+    void SetPointRecordsByReturnCount(std::size_t index, boost::uint32_t v);
     /// Get scale factor for X coordinate.
     double GetScaleX() const;
@@ -304,13 +304,13 @@
     void AddVLR(VariableRecord const& v);
     /// Returns a VLR
-    VariableRecord const& GetVLR(uint32_t index) const;
+    VariableRecord const& GetVLR(boost::uint32_t index) const;
     /// Returns all of the VLRs
     const std::vector<VariableRecord>& GetVLRs() const;
     /// Removes a VLR from the the header.
-    void DeleteVLR(uint32_t index);
+    void DeleteVLR(boost::uint32_t index);
     /// Rewrite variable-length record with georeference infomation, if available.
     void SetGeoreference();
@@ -357,25 +357,25 @@
     // Private data members
-    char m_signature[eFileSignatureSize];
-    uint16_t m_sourceId;
-    uint16_t m_reserved;
-    uint32_t m_projectId1;
-    uint16_t m_projectId2;
-    uint16_t m_projectId3;
-    uint8_t m_projectId4[eProjectId4Size];
-    uint8_t m_versionMajor;
-    uint8_t m_versionMinor;
-    char m_systemId[eSystemIdSize];
+    char m_signature[eFileSignatureSize]; // TODO: replace with boost::array --mloskot
+    boost::uint16_t m_sourceId;
+    boost::uint16_t m_reserved;
+    boost::uint32_t m_projectId1;
+    boost::uint16_t m_projectId2;
+    boost::uint16_t m_projectId3;
+    boost::uint8_t m_projectId4[eProjectId4Size];
+    boost::uint8_t m_versionMajor;
+    boost::uint8_t m_versionMinor;
+    char m_systemId[eSystemIdSize]; // TODO: replace with boost::array --mloskot
     char m_softwareId[eSoftwareIdSize];
-    uint16_t m_createDOY;
-    uint16_t m_createYear;
-    uint16_t m_headerSize;
-    uint32_t m_dataOffset;
-    uint32_t m_recordsCount;
-    uint8_t m_dataFormatId;
-    uint16_t m_dataRecordLen;
-    uint32_t m_pointRecordsCount;
+    boost::uint16_t m_createDOY;
+    boost::uint16_t m_createYear;
+    boost::uint16_t m_headerSize;
+    boost::uint32_t m_dataOffset;
+    boost::uint32_t m_recordsCount;
+    boost::uint8_t m_dataFormatId;
+    boost::uint16_t m_dataRecordLen;
+    boost::uint32_t m_pointRecordsCount;
     RecordsByReturnArray m_pointRecordsByReturn;
     PointScales m_scales;
     PointOffsets m_offsets;
diff -r d0cfd54c9995 -r 8c3cc1a87d67 include/liblas/lasvariablerecord.hpp
--- a/include/liblas/lasvariablerecord.hpp	Mon Aug 02 11:39:02 2010 -0500
+++ b/include/liblas/lasvariablerecord.hpp	Mon Aug 02 17:50:18 2010 +0100
@@ -44,7 +44,8 @@
 #define LIBLAS_LASVARIABLERECORD_HPP_INCLUDED
 #include <liblas/detail/utility.hpp>
+// boost
 // std
 #include <string>
 #include <vector>
@@ -77,48 +78,48 @@
     /// Get record signature (LAS 1.0) or reserved bytes (LAS 1.1).
     /// \exception No throw
-    uint16_t GetReserved() const;
+    boost::uint16_t GetReserved() const;
-    void SetReserved(uint16_t);
+    void SetReserved(boost::uint16_t data);
     /// Get identifier of user which created the record.
     /// The character data is up to 16 bytes long.
     std::string GetUserId(bool pad /*= false*/) const;
-    void SetUserId(std::string const&);
+    void SetUserId(std::string const& id);
     /// Get identifier of record.
     /// The record ID is closely related to the user ID.
-    uint16_t GetRecordId() const;
+    boost::uint16_t GetRecordId() const;
-    void SetRecordId(uint16_t);
+    void SetRecordId(boost::uint16_t id);
     /// Get record length after the header.
-    uint16_t GetRecordLength() const;
+    boost::uint16_t GetRecordLength() const;
-    void SetRecordLength(uint16_t);
+    void SetRecordLength(boost::uint16_t length);
     /// Get text description of data in the record.
     /// The character data is up to 32 bytes long.
     std::string GetDescription(bool pad /*= false*/) const;
More information about the Liblas-commits mailing list
